We have contest winners!
I find that my felling wedges tend to be tipped rather than level. Is there a line that will help me hold the saw level for the lower part of the wedge cut?
The pro series Huskies (and brand X) have a black line on the rewind housing and cylinder cover. This is to give the operator a guide when felling as the line should be parallel to the intended path when making the cuts. Remember, it is a guide and there are no guarantees.
As for making the back cut level. I hold my saw by the top handle. The key word there is hold, not grab. I let the saw balance itself and that gives me a reference line in which to make the back cut. I found its quick, easy and gravity never lies no matter what ghillside you are on.
I don't trust using the bottom of the front handle. I've had saws that had this handle sitting at an angle. If your particular saw has this handle set at a right angle, then it can be used. I don't trust it myself though.
Do you hear, Jeff!
Jokers,I never had even heard of the term gunning sticks. You just taught me something.
I have a sneaking suspicion that Jeff and you have a little disagreement on bar lengths......
And yes Deadwood, SawTroll and I go back and forth on bar length and full wrap handles. But it's certainly all friendly banter and well intended. Right SawTroll?
Started by joman on Sawmills and Milling
Started by roman on Forestry and Logging
Started by NotEnoughTime on Sawmills and Milling
Started by captain_crunch on Sawmills and Milling
