Author Topic: Wanted - small diamater low grade walnut logs and pallet logs ...  (Read 2073 times)
Offline Wes Lyon
Hello everyone..
If anyone has any small diamater low grade walnut logs withinn 75 miles of Chillicothe, MO or have any timber (pallet grade logs) they need thinned please let me know.
Thanks...
Wes
Offline beenthere
Re: Wanted - small diamater low grade walnut logs and pallet logs ...
« Reply #1 on: August 03, 2006, 09:42:25 PM »
What is considered 'small' diameter?  Is it below a certain diameter, or within a diameter range?
I'm not within the 75 miles, but just interested in what you mean by 'small' diameter.   :)
Offline Wes Lyon
« Reply #2 on: August 12, 2006, 10:31:53 PM »
Normally it is the top end of walnut trees or walnut branches on larger trees or trees between 10-14" which will not make grade around here normally.
Is sawing low grade logs for pallet manufac. worth the money?
Started by Kelvin on Sawmills and Milling
Last post December 18, 2005, 10:56:25 PM
by FiremanEd
pallet logs for sale
Started by Grunex on For Sale
Last post November 21, 2011, 09:49:31 AM
by Grunex
How long can red oak grade logs sit?
Started by barbender on Sawmills and Milling
Last post May 20, 2018, 12:49:07 AM
by mike_belben
What is the Shortest length you cut for FAS grade logs
Started by Max sawdust on Forestry and Logging
Last post November 17, 2005, 08:10:18 AM
by Max sawdust
