Source for Phosphoric Acid or similar compound for acid dipping?
Started by LOGDOG, August 23, 2006, 06:42:10 PM
LOGDOG
Guys and Gals,
   I'm looking for a source for Phosphoric Acid or a similar type compound to be used for acid dipping and rust removal. I wondered if any of you have used this method and maybe had luck finding a local source for it from say one of the big box stores or chain type hardware stores? I've found plenty of sources online but thought maybe a local source could be found. Time to clean some tools and the like that moisture has gotten to here in the south.  ::) All help appreciated.  :)
LOGDOG
Left Coast Chris
I used muratic (not sure of the spelling) acid to remove rust................ got it from one of the paint chain stores.   Any painting store should have diluted acid to clean steel.... unless some regulation has prohibited it in the last few years.
If you can't find any acid......... I believe the automotive stores still cary navel jelly.....I used it to clean out the inside of a rusted gas tank....it worked great but for a big job it might be a little spendy since they seem to sell it in small amounts.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
tcsmpsi
All the time and for many, many years.
I get mine (OSPHO) from one of the local lumber stores, for what I use on 'rough' work.  Not what I use in the shop for firearms.
Usually in the paint section.  I posted something about this earlier in some thread or other.
It turns iron oxide (rust) into an inert iron phosphate.  Poof!  No more rust.
**just brushes on with a paint brush, or you can dilute it a bit and immerse smaller items**
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
LOGDOG
Great ...thanks guys. I had read that muriatic acid can actually encourage rust and turn the metal black. I'd like to avoid that. I'll check the lumber stores here and see what I can find. I'll post my results for anyone else interested.
Thanks again!
LOGDOG
Bro. Noble
We use an acid in our rinse water in the dairy barn.  It's supposed to 'put a shine' on stainless steel and glass.  I believe it is phosphoric acid,  but I'm not sure.  I'll look in the morning.  It is available at any store that sells dairy supplies,  but it may be too dilute for what you want.  We get it in five gallon buckets,  but it is also available in gallon jugs.  It's not very expensive.
Raphael
... he was middle aged,
and the truth hit him like a man with no parachute.
--Godley & Creme
Stihl 066, MS 362 C-M & 24+ feet of Logosol M7 mill
Beweller
Ammonia is not an acid.  It is an alkali.  It will not remove rust or form a protective coating on steel.
Hydrochloric acid (muriatic acid [spelling?])is good for removing rust, but the cleaned item must be washed thoroughly to remove all traces of chloride--which promotes rust.  For this reason, sulfuric acid (dilute) is often preferred.  There are "inhibitors" for these acids that reduce the attack on the base metal.
Glycolic acid is used in many commercial rust removers, and is less agressive towards the base metal than the mineral acids.
Beweller
brdmkr
I have a homemade electronic bore cleaner that uses a mixture of white vinegar and ammonia in solution with an electrically charged rod in the bore (a 9 v AC/DC power supply).  It really works well to clean up old militrary rifles.  I don't know what your intended use for the phosphoric acid is (how big your tools are), but you might be able to rig up a reverse electroplating rig to remove rust similar to the bore cleaner.  I know that archeologists use a similar setup when restoring iron artifacts.  If you are interested, the negative charge would go to a sacrficial piece of metal in solution with your tool (I use a 1/8"steel rod, not stainless).  This metal should not touch the tool.  The positive charge would go to the tool.  You have to use DC current as I have been told that AC current removes and then replaces the rust :o.  I don't know if that is so, but it seems possible.
If it is working, the solution will bubble when the electric is on.  If you decide to do this, post or PM me because I would really like double check on where you attach the electrodes (+ - configuration)
Lucas 618  Mahindra 4110, FEL and pallet forks, some cant hooks, and a dose of want-to
LOGDOG
Nope ...haven't tried ammonia. Let me tell you though ... today I found some Phosphoric acid at the big box store that sports the orange letters. Found it in the paint section with the alcohol and other solvents. It was about $13.00 a gallon. I bought 4 gallons and a new 5 gallon bucket to make a little dip tank. I had some long bicycle chains that had gotten corroded. I had used a wire wheel trying to clean them but even that wasn't able to get into all the nooks and crannys. The chains are about 80 feet long each +/-. I dropped the first one into the bucket, let 10 minutes go by and pulled it out onto my blacktop drive. I hit it with the water hose and it blasted the solvent and the majority of the rust off. It nearly looked brand new after just that first dip. I dipped one chain twice, the other three times and they're as good as new. After the dipping and rinsing was over I put about 2.5 gallons of diesel fuel and 1/2 gallon of oil in another bucket and dropped the chains down inside to soak overnight and let the oil get in everywhere it needs to penetrate.
