Author Topic: Lubrication  (Read 7434 times)
Offline Shawn
  • Perfect Sawdust, everytime!!!
    • Shawn's Woodworking Page
Lubrication
« on: February 26, 2006, 11:51:21 PM »
What do you use in YOUR bandmill for blade lubrication???
Change is part of the design process.
Admit nothing, Deny everything, Make counter-accusations
Offline Radar67
  • Cuttin Wood Now For My House Later.
    • Stewart Photography
Re: Lubrication
« Reply #1 on: February 26, 2006, 11:55:27 PM »
Shawn, this has been covered many times on the forum. Most people use water and soap. You can do a search above and find lots of info on lube.
Welcome to the forum.
Stew
Re: Lubrication
« Reply #2 on: February 26, 2006, 11:56:26 PM »
I dont mind saying it again though.
Water
Offline Shawn
Re: Lubrication
« Reply #3 on: February 27, 2006, 12:13:00 AM »
I'm a member since Oct. I read here somewhere before about water and the cooks saw catolog aboout using diesel or kerosine. Just curious. Thanks everyone!
Shawn...
BTW...still waiting on parts this week and hopfully a truck full of steel by the weeks end...Pics forth coming!
Re: Lubrication
« Reply #4 on: February 27, 2006, 12:14:30 AM »
I just went and found this thread for you to read.  I think you might like it.
http://www.forestryforum.com/board/index.php?topic=850.msg9886#msg9886
Offline Radar67
Re: Lubrication
« Reply #5 on: February 27, 2006, 12:43:59 AM »
Here are two I found interesting when I was doing my research on blade lube.
http://www.forestryforum.com/board/index.php?topic=10365.0
http://www.forestryforum.com/board/index.php?topic=14800.0
I use water and liquid TIDE with BLEACH, one cap full per gallon.
Stew
Offline BBTom
  • Retired, If building a new homestead is retired.
Re: Lubrication
« Reply #6 on: February 27, 2006, 08:16:33 AM »
In winter I use WW fluid here where it gets cold.   I even use a bit of Pinesol in it for better wetting.  Summer is just water and pinesol, or water and WM blade lube.  Been trying to find out if it actually works better than the pinesol.  Not sure yet!!
Offline isassi
  • Dis-member-ed
Re: Lubrication
« Reply #7 on: February 27, 2006, 09:56:38 AM »
The guys from Mr Sawmill are bringing my blind freind's new bandmill today, and they told me on the phone, they reccomend 3 drops a minute of diesel/bar oil....Since I am not a bandmill person, I have read the threads, and will probably go with the majority here in helping Bill get set up. I will try to have pictures of Bill sawing his first log this evening.  :)
Offline loudsam
  • " You call, we haul, that's all"
Re: Lubrication
« Reply #8 on: February 27, 2006, 08:31:08 PM »
[quote
Quote
Hey Shawn,  I can hardly wait till you start putting the saw together. 8)  I still wish I would have built one.  I have to buy a welder anyway, as it turns out, for all the other things involved with this hobby. ;D
Doug
Offline thecfarm
Re: Lubrication
« Reply #9 on: February 27, 2006, 09:26:38 PM »
joasis,I have a manual bandsaw and I use the half diesel,half bar oil.I use alot more than 3 drops a minute.Just a slow drip,one every 3-4 seconds.I can tell when it's not flowing correctly,makes a differant sound.Just have to play with it to find out what works for you.I've cut lots of pine and never had problems with pitch.
Offline Shawn
Re: Lubrication
« Reply #10 on: February 28, 2006, 01:23:06 AM »
Doug,
I will let you know what I find. I want something good, But I don't want ti sink a house note into it. It probably will sit and collect dust after I finish using it.
Shawn...
Offline kelLOGg
Re: Lubrication
« Reply #11 on: March 06, 2006, 06:52:24 PM »
I've been using diesel and would like to switch to a water-based coolant for environmental reasons but I fear rusting out my steel coolant container from the inside. Any basis for this fear?
DH kiln, CatClaw, setter, tandem trailer, log arch, tractor, thumb tacks
Offline bberry
Re: Lubrication
« Reply #12 on: March 06, 2006, 08:35:23 PM »
kelLOGg,
I spent a lot of time looking at the pros and cons of water versus bar oil/diesel lube and found water and additives such as windshield wash, detergents etc. was probably not any better environmentally than the oil/bar lube. The amount of b-oil/diesel lube was very small and did a much better job of coating the blade and disolving the pitch. Others often complain about bearings being washed out by the water/detergent mix. I found that to be true. I do not have a Cook's saw but I do like their recommendations on sawing. I am environmentally conscious but sensible. I use more oil in my chain saw! Will the enviro -nuts stop using oil in their chainsaws? I taught woodshop and boatbuilding for 25 years and never saw stained lumber or smell problems from the diesel/bar oil. Even if there was a small drop on the surface it would be planed off in the processing! There are many more pros and cons but these are a few to help you. Happy sawing.
