Can a Jin pole be used to unload a log truck?
Started by Modat22, September 25, 2006, 12:49:55 PM
Modat22
Not sure where this question goes so I'm sorry in advance.
I want to buy logs from a logger but I haven't got a way to unload them and was wondering if a jin pole could be made strong enough and fast enough to use for unloading? If so could someone point me in the proper direction for sizing them for maximum lift?
Sam
Kevin
Modat22
Quote from: Kevin on September 25, 2006, 12:53:27 PM
You need to unload them from the log truck?
Thats what I was told, I assume the they ship them out on standard flat bed with metal racks on the side. There is one guy close that has a truck with a grapple on the truck but he stays so busy I'm out of luck there. I've never purchased logs before and really don't know very much about the whole process. I'm trying to avoid cutting all my own trees to build a large wood shop.
Kevin
QuoteThats what I was told,
Was that directly from them?
Modat22
Yep. I called 6 last week and 2 called me back during the rain Saturday and told me that I needed a way to unload the trucks.
Originally I figured they could just drop them or something. Is this normal or do you think I'm getting my leg pulled or something?
Norm
Around here Sam most of the log trucks use a grapple that's mounted on the truck. Other parts of the country do things differently though. As for a jin pole I don't have the answer but my guess is you're going to have trouble getting them to unload that way at your place.
Modat22
When I began building my mill another mill operator told me that milling would worry me to death. I'm already getting there, the paper mill in the area seems to be buying up most of the lumber and loggers don't want to talk to me or I can get free logs but I can't load them on my trailer  :D
I need a few little helper tools, I might go visit the amish near me and see how they handle logs.
Murf
I would think it would have to be a pretty big gin pole, mounted on an even bigger tractor to tackle such a task.
I do it with my boom truck on occasion for someone I know, usually it's for unloading log length firewood. Is there someone you know in thearea with a boom truck or very big wrecker than can help you for a day?
Modat22
Nope, but I know a guy with a large wrecker I can pay for a few hours. Does the wrecker need to be higher than the log truck or will they let me drag them off the back of the truck?
Mr Mom
     Do you know anyone with a track-hoe that has a thumb on it??
     Thanks Alot Mr Mom
Modat22
Nope, I do know someone with a backhoe thats about it. He is usually busy as well keeping it working to pay bills. I pretty much have to do this myself, I was looking for the most cost effective way (I'm poor).
Thanks for the insights everyone, I need to examine another route or look further away for a logger.
Not seeing anywhere that the size of logs are mentioned.  8', 12', longer?  max diameter?
What type of truck? Regular log truck with only bunks?  Flat bed?
What about rolling them off onto ramps leading to skids?  A parbuckling setup to help if needed to get them rolling, if a couple guys with cant hooks won't do the trick.
What equipment do you have to work with? Tractor? Winch?
Modat22
I have access to 1 small, (2) 35 hp and (1) 45hp tractor with a front loader, two small 2000 pound winches.
I honestly can't say what type of truck these guys use, the log trucks I see normally in my area are just flat bed trucks with racks made from 2 or 3" pipe. I have seen a few standard flatbeds with no racks around.
white oak 10 to 13 inches is pretty common around me so thats what I'm going for.
Murf
According to the handy-dandy FF Toolbox log weight calculator thinga-ma-jig.........
A 10" White Oak log, 12' long would weigh a little over 410 pounds, and a 13" one would be tickling 700 pounds.
My little Kubota is a 45 hp model, and I sure wouldn't want 700 pounds too far up or out of the back.  :o
If they're not too lumpy or piled too high, you might be able to drag them off, but if you can't the driver's gonna be none too happy with you.  ::)
mike_van
Modat, i'd forget it - Unless you buy from someone with a real log truck with a knuckleboom loader.  They can unload  a full truck - 7 or 8 cord in about 10 minutes. No driver I know is going to sit there & wait while the logs get picked off with a chain &  bucket loader, or gin pole or whatever, it just takes to long.  Kind of like unloading a concrete truck into a wheelbarrow.  My 2 cents.                                                     Forgot to add - theres too much risk involved "rigging" something up. I know years back it worked, but lots of men were killed or hurt for life because of it. Find a trucker with a nice log loader -  :)
DR Buck
QuoteI can get free logs but I can't load them on my trailer
Check out this link.  You may get some ideas here.   I'm sure there are other post along the same topic lines, but I just don't know how to find them.
Log hauling Link
Ron Wenrich
We haul logs either on log trailers or knuckleboom truck.  If they're coming on trailers, the logs will have to be lifted over top of those pipes.  My bet is those pipes are 6" well casing.  We unload ours with a JD front end loader with log grapple.  It takes about 10-15 minutes to unload a trailerload.
Mike is right when he says the truckers won't wait for you to unload them.  Besides, if you don't have any experience unloading trucks, I'd advise against it.  I know a lot of guys that got hurt that knew what they were doing.
JimBuis
Modat22,
I think you could rig up some sort of stationary crane or tractor mounted jinpole.  However, to me there is a bigger question.  Even if you had the jinpole setup, how would you grab hold of each log? Tongs? But then the tongs wouldn't balance the load as you try to pick it up or drag it off the back.  You could try to wrap chains or straps around each log, but that'd be dangerous work and very time consuming.  As someone said, the driver won't like it much when it takes you an hour or two to unload his trailer.
