Author Topic: Powder Post Beetles  (Read 3765 times)
Offline 333_okh
  • Got Wood
Powder Post Beetles
« on: February 14, 2007, 06:36:01 PM »
I have some rough sawn hardwood that was given to me that I need to go pick up.  Problem is htat some of it has the beetles in the outer sapwood.  Is there a danger that they will get into my other drying wood if I bring this onsite?
Re: Poweder Post Beetles
« Reply #1 on: February 14, 2007, 06:50:07 PM »
Yes.
It can be fumigated to kill adults but the only way to get rid of the infestation is Heat.  Putting it in a kiln or heat box such that the center of lumber reaches 130 and holding it there fo a while is the cure.
Offline 333_okh
  • Got Wood
« Reply #2 on: February 14, 2007, 06:53:22 PM »
great, not really what I hace access to right now.
« Reply #3 on: February 14, 2007, 07:17:22 PM »
well, I'm not sure where you are or the proximity of the new wood to the wood that you have stored, but keep in  mind that you are exposed to all of these insects all of the time anyway.  That doesn't mean that you can intermix the lumber and feel secure that you will avoid an infestation.  You might find a way to store it on your property where you can begin to control the maturity of the beetles and kill them before they leave to innoculate your other wood.   It might be as simple as wrapping the wood in plastic and setting off an insecticide bomb inside.  If it is truly sealed, the poison will kill adults, even those that hatch over time. The sun may get the wood hot enough to heat treat it this summer.
Don't give up unless it is just beyond your capabilities to manage it.  :)
Offline 333_okh
  • Got Wood
Re: Powder Post Beetles
« Reply #4 on: February 21, 2007, 12:59:31 AM »
The room I use to store my short lumber and turning blocks is 15 feet x 30 feet with a garage type door on one side and a regular door on the other.  It has a tight seal if the roof vent is closed.  I have a dehumidifier and a heating system in there.  I have everything turned off right now and I set off a bug bomb in the room.   I will repeat in a week and again in two weeks.
I have had some other insect species in the room and I thought I might have the pwder from the beetles near a scrap stack that I was waiting to be dry to use as firewood.
Any other ideas?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: February 22, 2007, 10:39:39 PM »
Remove the potentially infested wood if there is other valuable uninfested wood in the vicinity.
Offline 333_okh
  • Got Wood
« Reply #6 on: February 22, 2007, 11:44:09 PM »
I have, but I blew the fogger anyway.
I wonder if these foggers will work.  They are listed for a space twice the size of the dry shed.  I inspected all pieces (hundreds) of them and only found the one piece with any signs.  It was an edge piece of burl maple that was cut for turning wood.
Offline Justin L
  • Pouring Concrete!
    • Old School Lumber Co
« Reply #7 on: February 26, 2007, 08:35:03 PM »
The 130* will kill the adults AND the eggs. The eggs can hatch up to a year later if not heated. Just enough time to feel safe and build something and install it in someone elses house...
I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant! :)
Offline Don P
    • Calculator Index
« Reply #8 on: February 26, 2007, 10:32:47 PM »
The bug bombs will likely take you out long before they take out a ppb  ;).
Offline 333_okh
  • Got Wood
« Reply #9 on: February 27, 2007, 11:09:35 AM »
Fortunately this wood is all inspected board by board, but the potentially infected wood is still not with my current wood drying.  I just got worried and bombed the shed anyway.
Offline 333_okh
  • Got Wood
« Reply #10 on: February 27, 2007, 11:10:36 AM »
Help me on  the *130???
Offline beenthere
« Reply #11 on: February 27, 2007, 11:18:15 AM »
I suspect it is 130 F he's indicating.
(to get the degree mark, do an "alt 248" and the degree mark will pop up. Not sure what all the other codes are using the alt key, along with the number pad, but there are several).
A few others are
alt 171
alt 238   ε
alt 172
alt 169   ⌐
alt 155
alt 0190
alt 241
alt 64     @
alt 0134
alt 248
« Reply #12 on: February 27, 2007, 11:22:05 AM »
To kill powderpost beetle, the infected wood must be brought to a temp. of 130 or better for an extended period to kill the eggs laid in the egg chambers within the wood by the adults.
Those holes in the wood are created by adults as they leave.
http://www.powderpostbeetles.com/
For those who like to use characters other than on the keyboard, look in the area of the icons at the top of the page when creating a post.  There you will see a window made especially for you, called Special Characters.
Offline 333_okh
  • Got Wood
« Reply #13 on: February 27, 2007, 11:25:30 AM »
Thanks guys!  I think the wood will stay on the current site until/if I get a proper location to cook them.
None the less, my shop is clear of all insects now!
Offline beenthere
« Reply #14 on: February 27, 2007, 11:26:52 AM »
Thanks Tom
Learn more about sumtin every day here......... :)
Offline Ed
« Reply #15 on: February 27, 2007, 11:56:47 AM »
I just got my ppb infected ambrosia maple back from the mill, it went for a nice little "vacation" in their kiln. I've been watching it for a week now, with no signs of the little buggers.  ;D  8) ;D  8)  ;D  8)
Needless to say, it's not going to be stored in the firewood shed anymore.
Ed
Offline Justin L
  • Pouring Concrete!
« Reply #16 on: February 27, 2007, 09:17:12 PM »
Thanks for the tip! I didn't know how to do the deg mark. Actually, I still don't :( It doesnt work if I hold the alt key while I hit numbers, or if I press and release to hit the numbers. I never use the alt key, sooo what do I do?
« Reply #17 on: February 27, 2007, 10:19:46 PM »
Justin, read post #12.
Powder post beetles....
Started by Bill Ragosta on Drying and Processing
Last post October 04, 2016, 09:00:36 AM
by Sassafras73
Powder post beetles
Started by stumpy on Timber Framing/Log construction
Last post January 02, 2005, 07:38:47 PM
by Don P
Powder post beetles
Started by sunriseseamless on Sawmills and Milling
Last post October 25, 2008, 04:15:34 PM
by ljmathias
Powder post beetles
Started by Jerry on Sawmills and Milling
Last post January 09, 2015, 10:32:43 PM
by WV Sawmiller
