Author Topic: chain gauge  (Read 3167 times)
Offline tony_marks
chain gauge
« on: November 22, 2002, 05:20:34 PM »
 hey fellas ,im tony marks and am glad to be here.
my question is about gauge . i have 3 saws in the 50 cc range and the stihl 028is the only one with 63. i recently purchased an solo 667 at 69 cc. im thinking it has .50 gauge. this is my first saw of that size and im a little concerned with the chain holding togather.. ive never had any trouble with this but ive never had a powerhead this big either. i dont need it in the neck or where ever..
thanks a head of time. :)
Offline Seth
  • Keep the chips flyin
Re: chain gauge
« Reply #1 on: November 23, 2002, 06:08:13 AM »
Tony
50 gauge will hold,I have ran it on 066's with no trouble.I run Carltons A1 3/8 50 gauge on my 034 and 044 and have even ran it on my 120cc 22hp 088KD with no failure.Seth
Offline Kevin
Re: chain gauge
« Reply #2 on: November 23, 2002, 06:24:55 AM »
Tony,
I agree with Seth,  .050 will serve you well.
Re: chain gauge
« Reply #3 on: November 23, 2002, 11:05:39 AM »
I looked at that picture of Seth's and my mind read "Ethyl" instead of Stihl.  I was going to say something about Seth naming his saws and, in a split second, realized my error.  Kind of a neat concept though, eh Seth?   Have you named any of your saws? :D
Offline Kevin
Re: chain gauge
« Reply #4 on: November 23, 2002, 12:50:48 PM »
Tom, fess up.
Who is "Ethyl" , and why does she remind you of a chainsaw?   :D
Re: chain gauge
« Reply #5 on: November 23, 2002, 01:28:51 PM »
Ethyl was one "high testy" babe,  a real rip snorter, rippem-up but full of gas. :-/ :D
Offline tony_marks
Re: chain gauge
« Reply #6 on: November 23, 2002, 02:55:43 PM »
 thanks for the input fellas. i just didnt want to wear a saw chain as a necklace, when i go thru the pearly gates. :) i work solo so im careful, but wasnt sure about this issue. thanks again.
course theys nothin ever really sure doing his type work is there.
cept u sure better be careful.
Offline Kevin
Re: chain gauge
« Reply #7 on: November 23, 2002, 03:05:17 PM »
I use a .050 for milling and it holds up well.
If you break a chain it will usually come off the bar and fly out in front of you or down across the chainsaw chaps that everyone here wears. ::)
Offline tony_marks
Re: chain gauge
« Reply #8 on: November 24, 2002, 05:59:29 AM »
 this aint good but i see very few chaps around here.
think im going that route tho. ive hit my left leg many times and never really got hurt. mite be a different story with this bigger saw.
my experience is when im tired enough that the follow thru gets to my leg its past time to quit.ill be looking for a good set ,nothin fancy just enough to give the protection i need.
ps i have witnessed a saw cut. it opened it up pretty good ,and the strange thing is it took a while to start bleeding.turned out to be a serious injury.
Re: chain gauge
« Reply #9 on: November 24, 2002, 06:33:13 AM »
Yeah, and what a lot of people don't think about is that it cuts a trough that doesn't close up too good.   It looks just like the kerf it puts in a log but it doesn't take nearly as long.
When a chainsaw wound heals, if you're lucky, you're skin is a quarter of an inch shorter.  If you get a bone,  then so are you. :-/
I've been touched and know.  Hopefully never again, nor ever seriously.
Offline cluckerplucker
Re: chain gauge
« Reply #10 on: January 12, 2003, 12:48:19 PM »
speaking of chains can anybody tell me what degree angle to put on a chain to make it rip for a chainsaw mill?  Thanks cecil
cecil
Offline Kevin
Re: chain gauge
« Reply #11 on: January 12, 2003, 02:51:23 PM »
If you're talking top plate it`s 0 to 10 degrees.
Can I use .50 gauge chain on .58 gauge drive sprocket
Started by Greenerpastures on Chainsaws
Last post September 20, 2018, 03:19:45 PM
by Greenerpastures
Bar & chain gauge 0.050/0.058
Started by Allar on Chainsaws
Last post July 30, 2019, 07:27:11 PM
by sawguy21
.50 gauge chain on .058 bar?
Started by Steven A. on Chainsaws
Last post December 19, 2006, 07:53:29 PM
by rebocardo
.050 and .058 gauge chain
Started by snowshoveler on Chainsaws
Last post January 27, 2012, 10:42:00 PM
by Al_Smith
