Author Topic: Business Plan: doing my homework  (Read 1127 times)
Offline DoubleD
  • Knowledge is power
« on: January 17, 2006, 06:39:28 PM »
I am doing my homework because I want own a mill and operate it at least as a part time business. I am planning as a stationary electric mill, because here in Italy gas and diesel cost barely 6$ per gallon  smiley_crying smiley_eek_dropjaw smiley_furious3
I was unable to find some important information, I hope that you could answer some of my question
Which are the formulas to calculate overrun\underrun and the LRF lumber recovery factor in cubic meter?
Which are the log scaling rule used in Europe and in Italy?
Which are the grading rules for Europe and Italy?
Which is the volume of high grade and low grade lumber in  a log 17"(circa 45 cm) in cubic meter?
427 Board Feet= 1 cubic meter. Is this a valid conversion?
If a sawmill have an estimate production of 400 BF\hour Could I assume that the production is 1 cubic meter\hour?
Thank you
Wannabe a sawmiller
Offline Chris Burchfield
Re: Business Plan: doing my homework
« Reply #1 on: January 17, 2006, 07:14:12 PM »
I'm a bit metrically challenged. You may do better @ http://www.woodmizer-planet.com/ which is a website for European Woodmizer owners. However, similar to the Forestry Forum, I've seen comments by other mill owners as well. Hope this helps, Chris.
Woodmizer LT40SH W/Command Control; 51HP Cat, Memphis TN.
Offline DoubleD
« Reply #2 on: January 18, 2006, 05:56:24 AM »
Thank CB it helped to found the production per hour :P
Wannabe a sawmiller
business plan
Started by josh on Sawmills and Milling
Last post October 22, 2012, 01:26:12 AM
by OlJarhead
Business Plan
Started by woodsteach on Sawmills and Milling
Last post June 06, 2005, 10:39:18 PM
by AtLast
My business plan
Started by Darrel on General Board
Last post April 01, 2014, 08:54:19 PM
by scsmith42
Business Plan?
Started by 2StateTrigger on General Board
Last post November 25, 2015, 07:58:56 AM
by jdtuttle
