Dynamic Green Products Inc.
Author Topic: ? about older small skid steers  (Read 1461 times)
Offline whitepine
  • My idea of a good time is to walk my property line
« on: December 17, 2005, 10:30:18 PM »
Hi I have heard that the first bobcats that came out did not use hydraulic drives  and wheel motors but some kind of belt system does anyone know anything about them. I am refering to the small ones that used  like 16 hp gas engines. Did it work? Are the first 450 bobcats I think had 16 hp gas engines did they have hydraulic drives like modern ones? Is there a site where one could look this up? Thanks Tom
Offline badpenny
  • Go green recycle Congress
Re: ? about older small skid steers
« Reply #1 on: December 18, 2005, 10:19:45 AM »
   My '78-79-80 ish 610 Bobcat has a 24 hp Wisconsin with belt drive to a cross shaft to both sides of the machine, and the clutch packs on each side drive a #60 roller chain looped to both front and rear tires on each side. Hope this helps
Hope and Change, my foot,  It's time for Action and Results!
Info on skid steers
Started by killerman on General Board
Last post February 23, 2015, 11:15:14 AM
by barbender
Skid steers to work around your mills?????
Started by woodbe on Sawmills and Milling
Last post January 22, 2011, 11:58:30 AM
by jpgreen
Options, attachments, mods for Skid Steers?
Started by SawDust_Studios on Sawmills and Milling
Last post November 08, 2006, 10:26:11 AM
by slowzuki
Older Dozer or Tracked Skid Steer?
Started by Puffergas on Forestry and Logging
Last post September 08, 2015, 08:41:18 PM
by Puffergas
