Author Topic: Is 1" axle big enuf for homemade band mill ?  (Read 10234 times)
Offline chainsaw_louie
« on: November 12, 2006, 05:45:04 PM »
Hi,
I found a 1" steel axle with a keyway in it - it came from a go-kart.  Do you guys think this is strong enough for a 13hp bandsaw mill?
Thanks!
Tim
Offline willknot
Re: Is 1" axle big enuf for homemade band mill ?
« Reply #1 on: November 12, 2006, 08:26:51 PM »
Hi Tim, 1" is definately border line i would think and alot depends on how you plan on mounting the bearings. You can probably get away with it if you mount a bearing on either side of your bandwheel giving the shaft maximum support rather than 2 bearings on one side. I have seen 1" used on homemade mills but not sure whether any of the manufactures use them on their smaller models. Price is definately right and 1" pillow blocks are reasonable also. I used 1 7/16 shaft on mine only because both bearings are one the same side and I got a smokin deal on them! I'm sure you will get mixed opinions on this and you just got mine. :D. Good luck!
Will
Offline mike_van
« Reply #2 on: November 12, 2006, 08:31:56 PM »
Tim, i used 1", they've been 15+ years now. What helps is next to no extra space on the axle between bearings.  On the drive side, the sheave is right up against the back of the housing, no overhung load.
Offline hookhill
« Reply #3 on: November 13, 2006, 12:08:14 PM »
We used 1" shaft on a Rake style saw and it has done fine. Have sawn 15,000 feet so far with it. Like the other folks mentioned, you dont want to much space between the bearing and your wheel.
Offline Modat22
  • I love my dog.
« Reply #4 on: November 13, 2006, 12:39:40 PM »
If you use a 1 inch axle support it really close to the connected load. Also those gocart axles aren't real hard.
I used a car axle from a junk rearend and supported it to within 1 inch of the load. I still visually inspect it each time I run it.
Offline jrokusek
    • DIY Bandmill
« Reply #5 on: November 14, 2006, 09:00:15 PM »
I did it too but haven't had much time to play with the mill yet.  So far so good.  If you run your mill all day every day it may not last long - if you "tinker" like me and don't cut often it may last.
I got some 1.25" shafting cheap and matching pillow blocks in case I get a wild hair and go bigger...which I probably will do.  Play safe!
Offline D._Frederick
« Reply #6 on: November 15, 2006, 12:16:45 PM »
A number of guy's here have had small diameter shafts break on their home made mills. For safety sake, I would like a shaft no smaller than 1 1/2 inches diameter if you are using cold roll. The other problem is that for a 1 inch shaft the bearings won't take the load.
« Reply #7 on: November 21, 2006, 11:08:55 AM »
Thanks fellas.  The comment about the hardness of go-cart axles does concern me, a pick up truck axle may be a better choice, it would have the hub already mounted on one end.  Also the issue of mounting the hub on the end if its not a standard size might take some machining which I dont really have access to.
Do you need to have a machinist turn down a pu truck axle in order to fit it in pillow blocks or are they machined to a standard size (1.5" etc) already.
Tim
Offline Larry
    • Copas Sawmill
« Reply #8 on: November 21, 2006, 12:58:33 PM »
D has a good point about bearing failure.  Kasco went from 1 1/2" axles to 2" for that very reason.  As a side note they turn the axle down to maybe 1 1/4" where the wheel fits on...canít remember the exact size.
Offline Modat22
  • I love my dog.
« Reply #9 on: November 21, 2006, 12:59:24 PM »
the car axle I used had to be turned down at the bearing journal 10 thousandths to fit my flange bearing 1-3/8" I think. Cost to have it machined was like 20 bucks.
Stihl 038 Super 18" bar not getting enuf oil
Started by dbholfo on Chainsaws
Last post November 23, 2014, 10:31:32 PM
by JohnG28
band mill homemade?
Started by beenthere on Sawmills and Milling
Last post May 23, 2006, 09:06:13 PM
by thecfarm
"Pith to the left" quarter sawing in a band mill
Started by Pabene on Sawmills and Milling
Last post July 04, 2018, 09:37:22 AM
by samandothers
Can band mill blades be run "backwards"?
Started by Joe Hillmann on Sawmills and Milling
Last post April 05, 2014, 10:20:04 AM
by barbender
