Dynamic Green Products Inc.
Author Topic: Grinder Head Angles on a TECOMEC chain saw grinder--Same grinder as Oregon 511  (Read 4528 times)
Offline hydro2
What angle should the head on a TECOMEC chain grinder be set at for .325 chain and 3/8 chain.  I put a new chain in and lined up the motor-head andn it seems to be coming about to about 60 degrees using the new chain as a guide.
353 Husky
Husky 372XP
030 Stihl
Mahindra 4035
Speeco Log Splitter
Hardy Outside Wood Stove
Offline hydro2
I guesse what I am trying to ask is, I know my cutter should be filed with a hand file at 35 degrees, is that called the top plate filing angle?  Should I be setting the head (motor) angle to 60 degrees and is that called the top plate cutting angle?
353 Husky
Husky 372XP
030 Stihl
Mahindra 4035
Speeco Log Splitter
Offline hydro2
What is up with all of the Dis Yooper  stuff????????
353 Husky
Husky 372XP
030 Stihl
Mahindra 4035
Speeco Log Splitter
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
the grinding wheel angle should be about 60 degrees.
the 35 degree setting is the vise angle.
if your vise tilts, you may want to set it to 10 degrees for a better angle.
did that make sense?
Welcome to the forum, our fearless (maybe fearful) leader, JeffB likes to make us talk like his friends and neighbors up there in michigan talk sometimes!
lots of dull bands and chains
Offline hydro2
Thank you so much.  I thought the cutter head should be at 60, after grinder once at 45 and once at 90 degrees.  Oh well, learn as you go.  The manuals are not the great.
353 Husky
Husky 372XP
030 Stihl
Mahindra 4035
Speeco Log Splitter
Offline rickk
If it is the same as the Oregon 511, you can get Oregon's manual on-line. I don't know if it is any different, but worth looking. I found it to be a bit confusing but sill usefull after re-reading things a couple of times.
If you either get a hard dopy (free) or download and read Oregon's bar and chain and sproket maintence booklet first the grinder settings will be less of a mystery. You can either download or order a free copy from Oregon's web site. The book is great to have, as it shows all the angles for, and how to identify all of their different chains.
Oregon Chain Grinder vs. Stihl chain angles
Started by Chelsea Tree on Chainsaws
Last post July 08, 2013, 07:58:36 AM
by bandmiller2
Tecomec FL 136 chain grinder
Started by chugbug on Chainsaws
Last post November 09, 2008, 06:34:30 PM
by chugbug
oregon chain grinder
Started by poorfarm on For Sale
Last post October 26, 2012, 08:00:24 AM
by poorfarm
Oregon 511 chain grinder
Started by DonT on Chainsaws
Last post October 29, 2009, 09:04:48 PM
by DGK
