Author Topic: 3 point tiller  (Read 2542 times)
Offline johncinquo
  • Oh Boy A place to cut up!
    • My Pictures
3 point tiller
« on: June 08, 2007, 01:14:03 PM »
Looking to buy a 3 point roto tiller.  4-5 foot.  My tractor is 35 HP.  Close to MI to pick up.
To be one, Ask one
Masons and Shriners
Offline olyman
Re: 3 point tiller
« Reply #1 on: June 30, 2007, 06:06:01 PM »
they are ebay quite often---
Offline Quartlow
  • Amuture Sawer, master wood destroyer
Re: 3 point tiller
« Reply #2 on: July 10, 2007, 02:50:30 PM »
Look for a Howard rototiller. My brother has a 50 inch one that he runs on a Case VAC. It does a GREAT job
Breezewood 24 inch mill
Have a wooderful day!!
Offline maple flats
  • Life is what you make it!
Re: 3 point tiller
« Reply #3 on: August 16, 2007, 08:29:38 PM »
Yes, Howard Rotavator is good. I have a 42" and my brother has a 60" both of which I run with my 25HP tractor. On new ground the 60" is a little too much but on tilled ground it does good. The 42" does good on both new and tilled ground. Howard are heavy enough to hold up for a real long time. I bought my 42" about 20 years ago at auction for $225 because the shaft wouldn't turn. I applied oil to the outer input shaft daily for a few days and then hooked it up and tried it. It worked and I have never needed a new bearing. All I have done is 2 or 3 sets of new tines which are available easily from any farm supply thru JS Woodhouse. I used so many tines because I tilled for about 15 years doing gardens in the spring for folks and tines are a common wear item. But you do get several hundred if not thousand hours on a set. Rocks seem to wear them the fastest and eventually break them after worn too much. I'm talking rocks that throw the several hundred pound tiller jumping up and down as you till over them.
logging small time for years but just learning how,  2012 36 HP Mahindra tractor, 3point log arch, 8000# class excavator, lifts 2500# and sets logs on mill precisely where needed,  Peterson ATS upgraded to WPF mill, maple syrup a hobby that consumes my time. looking to learn blacksmithing.
Offline Quartlow
Re: 3 point tiller
« Reply #4 on: September 09, 2007, 12:19:50 AM »
We had a 13 footer at the sod farm when I was kid. John Deere would sell us tractor but wouldn't warrenty it if where going to use it. Ended up with a 1570 Case. We chisel plowed everything first but it still made the old case snort once in a while
Offline johncinquo
    • My Pictures
Re: 3 point tiller
« Reply #5 on: January 09, 2008, 03:01:52 PM »
TTT
Spring is just around the corner.  Hey its my world, let me dream in it.
To be one, Ask one
Masons and Shriners
3 point hitch Rotory Tiller
Started by Qweaver on Wanted
Last post February 16, 2007, 12:14:52 PM
by Qweaver
When your tiller won't start...
Started by Dave Shepard on General Board
Last post May 20, 2007, 08:07:43 AM
by Don P
Tiller's International
Started by thedeeredude on General Board
Last post July 12, 2008, 09:06:03 AM
by Fla._Deadheader
Tiller Springs
Started by Fla._Deadheader on Wanted
Last post February 10, 2010, 05:55:29 PM
by SwampDonkey
