What kind of Cedar?
Started by Jeff, September 20, 2006, 12:40:41 PM
While over by the cranberry floodings I noticed a small lone cedar tree that struck me as looking quite different from the Northern White Cedar. The first thing I noticed was that it had no cones, all the other cedars in the area are loaded with cones. The second thing was the tree has a lacy more elegant appearance. More so then a Northern White Cedar. It also has a different twig. Could this be an Eastern White Cedar? Something else?  This tree certainly seems to be out of place.
Here is a side by side comparison with a Northern White Cedar on the right.
Quite certain it's the same species Jeff, the one on the right could be alot older. We thinned some cedar last month that was over 20 years old and 6 ot 7 feet high. The one on the left is probably younger and faster growing on a better microsite perhaps. They both look like our northern white. If you look up northern white cedar in the dendro texts I think it will call it thuja occidentallis. Atlantic white cedar is only on the coast and is a chamaecyparis or false cypress. I don't think it's eastern red cedar, a juniper species. Juvenile foliage is more prickly-like on the red.
There are thousands of trees around the area Donk of all different size and age. Since finding this one I have been a persistant observer looking for another like it. Not a one to be found. Its form standing is even different.  The tree is probably 16 feet tall
A couple of pics of the same tree for comparison.
Take a branch from each and smell it at the cut, should smell the same. ;)
Do a search on the wooly spruce, it's a black spruce, but different also. ;)
Link to the wooly spruce
When I get back up there I'll get another look as I go past this tree to one of my bait stations. Chet thinks you are probably right but is betting its s stump sprout with a ton of nutrients. It could be as its off the embankment of a two track trail. It could be coming up from a pushed over stump or something. I'll climb down there and check it out. :)
UNCLEBUCK
That stuff looks just like the arbovitae in the yard here ? really ! ???
If you have any dogs you keep in their own house, cut a few small bows and toss in on the floor to keep the flees out. ;)
Roxie
The lack of pine cones is interesting.  If you check it out again, and it has no smell, then it's a Leland Cypress.  They don't propagate so the only way it could have gotten there would be if someone tossed it out.  Perhaps it was a live Christmas Tree or something.  Given room to grow, they have a spectacular form and can grow 3 to 4 feet per year.
You're gonna have to smell that tree!   :D  The bark (if it's a Leland Cypress) would be fragile and skin like.
Say when
Quote from: Jeff B on September 21, 2006, 01:48:00 AM
They can also layer from a low growing branch and feed off the mother tree, or it could be coming off a horizontal windfall, where a lateral branch becomes verticle, then grows as a tree. Often there will be others growing with it.
