Dynamic Green Products Inc.
Author Topic: Nyle 200  (Read 1579 times)
Offline Raider
  • The one that pulls the bow, knows the arrows path
Nyle 200
« on: June 09, 2007, 07:31:07 AM »
The son found a used Nyle 200 in Arkansas! So we left his place in Ill. and drove down to Little Rock first nite, then to the yard site,about hour. Picked up the Kiln, loaded and tied down and headed back to Wisconsin. The unit looks in very good shape 8). Took off the sides and blew out any dust etc. from the fins. Wiped down the fan blades, and put the sides back on! :) :) We wii be installing in a 26' freezer trailer. Plan on going to Maine this fall, will have to stop at the plant in Bangor.    Raider
Offline TexasTimbers
    • Dovetail Spline Jig
Re: Nyle 200
« Reply #1 on: June 09, 2007, 05:32:09 PM »
Cool. Show some pics of your first load when you get her full of goodies.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Re: Nyle 200
« Reply #2 on: July 02, 2007, 12:21:03 AM »
Raider,
Congrats on the new kiln unit.   I think you'll find the Nyle very dependable.  I have the Wood-Mizer version that Nyle builds and it is installed in an old truck box.   Unfortunatly I had to add insulation.  Aside from the kiln unit that was my biggest expense.
Here is the link to the unit I built.   Maybe you'll get a few ideas on putting your's together.
DR Buck's Kiln
One thing I did and I'm glad I did it is build the controller 'in to' the kiln.   It is protected from the weather and sun and it keeps it from freezing in the winter.
Hope your box has hinged doors.   Mine didn't.  It was a roll-up and I had to remove it and make hinged doors.
Good luck on your's
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline Raider
Re: Nyle 200
« Reply #3 on: July 04, 2007, 07:24:09 AM »
I checked on the doors of the box, they are hollow core, filled with foam ins. Rubber seals on all three doors. Have to mount fans from ceiling yet and install unit. Need to get a lab oven for samples also. Thanks for all the help :) :) 8)  Raider
Nyle L50 vs Nyle L200
Started by nanook on Drying and Processing
Last post October 21, 2007, 08:55:24 PM
by David Freed
Nyle L33?
Started by oakiemac on Drying and Processing
Last post December 11, 2004, 05:38:29 PM
by oakiemac
Nyle L 53
Started by Downhill Cutter on Drying and Processing
Last post May 19, 2019, 02:44:28 PM
by Downhill Cutter
Nyle l3
Started by Ricker on Drying and Processing
Last post March 05, 2018, 12:00:58 PM
by K-Guy