Offline Shawn
Re: Lubrication
« Reply #13 on: March 06, 2006, 08:45:06 PM »
I'm going to call my local Pizza Hut for a 5 Gal jug that the pan pizza oil comes in. I worked there in high school. An example of this jug is below.
http://www.mcmaster.com/
Part # 4135T23
Offline woodmills1
  • the truth shall set you free
Re: Lubrication
« Reply #14 on: March 06, 2006, 09:42:57 PM »
I am a bar oil and deisel guy but I just squirt it on from a can when needed or when the blade noise is up.  I tried all kinds of trigger cans and now use the old push on the bottem of the can style. seems the trigger cans dont like the winter.
Offline logwalker
  • Got Logs??
Re: Lubrication
« Reply #15 on: March 06, 2006, 09:45:22 PM »
I have been sawing in the same spot for 4 years using bar-oil/diesel for lube. I use less than 5 gallons a year and I have never seen any contamination on the wood deck below the carriage or anyway else. And you are right on about the chainsaws. Are they going to put windshield washer fluid in them? Hah!! LW
Offline slowzuki
  • Still learnin'
    • On the Farm
Re: Lubrication
« Reply #16 on: March 07, 2006, 08:10:25 AM »
Chainsaws are using lube for the metal chain running on metal bar rails. Sawmill doesn't have the same issues.
Offline jpgreen
  • My Boy- Snoopy Dogbone Green
Re: Lubrication
« Reply #17 on: March 07, 2006, 11:03:12 AM »
Anyone ever thought of using Ballistol mixed with water?
It's water soluble, and makes a great lube mixed with water.  Also safe for the environment.  I use it for all kinds of stuff.
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
Offline bberry
Re: Lubrication
« Reply #18 on: March 07, 2006, 07:11:07 PM »
Slowzuki,
       Yes, metal on metal is a good place to have oil based lubrication since it is a better lubricant. A great many band saw mills run metal blades on metal wheels and guides. The blade is held against the wheel and guides with tremendous pressure. This action is not quite the same as a chain saw but there is benefit to having a oil based molecular film between the two. Case hardening of the blade could shorten the life of the blade and may cause erratic cutting in the later stages of a blades life.
        Water based lube supporters lose their environmental edge when they live in a cold climate and have to resort to using windshield washer fluid straight or as a percentage. Windshield washer fluid uses methanol as it's base and that is now primarily made from petroleum bases. It is a volatile substance that is known to hurt the ozone layer. It is also highly poisonous and should not be left around small children or pets. Many know this substance by it's old name, "wood alcohol". Also I hope most people don't think Pinesol comes from pine trees. Some bandsaw mill manufacturers recommend oil based lube since it is a superior lubricant. Water is not a lubricant but you could say it is a coolant. However the oil based lube can do the same and provide better protection in other ways. I use oil based lube as conservatively as possible since it is expensive! As some say listen to your blade. A quiet blade is a happy blade! Makes me happy too! smiley_argue01
Offline slowzuki
  • Still learnin'
    • On the Farm
Re: Lubrication
« Reply #19 on: March 07, 2006, 08:28:21 PM »
bberry, I'm not pro oil or pro water etc :)
I will say the metal wheels only benefit from a solvent effects of oils keeping pitch off, there is no sliding friction ( we hope! ) for the oil to act on.  Only the backing lip of cooks or WM type guides benefit from an oil based lube for friction reasons.
Oil can dampen high frequency vibes in a blade.
Water and washer fluid are much better coolants, not letting the blade get much over 100 C where as oil can get as high as 300 - 400 C range before smoking.
Oil undoubtedly better lubes between the band body and the cant, probably more important on narrow set blades.
Methyl Alcohol isn't great stuff but the millions of gallons of it sprayed on car windows every winter makes sawmill use pretty insignificant.  It is broken down in the soil quite quickly just as very dilute oil is by bacteria.
I would think there is a good case for the use of one of many types of  fluids depending on what you're cutting.
Lubrication
Started by twostroke_blood on Sawmills and Milling
Last post June 03, 2005, 05:59:42 AM
by brucehuggins
Lubrication or dry cut
Started by Arkyrick on Sawmills and Milling
Last post July 22, 2018, 06:56:15 AM
by bandmiller2
question
Lubrication that is not toxic
Last post December 21, 2015, 06:18:12 AM
by Kbeitz
Chainsaw Lubrication
Started by WoodHead on Chainsaws
Last post August 31, 2004, 01:22:23 PM
by iain
