Author Topic: Glue  (Read 1030 times)
Offline Tom Sawyer
    • Tom Sawyer Sawmill
Glue
« on: July 07, 2007, 05:08:21 PM »
On my Woodmizer the little blocks that go under the blade guide roller (I forget the technical term :P) sometimes come unglued.  The first time it happened they told me just to glue it.  I have been experimenting with different kinds of glue and so far the best that I have used for this job is called Gorilla Glue.  It seems to hold at least as long as whatever Woodmizer uses ;D.  What kind of glue do the rest of you use?
Offline hiya
  • life is short, I have too much to do till its over
Re: Glue
« Reply #1 on: July 07, 2007, 07:25:57 PM »
One thing, make sure you have all the old glue scraped off. Epoxy may work.
Richard
RichardinMd.
Offline Leatherneck
Re: Glue
« Reply #2 on: July 08, 2007, 10:58:24 PM »
Not much that Gorilla Glue won't do.
Offline LT40HDD51
  • WM Sales & Service for N.S., N.B., P.E.I., NFLD., custom sawmilling in Atlantic Canada
    • Valley Custom Lumber
Re: Glue
« Reply #3 on: July 08, 2007, 11:30:21 PM »
Ive used a 2-part epoxy, the kind that comes in a big double syringe. Seems to work good...
The name's Ian. Been a sawyer for 6 years professionally, Dad bought his first mill in '84, I was 2 years old :). Factory trained service tech. as well... Happy to help any way I can...
Can you use calking glue to glue logs together?
Started by Rod on Timber Framing/Log construction
Last post February 28, 2005, 10:45:59 AM
by Rod
Glue up
Started by stumpy on General Woodworking
Last post May 15, 2019, 02:08:17 PM
by Larry
Which glue?
Started by Brad_bb on General Woodworking
Last post January 01, 2012, 08:34:09 AM
by SwampDonkey
Glue????
Started by Jno wood on Timber Framing/Log construction
Last post May 01, 2018, 09:24:04 PM
by Brad_bb
