Tally-I/O
Author Topic: bar for husky 372  (Read 5600 times)
Offline DonT
  • Lifes rough wear a helmet
bar for husky 372
« on: November 30, 2007, 12:35:20 PM »
I am looking at purchasing a 36" bar for my 372,i found one at bailey's but it is a 0.063 and not the regular0.058 I am currently running.Both chains would be 3/8.my question is can i run this longer bar and chain combo on my husky without changing the sprocket?  Thanks DonT
Offline SawTroll
Re: bar for husky 372
« Reply #1 on: November 30, 2007, 01:07:37 PM »
Yes, you can - but a 36" bar on a 372xp is waaaayyyy too much........ :-X
Information collector.
Offline Kevin
« Reply #2 on: November 30, 2007, 01:21:02 PM »
Don, the pitch is the same at 3/8" but the groove must match the drivers on all chains.
You couldn't run a .058 chain in a .063 bar groove.
If that's what you mean?  ???
Offline DonT
« Reply #3 on: November 30, 2007, 10:01:11 PM »
Thanks Kevin.To clarify my post,I am looking at the larger bar with an 0.063groove and  a matching chain.I do not have a whole lot of use for a bar this large but I do run into the odd maple that i would like to make a little lighter for disposal.   DonT
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #4 on: November 30, 2007, 10:19:47 PM »
Don
The 372 wont have much if any power to run a 36 on it cutting full length. I like the saw had one of the first ones that came out years ago. Still have some of them. But a i run a 36 on a 394 and feel that it really would be better with a 30 inch bar.
I think that you will be unhappy  with that saw and bar combo in hardwood.
dale
Game Of Logging trainer,  College instructor of logging/Tree Care
Chainsaw Carver
Online sawguy21
« Reply #5 on: November 30, 2007, 10:35:33 PM »
I liken it to hooking a fifth wheel travel trailer to a 6 cylinder half ton. It will hook up, it can be done, just don't ask it to go far.
 As has been said, changing the gauge will not affect the drive sprocket. The Husqvarna 365 and larger all use the same bar mount. You can use a shorter bar and work from both sides rather than over load your saw with that long (and expensive) one.
Offline rebocardo
  • Atlanta GA
« Reply #6 on: November 30, 2007, 11:19:21 PM »
If I was going to run a 36" bar on a Husky 372, for chain I would go with 3/8 x .050 and full skip, 30 rcs, from Baileys with a matching (and much cheaper) sprocket nose .050 bar.
Offline Cut4fun
« Reply #7 on: December 01, 2007, 06:42:16 AM »
If you are running a 8T rim with your short bars, I would switch to a 7T for your longer bar. I wouldn't go over a 28" myself on a stock 372, but if you are cutting softwoods have at it.
I put a 32" with skip on my MS361 once during testing cuts in softwoods and it did fine for the occasional cutting if had to.
Offline TexasTimbers
    • Dovetail Spline Jig
« Reply #8 on: December 01, 2007, 02:19:47 PM »
I put the 36" bar that came with my 395XP on my 372xp with the modded muffler full skip. It did not like it. It cut withoiut bogging too bad but you coukdn't lay into it like I like to do. I agree it is too much bar for the 372 and the 372 is my favorite saw.
The oil is all in Texas, but the dipsticks are in D.C.
Offline Captain
« Reply #9 on: December 01, 2007, 05:05:09 PM »
I think I staill have a GB 44" bar that will fit, .058 that I got on closeout.
Price is $88 and certainly 10% to the Forestry Forum.
Captain
« Reply #10 on: December 01, 2007, 07:09:04 PM »
28" is what i like to rujn on mine.
Offline DonT
« Reply #11 on: December 01, 2007, 09:50:00 PM »
Thanks for the replies guy's.I do relize that this is a very large bar for this saw.It will probably see very little use.The reason i even considered it was a bar and chain of this size was cheaper than buying a new saw that would see little use.As I said i was hoping it would make the couple of cuts a year that i seem to run into.I usually run 18's on most of my saws and quite like them.   Thanks again
Online sawguy21
« Reply #12 on: December 01, 2007, 11:36:09 PM »
I had a customer request a 48" .404 bar for a 395XP, :o Well o.k. buddy, if that is what you really want go for it but you bought it you own it.
« Reply #13 on: December 02, 2007, 09:52:55 AM »
Sawguy a 395xp will handle a 48" bar no problem. Full comp. Stock. I ripped oak crotches with a 50" bar, 0 full comp 3/8. While I would like to have had more power it did the job without too much trouble. But I have never run .404 maybe you are saying that is asking too much from that saw? I would think it ought to handle cross cutting though.
Maybe there is alot more difference in the power needed to pull .404 than 3/8 than i can imagine.
Offline SawTroll
« Reply #14 on: December 09, 2007, 04:39:33 PM »
That is a bit much as well, unless you use skip chain, imo...... ;)
« Reply #15 on: December 10, 2007, 10:18:59 AM »
Without the modded muffler it is definatley a little much but the extra ooomph I got from the opened muffler makes it acceptably mariginal most of the time.
In hardwoods that take most or all the bar, it is too much, and 24 is probably the max I should keep on it mod or no mod. So I would tend to agree with you even though I like to run the 28 because that 24 seems to be just a bit short alot of the times.
Offline SawTroll
« Reply #16 on: December 13, 2007, 07:28:53 PM »
Forgot to say, with a stock 372xp I would say that 20" is max with an 8-pin, and 24" with a 7-pin, unless you use skip chain.
16" and 8-pin is really cool!!!!!  8) 8) :D
Online sawguy21
« Reply #17 on: December 13, 2007, 11:07:08 PM »
The 24" is very common here on the 372 with full comp chain in softwoods although some run skip. We see little hardwood harvested commercially.
« Reply #18 on: December 14, 2007, 12:15:34 PM »
Mine handles a 24" like a dream.
Offline minesmoria
« Reply #19 on: December 25, 2007, 03:11:36 PM »
I have a 372xp with  28" bar full skip with muffler mod, i  cut two to three foot round logs no problem.
I have 7 pin sproket!
Husky Prestique 61 (1980) Vs Husky 562XP
Started by Mikeinkaty on Chainsaws
Last post June 13, 2016, 06:09:49 AM
by SawTroll
Husky 353
Started by Woodcarver on Chainsaws
Last post January 06, 2005, 09:17:51 PM
by Woodcarver
Husky 372 vs. 575
Started by Cedarman on Chainsaws
Last post May 20, 2005, 07:41:06 AM
by David_c
Husky 575 ???
Started by Blue Duck on Chainsaws
Last post September 26, 2006, 04:28:46 AM
by SawTroll
