Dynamic Green Products Inc.
Author Topic: Cotonwood as Posts and Timbers  (Read 3598 times)
Offline clif
  • " All we lack's finishin up"
« on: December 26, 2007, 10:19:41 PM »
I have a friend who has several large (28") Cottonwood trees that we bored to see if and how much center rot there is and it appears it is minimal and only very close to the center of the tree if any.  My question is if I were to saw 8-10" timbers/posts and not box the heart/rot would they be fairly dimensionally stable  as they dried in place or would I have a "can of worms"  so to speak?  I am adding a 20'x24' TF livingroom/artic entry to an existing building and I really like the looks of cottonwood.  Clif
Mighty Myte Mark IV Band Saw Mill .  " Don't let the past hold you back"
Offline BandsawWarrior
    • T&N Custom Sawmill - Specializing in Premium Fir Products
Re: Cotonwood as Posts and Timbers
« Reply #1 on: December 27, 2007, 12:34:37 AM »
Sometimes what we do is cut timbers one to two inches oversize, sticker them, forget about them, and then resaw them after a hot summer.  We're produced some of our nicest wood this way.  Now I've never tried it with Cottenwood, but if you have time maybe it's worth a try.
Tyler Hart
T&N Custom Sawmill
Offline iffy
« Reply #2 on: December 27, 2007, 09:25:02 AM »
This is second-hand info, but a local sawyer says when local farmers want to build a pole barn and bring him cottonwood to make the dimension lumber out of, he waits to saw it until they have the poles in the ground and are ready for it. He claims if he cuts it any earlier, it will try to tie itself in a knot. He tells his customers to take it home and nail it up immediately, and it will dry straight enough for a pole barn. A lot of old barns in the area are built with cottonwood, and old timers say after it gets completely dry it turns really hard. Don't know any of this for a fact, just repeating what I've heard.
Can put you in touch with a local guy who milled square beams and built a dovetail log home. He hasn't mentioned any problems with excess warpage, but I think he stacked it green.
Online Gary_C
  • Sunrise on the Prairie
« Reply #3 on: December 27, 2007, 10:12:40 AM »
Cottonwood logs start to rot before they hit the ground. Overall very poor rot resistance.
It will stink when you saw it and will stink any time it is rewetted after drying.
If you keep the heart centered in the boards or timbers and sticker it immediately after sawing, warpage is not that big a problem. However some boards will warp no matter what you do.
It has very poor nail holding abilities. Reason is because it is very prone to collapse in the wood around the nail or bolt and then the nail will fall out or the hole will enlarge around a bolt. That problem is especially bad where the wood is subject to wide temperature variations and the resulting condensation on metal parts.
So cottonwood needs to be dry before using. Do not use it anywhere next to the ground and only use it for non structural uses. I would not use it anywhere it could not be easily replaced or use it only for short life applications.
Other than that, it will work good.   ;D ;D
Offline Justin L
  • Pouring Concrete!
    • Old School Lumber Co
« Reply #4 on: January 01, 2008, 09:46:37 AM »
I can't say about the timbers, but I have 500' of 4/4 Cottonwood kiln dried & still on sticks. from what I can see, it looks OK with minimal warping. I'm going to plane it & finish the inside of my kiln office with it. If it's good enough for a pole barn, it's good enough for my office :) It is a pole barn, actually...
I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant! :)
Offline JGroebner
  • Rebuilding History
    • Terrasol
« Reply #5 on: January 01, 2008, 05:29:54 PM »
I personally would NEVER use cottonwood for Anything structural.  It's light, not very dense and therefore WEAK.  Bugs LOVE it because it's easy chewing.  It has a lot of the same properties of drift wood.
Jared
Offline Furby
  • Blurb....
« Reply #6 on: January 02, 2008, 12:18:29 AM »
Driftwood can be most any kind of wood, and is not a species. ;)
Offline clif
« Reply #7 on: January 02, 2008, 12:50:11 AM »
Not looking very good for the cottonwod is it?  I was thinking that cottonwood had similar strength properties as spruce.  I guess I will look it up again, although  I don't remember where I found it last time.  O well, back to the drawing board.
Offline beenthere
« Reply #8 on: January 02, 2008, 01:38:55 AM »
You can find clear-wood strength values in the Wood Handbook, and get an idea what the relative differences are between species, assuming the quality of the beams/posts are similar.
http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr113/fplgtr113.htm
Go to Chapter 4
Cottonwood is about 10% lower than Sitka spruce...but may yield higher quality.
