Author Topic: Cleaning Blades  (Read 1326 times)
Offline Jacar
  • Psalms 1:3
Cleaning Blades
« on: February 19, 2003, 07:43:53 AM »
Hey Guys,
I am still new at this.  I was sawing some white oak the other day and before I could catch it I had a pretty big build up on the outside of the blade.  So I changed blades and set it aside.  I was able to adjust my lubrication and prevent anymore.
My questions is before I have the blade sharpened what is the best way to move the build up on the blade.  It is hard now.  What say you?
Jack
Jack Watkins
Offline Bibbyman
    • Warden Sawmill
Re: Cleaning Blades
« Reply #1 on: February 19, 2003, 08:06:52 AM »
Probably the easiest way would be to put it back on the mill,  tension it up and then run it with your water/lube flooding it.
Once clean, you may find it still cuts good.
Sawing since '94
Offline Mark M
  • Wilton, ND
    • Some of My Pictures
Re: Cleaning Blades
« Reply #2 on: February 19, 2003, 08:28:25 AM »
Easy-Off oven cleaner works well for my tablesaw blades and I don't know why it wouldn't work for bandsaw blades.
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
Re: Cleaning Blades
« Reply #3 on: February 23, 2003, 06:50:52 AM »
I would vote for:
Blade on make narrow cut ,mabey edging
If you mount 2 wire brushes on the mill, it cleans the blade as it turns.
Put them just before the driven wheel so the blade will be at its cleanest point.
My mill uses 2 ea.  1/2 brushes,  set together so they equal 1 thick.    Brass is nice also.
Align the brushes so they touch the body of the blade, and are  about 15deg. off from the blade (this makes the brush roll)
The brushes dont have to be opposite each other, just both sides of the blade (or just the outer side if you wish).
You may be able to do this with  Cup Brushes also.
Oh yea!
The sharpener in me said to say.
Putting blades aside when they have build-up on the blade will rust pit the blade and shorten its life.  Oaks as we know are the worst.
JIM
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
cleaning saw blades
Started by mooleycow on General Woodworking
Last post December 25, 2011, 03:34:09 PM
by D._Frederick
Cleaning saw blades
Started by D._Frederick on General Woodworking
Last post November 02, 2009, 05:43:08 PM
by johnjbc
Cleaning blades
Started by Rambjor on Sawmills and Milling
Last post February 10, 2020, 10:17:46 AM
by DDW_OR
Cleaning Blades
Started by MrMoo on Sawmills and Milling
Last post November 05, 2003, 01:27:41 PM
by bull
