Author Topic: Walnut Stump and Burl [Sawing and Drying]  (Read 11951 times)
Offline 333_okh
  • Got Wood
« on: December 16, 2005, 03:26:51 PM »
Well I am new here so I might be asking something that has been covered a thousand times.
I recently had a burl stump from a walnut tree in northern California that needed cut up fast and hauled out before it went to the grinder.
What is the best way to cut up a stump/burl like this? Is was circular in shape.  No taller than wide, an no side was sider than the other.
What is the best way, and how long should I dry these slabs? They are between 4-6 inches thick.
Offline Frank_Pender
Re: Walnut Stump and Burl [Sawing and Drying]
« Reply #1 on: December 16, 2005, 03:35:13 PM »
Welcome to the Forum 333.    Whe I have done such to stumps and Walnut burl, I let it air dry.  One of the rules of thumb is a year to the inch.  I would recommend that you keep them out of the Sun and covered  well from a great deal of heat.  The slower you begin the initisal drying process the better your wood will be,with my experiences. ;D
Offline 333_okh
  • Got Wood
« Reply #2 on: December 16, 2005, 04:27:49 PM »
I have the wood in the back end of a storage barn where no light will actually hit it.  The wood is stickered about 3/4 of and inch apart and stacked together. This sounds good then.
I have to cut it in large slabs starting my cut from the top where the stump wand and going down to the root section with each slice, just as you would an onion.  Was there a better way of slicing/sawing it?
Offline 333_okh
  • Got Wood
« Reply #3 on: December 18, 2005, 02:57:18 AM »
No more help? I wonder if  ireally ruined that burl dure to how it was cut? I have to cut it fast or it was going in a tub grinder.  Wood looked great, but man it dulled the chains on my saws fast!
« Reply #4 on: December 18, 2005, 08:26:25 AM »
I always use a full 1" x 1" sticker for everything I dry.  It provides for good air circulation.  I would put them no more than 18" apart.  You might even consider placing some real heavy weight on the top of the slabes with a 1" spacer between the slabs and weight.  I sometiems use large parts of a sidewalk for the wieght, like 500 lbss pieces.
I believe you took the correct action in the direction you made your cuts.   Without really seeing the stump and all it is a bit of a challenge in Monday morning quarterbacking. :'(
Offline 333_okh
  • Got Wood
« Reply #5 on: December 18, 2005, 02:35:12 PM »
I will tell you I have never cut such wet wood, but I cut it in November and put it straight away into a workshop on the north side of a hay barn.  It isnt too dry and there is no sun light on it.
Thi thing dulled my saws to the point where I have to sharpen 2-3 times per slab.  The wood, especially the cuts that went straight through the stump is amazing!
Offline Ironwood
    • http://www.branchandburl.com
« Reply #6 on: December 18, 2005, 03:44:20 PM »
WOOD love to see some photos someday. Reid
Offline Den Socling
  • just wondering
« Reply #7 on: December 18, 2005, 03:51:38 PM »
Welcome to the forum. I hate to greet you with bad news but 4-6" thick figured wood is not likely to work out for you. When you dry wood conventionally, you have to dry the surface more than the underlying wood and hope that water wicks out from the inside. The thicker the wood, the less likely of success. 2" thick can be a challenge. And the twisted grain that makes pretty figure adds a twist to drying. Maybe if it sits a few years........ ::) Hopefully, I'm all wet in my opinion.  :D
Offline 333_okh
  • Got Wood
« Reply #8 on: December 18, 2005, 04:08:22 PM »
The plan is 3 years stickered and a final kiln run after that to bring it down to where we need it ~6%.  Then we will cut it off templates and plane to size?
Here is a shot of a small outside piece of the wood.
Offline 333_okh
  • Got Wood
« Reply #9 on: December 18, 2005, 04:12:02 PM »
Sorry!
This is the wood rough planned.  Just testing a couple of peices.
http://s2.excoboard.com/forums/8151/user/150177/251033.jpg
Offline GaS
  • this space for rent
    • PC Specialties
« Reply #10 on: December 18, 2005, 06:12:18 PM »
Sorry!
 :o don't break it!!!
Offline 333_okh
  • Got Wood
« Reply #11 on: December 18, 2005, 07:01:39 PM »
Not kowing a lot about walnut burls, is this a typical looking burl?  I have about 2000lbs of this stuff wet.
The top of the tree was English, but the portion I cut up appears to be all the Claro root stock.  They chipped the tree itself, including where the graft must have been since I have no graft wood section in this wood.
This is the one part of the truck that I was able to saw.  It made two slabs 3 inches thick and about 18 inches wide and 3 feet long.
This is a close-up.
What happened to this picture?
Kirk_Allen
  • Guest
« Reply #12 on: December 18, 2005, 07:36:59 PM »
That is an awesome looking walnut burl.
Wont do you any good though cuz you need super duper special tools and I just happen to have them.  So to avoid lots of work and frustration wize dont you just send that burl my way and I will make sumtin prim and proper with it ;D :D
Offline 333_okh
  • Got Wood
« Reply #13 on: December 18, 2005, 07:40:01 PM »
If you like that peice you should see the one from the center cut.  It is 6 inches thick, 4 feet wide and eight feet long.  The center has grain like clouds going everywhere, and the entire outer ring looks just like that burl photo I posted.  You cannot imagine how much it currently weighs!
Offline Modat22
  • I love my dog.
« Reply #14 on: December 18, 2005, 09:38:16 PM »
you have a treasure there, a very nice treasure. 8)
Offline 333_okh
  • Got Wood
« Reply #15 on: December 18, 2005, 09:43:30 PM »
By the way the last cut looks was rougher than it should but your looking at my handy work with a chainsaw.  That has not bee planned.
Offline 333_okh
  • Got Wood
« Reply #16 on: December 31, 2005, 05:56:39 PM »
NOTE FROM ADMIN: We have rules on posting photos. Photos MUST reside on the forestry forum server and MUST be lest then 30k and less then 400 pixels maximum in their greatest dimension
Photo posting tutorial
http://www.forestryforum.com/board/index.php?topic=12416.0
This is a picture of a peice taken from one of the slabs to see how the wood looked for gunstocks.  It is 6.5 inch on the small side, 9.5 inch on the butt side, 4.5 inches thick and 18 inches long. I will actually reduce its thickness to 3 inches later due to a small burl/bark intrusion on the back side.
I hope, I hope, this dries nicely........
Offline Ironwood
« Reply #17 on: January 08, 2006, 07:15:28 AM »
WWWWWOOOOOOWWWWW. Reid
Offline Dana
    • Green Leaf Farms
« Reply #18 on: January 08, 2006, 09:11:01 AM »
Nicely figured wood, I don't think I could decide what to make if it was mine!
Offline 333_okh
  • Got Wood
« Reply #19 on: January 08, 2006, 11:50:59 AM »
Top is a different peice from the same stump.  The bottom is better pics of the wood from above.
I have a lot of this, but there is a bit of bark intrusion in some places limiting what it can be used for.
Walnut drying on the stump?
Started by WV Sawmiller on Sawmills and Milling
Last post November 26, 2017, 11:05:25 AM
by WV Sawmiller
Sawing Walnut and with Kiln Drying in Mind
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post March 31, 2017, 07:52:20 AM
by WDH
Burl on stump
Started by Bill Gaiche on General Board
Last post May 10, 2011, 06:52:26 AM
by Burlkraft
exclamation
Help with drying burl.
Started by muck on Drying and Processing
Last post June 14, 2014, 10:51:03 AM
by muck