Have no idea what driftwood properties are... ::) ::) ??? ??? :)
Offline Thehardway
  • Doin' it the hard way!
« Reply #9 on: January 02, 2008, 07:41:16 AM »
The properties of driftwood are as follows:
Strong enough to bust your bottom unit or prop.
Burns well in beach fires, good for hot dog roasting an d marshmallow toasting
Holds sand and gravel well
Difficult to finish and machine, with a tendency to splinter
Dulls tools quickly
Range is widespread along coastal areas
Availability is good especially after storms, flooding or hurricanes
Uses:
Popular for landscape, yard and wall decoration
burled peices can sometimes be turned into bowls
Norwood LM2000 24HP w/28' bed, Hudson Oscar 18" 32' bed, Woodmaster 718 planer,  Kubota L185D, Stihl 029, Husqvarna 550XP
Offline submarinesailor
  • LT15 and a wife of 45 yrs
« Reply #10 on: January 02, 2008, 08:04:05 AM »
Hey Hardhead OH, I mean HardWay is this saltwater or fresh water drift wood??? ;D ;D ;D :D :D
Offline Furby
  • Blurb....
« Reply #11 on: January 02, 2008, 01:16:15 PM »
Yep, those are two different species aren't they Sailor. ;)
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #12 on: January 02, 2008, 02:21:34 PM »
Check out my new post about driftwood......
Offline HOOF-ER
« Reply #13 on: January 02, 2008, 10:09:34 PM »
I asked a relative of mine about cottonwood and building with. He said come here want to show you something. Took me to the basement pointed at the floor joists in his house and said that they were all cottonwood. What I know is keep it  DRY. Rots quickly when wet. Doesn't hold a nail as well as other woods. Crappy studs from the lumber yard don't hold a nail well either!  ;D   IMHO cottonwood would be as good nailing as that stuff they call pine studs.
Home built swing mill, 27hp Kawasaki
Offline JGroebner
    • Terrasol
« Reply #14 on: January 02, 2008, 10:49:26 PM »
WoW I didn't think a reference to driftwood wood be so "colorful".  Our neighbors to the west in S.D. are plagued with cottonwood, it's light, it's molecules when viewed through a microscope almost seem misplaced.  It's like driftwood because it's brittle, it's light, it's lost it's identity ;D
Jared
Offline tsodak
« Reply #15 on: January 04, 2008, 09:29:38 PM »
I don't know, may be in the process of learning a hard lesson, but no sign of it yet.
The one wood we have in mass quantities is cottonwood here in SD. I asked many of the same questions a year ago, and got just as variable of answers, so I just did it.
Cut posts 8x8 and 6x6, happy with both. The building I am using them in has no floor, so generally easy to replace if they rot off, I put them wrapped in plastic into very sandy dry solid and built a 12x36  lean to barn out of 100% cottonwood. Rafters, purlins, board and batten siding, trim, everything. I am almost finished with the siding, but need to put the battens on. All in all it was the funnest building project I have ever had.  I thought it worked well, and I will treat it with spray on sealer or more likely just used oil mix sprayed on. It does have a steel roof, so every piece that is exposed to weather is vertical. I figure worst case if the posts rot off, I can dig and pour a concrete base to bolt the pole to, and if the walls don't last I can always pop it off and put steel on the walls.
I am happy enough that I am making plans and gathering logs to move on to the 40X40 stick framed garage and shop I  have always wanted. Plan to start digging footings in June. Going to mainly saw it as I build it. But will precut, sticker and stack a bunch of 2x6's for the walls in the spring. I just overbuild it all. If I could get by with a 2x4 I use a full dimension 2x6. Size everything up.
Go for it.
Milling and using oak posts/timbers
Started by IowaAl on Drying and Processing
Last post July 19, 2016, 11:55:45 AM
by Roy Beauchamp
Milling own timbers vs ordering timbers from a sawmill
Started by Joe Vachon on Sawmills and Milling
Last post July 03, 2017, 12:45:18 PM
by thechknhwk
question
Hardwood timbers vs. Softwood timbers
Started by jeremy86 on Timber Framing/Log construction
Last post September 23, 2016, 09:01:22 AM
by Heartwood
Dam Timbers, I'm Done
Started by bugdust on Sawmills and Milling
Last post February 15, 2011, 06:09:59 PM
by petefrom bearswamp
