Author Topic: MS200T Won't stay running.......  (Read 8142 times)
Offline Bark Buster
  • Member*
  • Rookie
« on: January 29, 2006, 02:08:31 AM »
How hard is it to replace impulse line on the ms200.?..I'm suspecting it to be bad due to the hard starting of this saw, it starts only when choked and then after 7 or so pulls it runs and quits. The carb will also be kitted although it seems to be clean and diaphrams not distorted or torn. Saw sat for awhile but has new gas and good compression . Any suggestions ?? would be appreciated. Thanks in advance.
"You get what you inspect not what you expect."
Offline Mike_Barcaskey
  • professional outdoorsman
    • my PA Ag Map Page
Re: MS200T Won't stay running.......
« Reply #1 on: January 29, 2006, 07:44:36 AM »
same problem on mine a while ago, I took it into the dealer to fix
It matters not how strait the gate,
How charged with punishments the scroll,
I am the master of my fate:
I am the captain of my soul.
Offline Rocky_J
« Reply #2 on: January 29, 2006, 07:50:56 AM »
The carb has to be accessed through the air filter opening. Two 8mm nuts to remove the air filter mounting plate, but they also hold the carb in place. I'd recommend an air compressor with air nozzle to fully clean all around the carb before removing anything. Then pull the filter mounting plate and press your thumb over the carb opening and blow the carb off real well. Be careful when pulling linkage off the carb, if the part inside the handle gets messed up they are almost impossible to reassemble correctly. Stihl sells the top handle with all the linkage intact (and they are very proud of that handle).
Offline Jim Spencer
  • Washington, Mi
« Reply #3 on: February 01, 2006, 09:35:15 AM »
I had a similair problem with my 028.
How I solved my problem.
The cause of this problem was a screen in the carburetor was plugged.
There is a screen about 1/4" in diameter that is under the fuel pump diaphram and was plugged with dust.  The fuel pump seems to be powered from the movement of the piston and is on the opposite side of the carburetor from the gasoline diaphram.
The cover is held in place by 1 screw. Under that cover is a diaphram and under that there is a screen that can get debris from the exhaust.
This tiny screen was plugged.
Jim
Offline kenskip1
  • Stihl Looking for the fountain of middle age.
« Reply #4 on: February 09, 2006, 06:17:17 PM »
Jimmy, Back up!
    Have you read what you have told this man? Exhaust into the carb? How about the gas filter in the tank did not filter all the impurities. However, the screen in the carb caught this. The screen was cleaned and the saw is now running well.
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
    • my PA Ag Map Page
« Reply #5 on: February 10, 2006, 08:14:57 AM »
Bark Buster, did you get it fixed? What was wrong?
Offline ehp
  • logger/chainsaw hack
« Reply #6 on: February 18, 2006, 04:38:36 PM »
Check your 200 for a air leak at the back of the carb , if you can get it running just spray some WD-40 on the side of the carb the jets are on , spray it right at the point that the carb bolts to the saw, if it is leaking the saw will quit as soon as the WD hits it.
Ms200t running issues
Started by Grimace71 on Chainsaws
Last post June 13, 2018, 05:36:35 AM
by ladylake
Saw won't stay running
Started by JohnnyF on Chainsaws
Last post October 21, 2006, 08:36:24 PM
by PineNut
540a won't stay running
Started by henry co. on Forestry and Logging
Last post January 19, 2017, 09:22:49 PM
by ohiowoodchuck
Dozer won't stay running
Started by LeeB on Forestry and Logging
Last post April 03, 2012, 06:55:04 AM
by snowstorm
