Dynamic Green Products Inc.
Author Topic: Wood-Mizer manual log loader  (Read 3586 times)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
« on: March 28, 2006, 09:12:16 AM »
How many of you use the manual log loader on your saws?  How well does it work?  Any tips?  I normally use a skidsteer to load logs onto a bunk and then roll them on to the saw. I have a log to saw that is 34" DIAM AND 9' long, and my skidsteer won't lift it.  I was hoping to use the loader.  Any thoughts???
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline IL Bull
  • Thank God I'm A Country Boy
Re: Wood-Mizer manual log loader
« Reply #1 on: March 28, 2006, 09:28:47 AM »
I built a manual log turner using a boat winch (1500# two speed with strap).  I made a frame and mounted it to the saw.  Works good.  Takes the work out of turning a log plus you have control for squaring up the log on the second slab cut.
Whoops,  I should have read the post better.  you said log loader.  Sorry.
Case Skid Steer,  Ford Backhoe,  Allis WD45 and Burg Manual Sawmill
Offline raycon
« Reply #2 on: March 28, 2006, 10:30:51 AM »
I have the hydraulic loader and the manual loader on the mill. Using the manual loader is time consuming but its worked
fine the times I've used it. Replacing the hand crank with a 12VDC winch would speed things up.  I use it mostly to pull logs to the mill at this time -- or to pull logs off a stack that can't be rolled off with a cant hook/peavy.
Lot of stuff..
Offline Bibbyman
    • Warden Sawmill
« Reply #3 on: March 28, 2006, 11:02:14 AM »
We had a manual WM LT40 for 7 years.  When we sawed mobile and had a large log to load wed just roll it up the rams using a chain looped under it and pulled by something like a PU from the other side.  Youve got two engineering principles working for you inclined plane and a gear reduction of 2/1.
I wish I had a picture to show you but its the same method used to load logs onto a wagon or truck before loaders were invented.
Sawing since '94
Offline stumpy
« Reply #4 on: March 28, 2006, 01:29:17 PM »
Thanks Bibbyman. I use that method(I think it's called parbuckling) all the time to load logs on my trailer.  What I haven't figured out on the mill is, how to attach the cable so I have the correct pull angles.
On my trailer, I have 2 side ramps. I loop a chain from the top of each ramp down to the ground. I then roll the log onto the loop. I then take my winch line over the log and attach it to the chain. It works great.  On the mill however, I don't see a way to run the cable up high enogh to accomplish this.
Offline ronwood
  • Enjoy Making Sawdust !!
« Reply #5 on: March 28, 2006, 01:52:00 PM »
stumpy,
Could make some ramps that could attach to the bunks and roll the log up the ramps using the forks on the skidsteer?  Problem would be holding the log when you need to get another bite on the log. Doesn't Woodmizer ramps for manual mills have some type of stop tha keeps it from rolling back?
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
For sale, Wood-Mizer LT-40 Manual
Started by slidecreekdan on For Sale
Last post August 06, 2008, 07:31:56 PM
by backwoods sawyer
Wood-Mizer LT 40 Manual Backstops -- FREE
Started by DR_Buck on For Sale
Last post February 13, 2018, 05:11:14 PM
by Steve83856
Wood-Mizer Manual tooth setter
Started by Jeff on For Sale
Last post April 01, 2012, 09:35:46 AM
by Ironwood
Wood-Mizer Manual Tooth Setter
Started by NMFP on Sawmills and Milling
Last post January 09, 2011, 11:31:05 PM
by paul case