Sounds like you need to either buy a grapple or begin scrounging stuff to make your own.  Do you have much old iron around to help manufacture something?  Maybe a double A-frame mounted on truck spindles and wheels to straddle the trailer and to pick up a log with two sets of tongs and use a tractor to pull the A-frame backwards off of the trailer to drop the logs.  Do you have several big oak trees conveniently situated just far enough apart for a semi to pull in between them?  Maybe build a crane outfit in the trees, but then the truck would have to pull out from under it to unload each log.  That would take a long time.
Anyway, unless you have some cash laying around for this, the job of building anything I can imagine would not be a weekend endeavor.
There's no easy solution I can think of.
Good luck,
Jim
Jim Buis                             Peterson 10" WPF swingmill
Stephen1
Chain the logs tight, Pull the pipes, & roll them off the side, put some blocking down the side of the trailer, so the logs do not roll underneath.
Modat22, I worried and cogitated about this very problem for a long time when I first got my mill.  I never did come up with a suitable method, even with the forklift.  The H-mobile would do it, but not quickly enough to suit a trucker.  Those guys get paid by the load around here, and don't cotton to being delayed.
My advice is to just be patient.  If you have a trailer, concentrate on getting logs you can haul yourself, until the logs start coming in on their own.  I did that at first, but now I rarely have to haul any.  People have found out they can leave logs here without having to pay dump fees, and I have more logs than I can handle. ;D
Mike-Van, "real" log trucks around here don't need self-loaders.  They pull into a landing, drop that empty trailer, hook up a full one and head for the mill.  A self-loader would be a waste of time around here. ;)
mike_van
I forgot the mill that used to be up the road from me [25 years ago] had a Pettibone loader - Good sized payloader w/forks & grapple - That would clean a truck or trailer off  in a few minutes - Right over the 12' pipes, pick 3 or 4 logs at a time.  Modat, what ever you come up with, try to keep the logs off the ground. Dragging or rolling them in the dirt of mud will cost you plenty later in dull blades.
Modat22
Hey guys thanks for the tips, I'm still looking around. I starting to panic a little, I'm trying to get enough material to frame up the biggest building I can before winter and let it stand till next year to finish.
I may try to build a grapple next year, I need to build a trailer as well, try to build a mini skidder and perhaps go fishing.
Then pay the lawyers fees when my wifes gets sick of never seeing me  :D
scsmith42
Sam, have you thought about approaching some local loggers with an offer to puchase based upon them unloading the logs at your place?  One of them may have a buddy with a large loader, grapple, or a trailer with a grapple etc.
Tom's 3638D Baker band mill
fencerowphil (Phil L.)
Hey Modat!
I puzzled, as DanG said, about this.   I realized, however,
that free dumping does have an appeal to the tree trimmers.
In rural KY that may not be an issue for them.  Don't live there.
Since you have a trailer and have  opportunities to go get logs,
you could upgrade your capabilities for loading  your own trailer.
The logs you seem to want are small, light items - at least in the
world of sawing.  A used grapple with your welding/fabricating skills and ...
Wah Lah! you are set to retrieve 'em!
For an example of how nice it could be, see the Blue Ox stuff advertised
to the left of this forum.  Also, there is always SawMill Exchange.com and Ebay!
With a combination of this small grapple of your own and waiting for
these free dumps,  you will gradually eliminate the option of the big trucks.
They will not be interested anyway, as has already been said.
One word:
I have no problem getting really big wood free.  My most recent freebees
include two Oaks that were in the 45" DBH category and weighed in the 5-ton
range. (Yep, that's why I love my Peterson Swingblade.)  If you can set aside
a remote acre for the dump point and team up with a Swingblade owner, now
that might be the ticket!  You cut the small, he cuts the big, and you get some
small percentage of what he cuts.  I would do it, but Georgia's too far a drive!
First, first, first...
Put the word out to the trimmers and the land clearers, clearly stating what
you are wanting.  You may get surprised!
Phil L.
Bi-VacAtional:  Piano tuner and sawyer.  (Use one to take a vacation from the other.) Have two Stihl 090s, one Stihl 075, Echo CS8000, Echo 346,  two Homely-ite 27AVs, Peterson 10" Swingblade Winch Production Frame, 36" and 54"Alaskan mills, and a sore back.
Oh, so you are in a time crunch, Modat22!
That's different.
I did several sessions of cutting in Mississippi after Katrina - a lot of it with Radar67.
[How ya' doin', "Stew?"]  One of my newfound friends out
there was a logger, complete with two sons and one son-in-law in the business, too.
Loggers all, now!  When one of the crews moves, its a big deal
Skidders, harvesters, service trucks, trailers, etc.
If you do like Brother SCSmith42 says, you may catch a crew on the move and get a
load. If you are in this much of a hurry, talk to the timber brokers, too.  The
demand for white oak is low right now,  you might get a load or two.  The trick will be
to catch that loader between sawing sites.
Phil L.
