Dynamic Green Products Inc.
Author Topic: Curve sawing with Alaskan-type Chainsaw mill  (Read 1265 times)
Offline Nudgewood
« on: January 20, 2007, 11:45:43 PM »
Seems that a characteristic of Virginia pine is a curve in the first ten or twelve foot of growth. As most of what I'm sawing now is relativly small diameter, at least 70 % is curved. I thought I'd share some pics of what can be done to maximize yield.
First I nail a guide-board to one flat side and cut:
Then I roll the log ninety degrees so the curve is vertical and nail the guide-board to that side and crank the ends down so the board follows the curveature of the log:
Cut that side:
That opens the face for the saw to follow for the first board:
All four boards on the trailer, curve down same as they were cut:
They're all flat! I also sticker them in the stack curve down and once air-dry they're regular, flat boards.
One caveat though, there's a difference between a log with a curve and a log with a kink; a board with a kink will flatten but it'll still have a kink in it.
I hope someone finds this interesting and, who knows, maybe even useful.
Sumpin always depends on Sumpin.
Offline Nate Surveyor
  • If you like work, you will always be happy!
Re: Curve sawing with Alaskan-type Chainsaw mill
« Reply #1 on: January 21, 2007, 12:01:51 AM »
Ya know, I really think you are on the right track. This concept REALLY should be incorporated into bigger mills. A curved log follower. And it could maximize the yield. I want to figgure out how to install one on my Peterson... Dunno. But, it sure could help yields.
Nate
I know less than I used to.
Offline beenthere
« Reply #2 on: January 21, 2007, 12:26:18 AM »
Curve sawing is done in large production-mills now, I believe.
Here's one link
Curve sawing
Steep learning curve... anyone out there running a double-ended chainsaw mill?
Started by Wal Nut on Sawmills and Milling
Last post February 10, 2020, 06:50:30 PM
by BLink
Alaskan Chainsaw Mill
Started by sawinmontana on Chainsaws
Last post November 04, 2003, 01:22:55 PM
by Kevin
Granberg Alaskan Chainsaw Mill
Started by tyb525 on Sawmills and Milling
Last post August 27, 2008, 08:38:23 AM
by JV
Need help with chainsaw choice for Alaskan mill
Started by bornwithnoname on Sawmills and Milling
Last post January 22, 2015, 08:48:04 PM
by bornwithnoname
