Author Topic: Found a mill  (Read 1930 times)
Offline John_Haylow
  • "If you are going through hell, keep going." W.C.
Found a mill
« on: May 24, 2007, 06:44:43 PM »
Well I thinkI  finally found a good used mill, its a 2004 LT40HD with just over 800HRS on it. I will be picking it up at Woodmizer in Manilla  tomorrow. The fellow I purchased it from had a problem with the accuset board and had a new one so Woodmizer installed it today.
I have been looking for some time and looked a number of mills before finding this one. It also has autoclutch, lubemizer and a debarker. I will read up on posting pictures and try and post some.
John
2004 Wood-Mizer LT40HDG28
Re: Found a mill
« Reply #1 on: May 24, 2007, 06:47:18 PM »
congratulatios, John.  That's a fine machine.
Offline LT40HDD51
  • WM Sales & Service for N.S., N.B., P.E.I., NFLD., custom sawmilling in Atlantic Canada
    • Valley Custom Lumber
Re: Found a mill
« Reply #2 on: May 24, 2007, 06:49:19 PM »
Way to go, John. Tell Dave Ian says hello  :)
The name's Ian. Been a sawyer for 6 years professionally, Dad bought his first mill in '84, I was 2 years old :). Factory trained service tech. as well... Happy to help any way I can...
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Found a mill
« Reply #3 on: May 24, 2007, 07:03:57 PM »
Congratulations on the new mill! Sounds like a nice setup.
Dave
Offline Kevin
Re: Found a mill
« Reply #4 on: May 24, 2007, 08:35:37 PM »
Congratulations, Dave will treat you good, tell him Kevin from the Sault said hello.
Offline Bibbyman
    • Warden Sawmill
Re: Found a mill
« Reply #5 on: May 24, 2007, 10:17:53 PM »
What Tom said.....   ;D  8)
Sawing since '94
Offline thecfarm
Re: Found a mill
« Reply #6 on: May 25, 2007, 10:02:45 AM »
John,good for you.Do have have logs on your land to saw?Going to do some custom sawing?Have building to build at your place?Pictures might be hard the first time,but we are all here to help you.Best thing I've done on here is learn how to post pictures.Have fun.
Offline John_Haylow
Re: Found a mill
« Reply #7 on: May 25, 2007, 09:19:25 PM »
Thanks everyone for your replies.
Ian and Kevin, Dave says "hello".
"thecfarm" Yes I do plan on building a sawmill shed from trees on our property. I will also be looking at doing some custom work.
I won't forget the pictures.
John
Found a New Job on My Mill
Started by just_sawing on Sawmills and Milling
Last post January 07, 2007, 11:07:08 AM
by leweee
I think I found the First Band Mill
Started by jimparamedic on Sawmills and Milling
Last post March 01, 2013, 01:51:01 AM
by Satamax
Found my grandfathers mill!
Started by Wallee on Sawmills and Milling
Last post March 24, 2017, 08:03:18 PM
by Wallys World
Information help about a mill found for sale
Started by slider on Sawmills and Milling
Last post January 17, 2012, 08:36:43 PM
by slider
