Handy things around the mill
Started by Bibbyman, July 01, 2001, 12:41:27 PM
Brucer
That'd be Razor-Tip, aka, stellite. In short, a very expensive mistake.
By the way, stellite blades will not saw off the side stops. I tried it once, with a brand new out-of-the-box blade :(. Didn't get any further then I did with a plain ol' Double Hard.
I feel your pain.
Bruce    LT40HDG28 bandsaw
Nomad
Quote from: WDH on May 28, 2013, 09:25:43 PM
With a Razor-Top blade  :).
     Not any more, it ain't. :'(
WoodMizer LT50HDD51-WR
Lucas DSM23-19
It is now a razor-untipped blade :).
Yup, there is not much that you can do about those screw ups except to claim um, wear um and share um. ;D
JohnM
Quote from: Larry on May 27, 2013, 03:38:52 PM
But no more...the See All mirror knows.
That's pretty neat!  Personally I would nerd-out and refer to as The Eye of Sauron. :)
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
OneWithWood
One With Wood
Kbeitz
I am now building my first band saw mill ... After reading the last couple post I think I'm going to
make a carriage stop if the dogs are to high for the blade to clear. I'm thinking this should be easy to do.
If a adjustable stop arm was put right in front of the blade guide it would hit the dog before the blade.
If the stop hits the carriage will stop or push down the dogs. What ever take the least effort.
I made all my dogs lay down the same way the carriage travels.
Love machine shop work
and Wood work shop work
And now a saw mill work
justallan1
Kbeitz, look on the EZ Boardwalk mills, they have them. It's a piece of square tubing that comes to a point that hangs below the plane of the blade and on the top of the stops there is a piece welded on that it catches onto. Pretty slick idea, for sure.
Kbeitz
Quote from: justallan1 on April 30, 2015, 08:50:47 PM
Thanks... I will check that out...
