Extreme DIY Flooring: Part 1
Started by Joel Eisner, July 06, 2006, 01:11:45 PM
Joel Eisner
As posted earlier today on our house blog www.boothemountain.blogspot.com
One of the common comments we get about our timber frame project is that it is off the charts regarding the way we are doing it. Some times we take the DIY thing a bit too far. We are about 1/3 the way through installing our Southern Yellow Pine plank flooring using cut nails and I think this is the case with this project. Here is Part 1 of the DIY process for wood flooring.
The flooring process started last September when we had Mr Gentry spend a day clearing a small section of land next to our house. It is the envelope of the next house. In a few hours he was able to do weeks and weeks worth of work that we could do with our chain saw and 1941 Farmall. All the logs were cut into 12-6 lengths and stacked. The trees are about 80 years old with minimal branches until you get to about 50 ft up. At the but end they were between 18 and 24" in diameter.
With the logs in one place we rough cut the flooring in two sizes (1 by 4's and 1 by 6's) to keep the installation a bit more sane. The cutting took several weeks working evenings and weekends. All the flooring was cut with our Lumbermate 2000.
We loaded the green rough boards into the solar kiln and stickered it (1x1 wood strips to help maintain air flow between the boards). This is the second charge for the kiln. The first was the roof decking which was dried down over the winter. It is amazing how fast and well it works. In January it was able to dry air dried (~16% moisture content) to 6-8% in one month. The temperatures were getting up to 120 deg F. This charge took a few weeks to get up to temperature since there was a lot more water to drive off but the temps were getting up to ~140 deg F during the month of June. We were able to take the wood from >30 % moisture content to 6-8% in a month. The kiln has no heat source other than the sun and it uses two attic fans to circulate the air. We are able to load about 1200 to 1400 board feet of wood into the kiln.
At the end of June we off loaded the kiln into the house to acclimate for a week and started to nail down the floor.
To be continued.....
The saga of our timberframe experience continues at boothemountain.blogspot.com.
ohsoloco
Nice write up  :)
Now where's part two  :D
Kelvin
sounds good.  Are you T&G ing them?  Is there another layer of flooring?  I'm coming in late here, but what is the second house you are clearing your land for?  Building two together?  Nice kiln.  Is it insulated?  How much do you imagine the energy requirement for drying the wood?  I ran two solar kilns for awhile, but figured the fans ate up a lot of elec over the 2 months or so.
Keep up the good work.
Kelvin
Joel Eisner
Hey Kelvin,
We cleared the spot next to the first building (carriage house/ apartment).  It is covered in the early posts of our blog.  The main house is supposed to be a 1909 Gustav Stickley designed house that we found in a plan book and then we hunted down the original plans drawn on linen in the Columbia Univ Rare Book Library.
The kiln uses $25-30 of electricity a month and is insulated.
The floor is not T&G but is being nailed over the sub floor (3/4 in T&G OSB nailed and glued to a conventional joist set up) with 15 lb tar paper between.