  The acid dip was a life saver for the chains. I took a wide flat file that had rusted so bad that the ridges in the file had filled up with rust (thought it was ruined) and dropped it in the solvent for about 15 minutes. It came out clean as a whistle. Same thing with a wrench that had some rust.  :)
  I'm thinking I might have a new addiction. You can really pick up some neat stuff at the flea markets down here for pocket change. Knowing that I can clean metal this easily makes some of those antique trinkets even more appealing. I think I want a big dip tank now.  ;D
  One question I do have ... how do I get rid of the phosphoric acid in an environmentally friendly way when I'm done with it?
Thanks for the tips guys!
LOGDOG
Quote from: LOGDOG on August 24, 2006, 09:00:56 PM
............onto my blacktop drive. I hit it with the water hose and it blasted the solvent and the majority of the rust off. ........   One question I do have ... how do I get rid of the phosphoric acid in an environmentally friendly way when I'm done with it?
When will you be done with it?  When you run out of rusty things to clean up?  When you stop buying those neat rusty things?  :)  Or when the solution doesn't have any punch left?  I think keeping it on hand would be the best idea.
Either way, seems diluting it would be the way to dispense with it..slowly.  Same as what you did when rinsing the chain off in the driveway......as I would say that was enviromentally friendly. :)
LOGDOG
Uhhhhh ....errrrrr.....ummmmm ...  ::) Since you put it like that I'd have to agree. ;D
Actually I read an article that said after Phosphoric acid loses it's punch it's safe to use as a liquid fertilizer if you can believe that. I mentioned that to a chemical salesman today though and he said he had never heard of it. I'm sure his grade of phosphoric acid is much stronger than what I used today though. I'm curious, how long does the stuff keep it's heat? I have no probelm keeping it around for a while until everything is shiny. I can always run it down to the city dept that handles that I guess. At least to get rid of the bulk of it.
LOGDOG
Bro. Noble
I checked on the acid we use at the dairy----it is Phosphoric acid.  I'm not sure what the concentration is but it is specifically for use in cleaning milk lines and bulk tanks.  It (as all chemicals used in milk lines and tanks) is approved by the FDA and I'm pretty sure,  must be bio-degradable.  I think the gunk that gets disolved in the acid would be more of a problem.  If it were me,  I wouldn't lose any sleep over it.
tcsmpsi
Logdog, neither the phosphoric acid, nor its residual iron phosphate is detrimental to the environment.  Now, a high concentration of it in a particular area might keep rutebegas from growing, but I'm not convinced that is a detriment.
I am glad you found some.  If I would have had any smidge of doubt you would, I certainly would have offered to ship you some.  I've been using it on tools and equipment and metal roofs for about 25 yrs.  I've had it all over me, and am sure I have ingested some.
Though some might could argue that may have contributed to some mental deficiency, any of that was certainly a more natural process.   ;D
jkj
If you dilute acid with water before disposal, be sure to add the acid to the water.  Mixing acid and water releases heat.  Adding acid to water creates a very dilute solution initiallly and allows the heat to be released slowly.
If you pour water into a container of concentrated acid, the thermal reaction can explosively boil the solution and throw the acid into your face.  This may be undesirable.
LT-15 for farm and fun
LOGDOG
Thanks Bro. Noble, Tcsmpsi, and JKJ (everyone else too).
   I have to say, having the forum as a resource is like having the "phone a friend and ask the audience lifeline" on "Who wants to be a millionaire''. It's great to have such a collective wealth of experience close at hand - especially for a young guy like myself. :)
Thanks again.
LOGDOG
tcsmpsi
Logdog,
As far as how long it will keep, I've not actually found a 'cut off' time.  Only when the solution gets 'dirty' enough, do I change it out.  You can tell when that happens, as the process will slow considerably, and 'dirty' enough, will stop altogether.
