Effective signs?
Started by Jeff, March 27, 2007, 10:32:14 PM
Max sawdust
OWW, It took years for us to get rid of one or two " stubborn" ones.  The only way we did was to regularly use the parcel.
Joan,
The camera idea crossed my mind, I was afraid the whack that was tearing down the signs would have stole the camera.  So what were the cops doing on your land without a warrant? ???  Can they do that?
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
sprucebunny
Max, if you want to keep the bad guys off the trail, you have to let the good guys patrol it.
Max sawdust
I did not know they offered that service ;)  Our police barely have cars let alone Atvs.  ;)
max
True Timbers
There is a state police post in De Tour. One officer, one car.  He knows where a key is for the cabin. So far we have never had a break in knock on wood. We have however went up in the middle of the winter more then once to find his business card laying on the table.  He not only stops by, he comes in and makes sure the place is still buttoned up inside.  Of course this is with our full permission.   One car, one officer.  I ride down the road once on the quad without my helmet and he catches me. :D
Brings up a good point.....apparently there is a helmet law for the UP ??
All of Michigan. However enforcement on private property seems like it could get pretty sticky. I dont wear a helmet off road on my property.
It's the Law—Required Equipment
Before an ORV may be operated on any property, the operator is responsible for ensuring that the vehicle and its riders have the required equipment.
For Operators and Passengers
ORV operators and all passengers must wear a U.S. Department of Transportation–approved crash helmet and protective eyewear or goggles except when the ORV is equipped with an approved roof and the operator and passengers are wearing properly adjusted and fastened safety belts.
For Off-Road Vehicles
The ORV must be equipped with the following.
    * Braking System: A braking system in good working condition that operates by either hand or foot
    * Throttle System: A throttle system designed to automatically and immediately return the engine speed to idle when pressure is released
    * Spark Arrester and Muffler: A U.S. Forest Service–approved spark arrestor and muffler in good working condition, in constant operation, and meeting applicable sound-level standards (see Sound Emission Regulations)
    * Seating: Designed, manufactured accommodations for seating for each passenger
    * Lights: If operated during the hours of one-half hour after sunset to one-half hour before sunrise, the ORV also must have and display all of the following:
          o A lighted headlight
          o A lighted taillight
          o A brake light, brighter than the taillight
I don't get many trespassers, maybe 1 every 2 or 3 years. One guy left and old beat up axe and garbage bag on the trail. They were tipping and must have been a wet tip , because it rained after i was their in the morning and the next morning I found the evidence. And anther guy I walked up to as he was tipping my fir and lied about where he thought he was, and if he was were he thought he was, he was also breaking the law without a permit.  ::)
My trails are walking only, so I don't get many. Once in awhile someone will also venture in looking for moose. They can have all they want, but would be interesting getting it out.  ;D
Jeff, do you happen to have a definition of "approved roof"?
The buggies, jeeps and sand rails on the dunes have nothing but roll bars, and no one wears a helmet in them, so I assume a roll bar is approved.
I'm guessing it means factory roof.
Corley5
You're not required to wear a helmet in a vehicle such as a JD Gator that has a top speed of 25mph or less.
I would think it meant 'factory' as well.
That being the case, it's not being enforced by the state on the dunes.
bugmeist
I drove down from Ontario to Michigan a few years ago via Sarnia.  Saw a field on the Michigan side that was posted with signs that said:  "If I can see you- you're in range."    I doubt many tested whether it was tongue in cheek.
100 acres, Lucas 618, Universal Tractor w/loader, chainsaws, cant hooks and not enough time to play!
Fear is temporary...regret is forever.   www.bugshirt.com
My signs came in Friday. They look pretty good!  ;D smiley_smug01
I need one for butternut research.  :D :D
I need one for Poison Ivy research ;D.  Good looking sign, Boss ;).
Rokky Rakkoon
    i saw this one near Lanse, MI.
That one aint goona slow anyone down in our end of da U.P.  :D
Apparently none of my signs are effective to those that think a powerline right-of-way are public highways. I had a couple quads go right up through the middle a couple weeks ago mowing down the row of corn and sun flowers I had been cultivating. So, its time to seei if a fence will be effective. I'll have a 16 foot entrance for the power company around the end. I wont lock it until I'm given reason to do that too.
I'm harvesting Tamarack that were killed last summer by our drought. They should make a fine fence. I've been cutting a tree, then skidding with my beloved Logrite arch, then sawing material from that tree, the assembling fence, then cutting the next tree. I have the fence a little over half done and as of this morning probably have enough logs cut to finish. The fence is built in an arc for added strength so its taking more material then it might have it were straight.  I'll add further strength with the old stop sign posts I have driven in on an angle as anchors for support cables attached to the fence.
Mooseherder
I see you put Pete to work. ;D
It is pretty sad when people don't know how to read or blatantly disregard others property.  >:(
You need one of these. ;D
I want one!! 8) 8)
Loaded up for work tomorrow. :)
isawlogs
 Thats gonna be quite a nice fence , you going to cut out the little spruce trees on this fence too ???
I had a guy go and turn in my hay field here this summer while I was putting up private road signs  ::)  He was looking for a road that showed up on his GPS that has not been for at least forty years a public road . I asked him if it was the hay bales ... the gate he went through or the grass growing in the field he did not see .  ::)
  His GPS was telling him where to go ... I also told him where he could be going .  ;D
   Marcel
Mooseherder
Marcel,
He didn't see the sign that said no GPS. ;D
isawlogs
Maybe I should get me one of those  :D :D
Some are so oblivious to there suroundings when they get here it aint funny . They relye on the GPS so much that they dont see the CUL DE SAC  signs , two of them ... You tell them they need go back and turn left at the stop sign cross the bridges and turn left again ....
They dont recall crossing no bridge .. or train tracks or turning off the pavemant  but where not coiming from Vermont , well we have a problem here , that or ya might want to share some of the smoke  :D
   Marcel
crtreedude
Just catching up a bit here Jeff.
One thing I let people know in the area is that I don't mind them fishing in the rivers (it is the law here that they can) but I do mind if they cause any damage, or leave any trash.
Someone once saw my bow and asked a worker "Does Don Fred hunt?", the answer came back "You, if you tresspass..."
We don't have any signs, everyone knows where our properties are since we maintain our fences.
We also have people who live on the fincas full-time, which helps a lot.
So, how did I end up here anyway?
