Author Topic: Saw won't stay running  (Read 2769 times)
Offline JohnnyF
« on: October 16, 2006, 10:07:35 AM »
I have a Husky 55 rancher that is about 2 yrs old.  I don't cut a lot of wood but have not had one problem with this saw until yesterday.  It started fine, ran for a few seconds and died. I restarted it several times and it just won't run when I hit the trigger, it just dies.  So far it has been dissassembled and carb cleaned, muffler checked and new gas, twice mixed.  The H and L screws have been adjusted 6 ways to Sunday and it still won't stay running.  I'm wondering if the fuel line is partially plugged but if I choke it and start it, and play with the choke in and out a small amount, it will run for a short time before dying.  Any suggestions are welcome.  Thanks
Offline Tony_T
Re: Saw won't stay running
« Reply #1 on: October 16, 2006, 12:23:17 PM »
Put a little mix directly in the carb inlet, if it starts and runs a few secounds it indicates a fuel problem.
If so, check the fuel filter and fuel line, diaphrams in the carb that pump the fuel, and the vacuum hose that provides vacuum from the crankcase (cracks/leaks).
Offline twoodward15
  • turnersville NJ
« Reply #2 on: October 16, 2006, 12:39:18 PM »
Not trying to sound condecending, but are you sure you are adjusting the carb properly?  Next I'd check for loose/spongey fuel lines, then check the filter in the tank.  I just got done with a homolite that had the same problem.  Adjusted carb and it worked great........for a while, then the fuel lines went bad.  It is a saw that is about 10 years old, but only used once and left outside in its case until a few months ago.  I changed the fuel lines today and she runs great now.
108 ARW   NKAWTG...N      Jersey Thunder
Offline PineNut
« Reply #3 on: October 16, 2006, 07:00:51 PM »
I have a Husky 55 and have replaced more fuel lines than chains. I have heard that the new fuel lines are made of a different and better (?) material.  They do look different. The symptoms were the same as you are giving.
Offline jacob j.
« Reply #4 on: October 16, 2006, 10:56:23 PM »
Fuel lines are the number one issue on a Rancher 55 that has sat. It may also be the time to install a new carb kit, not just clean it out.
Offline SLOBuds
  • I Edited My Profile!
    • Huasna Huaffles
« Reply #5 on: October 17, 2006, 05:18:00 PM »
My Rancher has been a workhorse (for me, in my tiny 10 acre parcel!).  I've had it for 4 years never giving it a tuneup, or even a new spark plug.  I've never even messed with the adjustment screws.  The saw absolutely kicks bu** from my perspective and turns potentially long days into, well, much shorter.  Guess there are bigger and more powerful solutions, but the Rancher is perfect for my scale.
I bought a Husky pole saw, on the other hand, that has run less than 4 hours.  It always gave me trouble and finally was unable to hold idle recently.
I cleaned everything and gave up by handing it over to a mechanic.  One fuel line later the engine held idle and ran just fine.
Not sure why they are having so much trouble with the little fuel lines.
Martin
Offline PineNut
« Reply #6 on: October 18, 2006, 10:06:46 PM »
The problem with the fuel line is they probably wanted to save 2 cents so they went with the cheaper one. (Also means they can sell more of them.) I have been in the manufacturing area and have seen how they look at price vs quality.
Offline Al_Smith
« Reply #7 on: October 21, 2006, 11:29:20 AM »
 It's most likely a fuel delivery thing,carb or lines.
Offline dredgeslavedave
« Reply #8 on: October 21, 2006, 03:28:11 PM »
I think it is the fuel line as well. I bought two 3120XP huskys and both of them had bad fuel lines within a year. Husquvarna is starting to build a bad reputation one fuel line at a time. Your saws are only as good as the weakest link.
3 Alaskan's and a Grandburg mini mill. The newest addition to the family, Peterson WPF 8 inch with electric raising winch
Offline rebocardo
  • Atlanta GA
« Reply #9 on: October 21, 2006, 08:07:17 PM »
re:fuel lines
It might be the fuel available in the USA is not too kind to equipment using gas formulated to different standards.
Offline PineNut
« Reply #10 on: October 21, 2006, 08:36:24 PM »
If they are going to sell the saws in the US, they should be capable of working on the gas available here. They may have made the change as the last fuel line on my saw looked different than the previous ones.
Dozer won't stay running
Started by LeeB on Forestry and Logging
Last post April 03, 2012, 06:55:04 AM
by snowstorm
New Tanaka won't stay running
Started by aquacanis on Chainsaws
Last post December 06, 2011, 06:25:45 AM
by thecfarm
MS200T Won't stay running.......
Started by Bark Buster on Chainsaws
Last post February 18, 2006, 04:38:36 PM
by ehp
Husky 385 won't stay running.
Started by DR_Buck on Chainsaws
Last post December 01, 2007, 05:36:58 PM
by DR_Buck