It does put a whole new light on steel stuff, doesn't it?   ;)
I originally found it for refurbishing metal roofs.  Works well on new galvanized steel to paint, also.  In fact, it should be used on any of one's steel stuff before painting.  Makes certain there are no oxides underneath the paint and allows it to make an 'airtight' bond to the metal.
*One other little tidbit.  For immersing longer items, I use a long section of 4" pvc pipe, capped off on each end, and top of the pipe cut out lengthwise the length of the pipe.  I cut out boards for a base for the pipe to sit in (front, back and middle), and then cut a pipe lengthwise in half to use for a cover. 'Snaps' in place when you push it over the pipe in the stand.*
Kcwoodbutcher
Normally phosphoric acid does not degrade over time, only when it reacts with the items you are trying to clean.  Concentrated phsphoric acid (85%) will burn your skin due to the exothermic reaction with the water in your skin. As far as ingesting it- take a look at the ingredient label on a can of coke or pepsi.
My job is to do everything nobody else felt like doing today
LOGDOG, ya could try this method.
https://forestryforum.com/board/index.php?topic=6915.0
Cheap and effective.  Lota guys use the method to clean up old planes.
I've always heard that phosphates in fertilizer and laundry soap was bad for the environment, especially when it gets in streams and ponds promoting pond scum that robs oxygen from the water needed by aquatic life.
http://www.ec.gc.ca/WATER/en/manage/poll/e_plant.htm
tcsmpsi
The inert iron phosphate is a wholly different critter than the type and intent of phosphates used in fertilizer and detergents.   ;)
Been herbal and organic since long before I started using the solution and had studied it before applying it.  Been so long, I don't remember all the detail, but do remember that the iron phosphate was one of the few things approved for organic farming (which requires being environmentally beneficial).
Good for everything except rutebegas, of course.   :D
LOGDOG
I'm not sure if you read that thread that you linked SwampDonkey. Notice the comment it makes:
"But today, in many places, this process is tremendously accelerated by high concentrations of phosphorus and nitrogen (from fertilizer, for example) which enrich the water with nutrients, causing the aquatic plants to bloom."
   So in actuality the the phosphorous promotes growth in this case rather that hindering it. The reason that particular study wasn't crazy about it was because it was making algae in bodies of water grow out of control. If you've ever been around a lake that's overcome with weeds you can understand why. Plant growth out of balance is many times an undesireable thing.
  Tcsmpsi ...I'm glad  to hear you mention rutabagas. I thought only yankees like me knew what those were. Don't hear of many folks down hear using them.  :) One of these days I'd like to take a roadtrip over your way and see how you're coming along with your mill. ;D
LOGDOG
Quote from: LOGDOG on August 26, 2006, 09:28:34 AM
Yeah I did and it states what I said earlier if you read on. Not sure what point your making.
'As the plant growth explodes, it chokes off the oxygen supply normally shared with other organisms living in the water. When the plants die, their decomposition uses up even more oxygen. As a result, fish suffocate and die, and bacterial activity decreases.'
I've seen what fertilizer runoff does to brook trout in fish ponds. When algae scum grows, robs oxygen and your trout croke. Brook trout are more sensitive than rainbows.
LOGDOG
Logdog, I grow a batch of'em every fall down here in Fla.  Rooterbeggers is one of my favorite veggies.  Fresh ones are better than those big ol' waxed ones in the store, though I like them too.  Ya ever try the greens?  They're great when mixed with turnip tops or mustards. ;D 8) 8)
tcsmpsi
Yep.  Rootbeggers are just rusty turnips, for which I've always had a great appreciation.  ;)
Well, LOGDOG, you've got the talking part of the roadtrip done.  Look forward to it anytime.  Though, I am pretty much constrained to Sunday (ones I don't have class on) sawing at the present.  One never knows what tomorrow may bring, though.
tcsmpsi
Hey, LOGDOG!  It just dawned on me what you said you paid a gallon.
What was/is its brand name?  That's less than I've been giving the independent, and might be worth me traveling up the road to the 'orange lettered boxstore' (since I go up there from time to time anyhow).
