Author Topic: Calling all weldings :)  (Read 5388 times)
Offline Paul_H
Re: Calling all weldings :)
« Reply #20 on: September 13, 2007, 04:53:25 PM »
Kevjay,
those hinged jigs look like they would be the Cat's pajamas!
eg  tregar  meste  på  Tulla, for  ho  var  krulla  i  ulla.
Offline TexasTimbers
    • Dovetail Spline Jig
« Reply #21 on: September 14, 2007, 12:55:09 PM »
I don't know of a faster way. About 3 seconds to trace the pipe and 15 seconds with a cutting torch if you are slow, and you are ready to weld.
Offline rebocardo
  • Atlanta GA
« Reply #22 on: September 14, 2007, 08:24:25 PM »
I guess it comes down to how much you want to invest in tools. I have a bi-metal (use lots of oil) hole saw set for 3/4"-4", a joint jigger (sort of expensive), and 12 ton tube bender.
If you want to do it cheaply and still have a fairly nice fishmouth, get a compass, draw your circles on cardboard, cut out, transfer to your tubes with magic marker. Then get a skill saw with a METAL blades (the ones at Home Depot are okay) and cut them out (slowly). Just make sure the blade does not hit the inside of the pipe. If the blade is too long when the Skill saw is in the extended position, just cut the blade end off until it fits inside the pipe, IF it can't fit though both sides at once.
A 6" metal blade should be fine though if it is 1/8" mild steel tubing.
Offline Furby
  • Blurb....
« Reply #23 on: September 14, 2007, 08:32:02 PM »
You mean a jigsaw or saber saw right?
Offline sbishop
« Reply #24 on: October 18, 2007, 03:04:15 PM »
Got my gate all welded up, works GREAT!!!!!
Sbishop
Offline rebocardo
  • Atlanta GA
« Reply #25 on: October 18, 2007, 03:06:36 PM »
You could call it that too.
Offline rebocardo
  • Atlanta GA
« Reply #26 on: October 18, 2007, 03:10:03 PM »
Might want to paint it bright orange so noone rams it, kind of matches the background.
Looks like a nice patch of land there!
Offline sbishop
« Reply #27 on: October 18, 2007, 03:22:09 PM »
Rebocardo, you would have hit the chain that is at the beginning of the field first... :D
on the main road you must turn right into an old field, I have a chain setup there for looks, once you cross the field and head towards the woods, my gate is in the middle of the hill.
But I do plan on painting the gate, just not this year  :)
Offline olyman
« Reply #28 on: October 19, 2007, 01:08:53 PM »
  take the pains, and notch out the tubing, and it'll hold up to climbing and driving the truck into it :)   and you know this----how????????????? :D :D :D  i thought gates were for holding animals in ---not trucks!!!!!! :D :D :D
calling
Started by coxy on General Board
Last post April 05, 2017, 09:53:05 PM
by Magicman
Calling on Land
Started by terry f on General Board
Last post July 31, 2012, 12:13:28 AM
by tyb525
calling logger 88
Started by snowstorm on Forestry and Logging
Last post January 03, 2015, 07:36:15 PM
by outlawcowboy
Calling Dr.Roof
Last post May 06, 2004, 05:23:48 PM
by Tom