Yup, I like those rootbulbs to, only we leave them for a hard frost to sweet'n their taste. Ones in the store harvested early are tasteless like poplar wood chips. mmm  ::)
LOGDOG
SwampDonkey ... I guess what I was initially wondering is whether the Phosphoric acid would "induce death" directly to say plants or animals if disposed of in diluted fashion to the ground. I'm very familiar with trout and their sensitivity. You can look at a trout wrong and they roll over on their bellies it seems. Love catching and eating them though. In that article it seems as though it were an overabundance of both life and death causing a depletion of oxygen in the water that actually was the casue of death (lack of oxygen) than say death by poison. It's a problem though in large agricultural areas where there is a lot of run off into the water shed from fields where chemical fertilizers are used.
Louisiana has to be one of the least environmentally friendly states I've ever seen though. After Katrina, the water in the streets of New Orleans was pumped back into Lake Ponchatrain. The people that had been wading through the same water had chemical burns on there legs and yet the WildLife and Fisheries folks say it's ok to eat the shrimp,fish and crabs that come out of the Lake? Hmmmm ... not me. I'll give it some time. I know the water had to go somewhere though. Perhaps there was no good solution given circumstances. ::)
Tcsmpsi ...I'll look in the morning for the name of that stuff. I think  it was Klean Strip if I remember right. We had a thunderstorm roll in otherwise I'd run out there and look. :)
DanG ...when do you put your beggas in? I think you and I are in the same hardiness zone. I've got plenty of good ground to grow some. We used to plant them up north all the time. The deer love them!!! I do too. Good in soups and pasties. Our Yooper friends can tell you about pasties. Down here they call them meatpies ...close but not quite like the pasties. I'll have to try the greens ...that will be a first for me. Deer can't get enough of them for sure.
LOGDOG
As with alot of this stuff, there is cause and effect relations. Alot of things happen in stages. Can't just look at the effect and not look back at or trace the root cause.
But, anyway the bottom line is that everyone has to be conscious of their actions. It hasn't been too many years ago that I saw farmers with the spray dripping from hoses/nozzles, streaming away from a parked sprayer along side a stream pumping water with a spray coted water hose dipped into the brook.  I also seen alot of water being pumped from a brook into a sprayer to flush it out and that flushed contaminated water run down hill into a brook or spring hole. The farmer just tossed his old emptied spray jug into a wetland or brush pile.  ::) No wonder there is hardly a brook trout left around here and I wouldn't eat any now if my life depended on it. And this has all changed in the last 20 years, but it's almost too late.
LOGDOG
Tcsmpsi ... I've got the name of that solution for you. It's made by "Klean Strip" and it's the "Phosphoric Prep and Etch"solution.
However, if you're looking to buy more than a gallon at a time for $13.00 a gallon I have a company here locally that sells it by the 50 gallon drum for $338.00 which is just under $7.00 a gallon. If you were going to use much over say the next year that would pay off with substantial savings. The company is Harcros Chemicals. Ask for Clay. He was the sales rep I spoke with. If we timed it right I could throw a drum in the back of my truck when I come visit. :) As long as you have your tractor or something handy to unload it.  ;)
LOGDOG
tcsmpsi
Thanks, LOGDOG.
You must be talking about those Natichoches meat pies.  A Rose by any other name.... ;D
Are you getting yourself a drum?    Hmmm...never tried, by I wonder if I bathed in it, it would take the rust out of my hair?
LOGDOG
Yep. I'll likely get a drum when my new shop is built. Tight on space right now but would love to have it on hand even if it is a chunk o'change to spend all at once on it. With that much though I could utilize a pretty good size dip tank.  ;)
LOGDOG
tcsmpsi
I've got a couple pretty good sized projects coming up for its use.  So, a drum or even half a drum (hint), most certainly looks pretty good.
LOGDOG
Gotcha ... thought about the half myself.  ;) Let me know when you're ready. No sense storing it until we need it right?  ;D
LOGDOG
tcsmpsi
Quote from: LOGDOG on August 28, 2006, 06:48:44 PM
LOGDOG
That rather depends on the price stability.
I'm ready whenever you are, and however we best need to accomplish it.  I'm adaptable (not adoptable).   ;D
