Dynamic Green Products Inc.
Author Topic: Need advice in picking reasonable saw mill.  (Read 7774 times)
Offline Norwiscutter
  • Have a nice day!
Re: Need advice in picking reasonable saw mill.
« Reply #20 on: January 26, 2008, 12:05:43 PM »
I like the idea of setting up the swinger on a trailer just like a portable manual mill. Push feed is no problem, and need to turn the logs would be greatly reduced. Harold is saying that it would run on an angle iron track right? What about making any necessary modifications to the sawing unit it self?
Si vis pacem, para bellum.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #21 on: January 26, 2008, 03:16:32 PM »
 I believe all you have to do, is provide the room under the blade to swing it.
  An ATS or the Lucas, would both run on the edge of the angle, just fine.
  Might have to have some sort of walkway while pushing the carriage. It's GOT to be equal to a band mill set up ???  ???
Offline Ianab
« Reply #22 on: January 26, 2008, 06:55:08 PM »
You would want to use a WPF saw unit if you were running it on a trailer mount or home built rails.
With the ATS or Lucas the rails move up and down to adjust the height of the saw, so they are a major part of the mills operation.
With the WPF all the saw mechanism is on the carriage and you can set up the rails lo-lo and could use just about anything. It's about as complicated as a railway track ;)
Cheers
« Reply #23 on: January 26, 2008, 07:31:45 PM »
 Ahhhhhhhhhhh
  I'm used to the adjustment on the carriage, and, forgot about adjusting the rails  ::) ::)
Offline ErikC
    • Erik Cordtz Enterprises
« Reply #24 on: January 27, 2008, 01:20:36 AM »
  If a peterson was set up on angle iron tracks, I'd think if the iron was rough, as it often is, it would wear out the nylon wheels pretty fast. Any one have experience here? It would be an easy and cheap way to put some tracks up behind the house for those jobs where a carriage-bed alignment was important. Resawing comes immediately to mind. probably a lot of uses.
Might make a pretty wide trailer though.
Erik
Peterson 8" with 33' tracks, JCB 1550 4x4 loader backhoe, several stihl chainsaws
« Reply #25 on: January 27, 2008, 08:30:29 AM »
 Bet I could sand them smooth in an hour.  ;D ;D ;D :D :D
Offline Nate Surveyor
  • If you like work, you will always be happy!
« Reply #26 on: January 27, 2008, 01:10:04 PM »
If I wanted to go with iron tracks, I suspect that changing to metal wheels would be in order too.
N
I know less than I used to.
Offline TeenSwinger
  • Like cutting big logs
« Reply #27 on: January 27, 2008, 08:34:12 PM »
  I have a setup at the house for stationary milling so i don't have to unload my tracks and all every time.  I just run my peterson on some angle iron and i just have the nylon rollers. I have cut maybe 50mbf and have not replaced them yet. Metal wheels would not be a bad idea though. The thing with the angle iron is that if you want to cut longer logs it just cost about 80$ to cut 20 more feet. :) :)
Jacob
Peterson ATS 827  Nyle L200  Ebac 800  Bridgewood M-562
Offline ErikC
« Reply #28 on: January 27, 2008, 10:38:38 PM »
 Jacob, that's good to hear. What size angle iron did you use? Maybe a picture? I've been thinking about doing the same thing. I think changing to metal wheels is alright if your not using the aluminum rails anymore, otherwise you'd want to go back and forth. Those Peterson rails are a little more expensive than $80 for 20'.
Erik
Offline alsayyed
« Reply #29 on: January 28, 2008, 10:47:57 AM »
 I thank you very much and I appreciate yours replies. I have checked the prices on Peterson and Lucas saw mills I have found out that they are expensive to purchase. I know I have read about these two saw mills
And found out that they are great and easy to operate but like I said it is rather expensive for me. I will stick to my chainsaw milling and in the mean time I will think of a way or invent a way how to mill logs. So I thank everybody.
« Reply #30 on: January 28, 2008, 10:52:08 AM »
I was in that same predicament. So, I bought a USED mill. Now, when you get it, it will probably be out of adjust, and need a few parts. It is really nice to START with it in perfect tune.
But, a good used one is what I did.
Nate
Offline alsayyed
« Reply #31 on: January 28, 2008, 11:18:33 AM »
thank you Nate i wish if i can find used one, at in good condition and it is been used without mecry
Offline nsmike
« Reply #32 on: January 28, 2008, 04:30:02 PM »
Just an idea I read on an Australian woodworking website. This guy was useing his chainsaw mill to break a log into small cants and then resawing the cants into boards on a large bandsaw. I bet a large bandsaw would be easier for you to find then a used sawmill.
Mike
« Reply #33 on: January 28, 2008, 05:32:07 PM »
Here's one on the Peterson Web site:
2001 8" 25hp Kohler WPF
Includes: 2 x Peterson six tooth blades and 2 x Pacific Hoe eight tooth blades.
Condition: Been setup inside since brought, professionally tuned, approx 1000 hours.
Price: US$13,500
Jeff Moffatt - Ph 613 269 3900 oremail Jeff
Mill is in Ontario, Canada
Then there is this one on Ebay: 110218429211
You probably already saw those, but all sawmill prices have got higher in the last 2 yrs.
N
Offline nsmike
« Reply #34 on: January 28, 2008, 08:51:16 PM »
I got tp thinking that a picture might help. This link is to a company that sells resaw blades for normal woodshop type bandsaws. the picture shows it in action. http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=1293
Mike
Offline TeenSwinger
« Reply #35 on: January 28, 2008, 08:58:32 PM »
  Erik, I am just using 1/4 in. 2x2 angle iron that is bolted to a 3x5 block of wood.  Right now I am set up with two twenty foot sections so i can cut about 35 foot.  I am working on a picture, I got dial up. :(
Jacob
Offline Ianab
« Reply #36 on: January 28, 2008, 10:09:58 PM »
A manual bandsawmill isn't really difficult or expensive to build yourself. Several guys on the forum have built their own. Most of the parts should be available locally, use car wheels and tyres, a basic industrial 4 stroke engine, threaded rods, bicycle chains etc.
Keep the chainsaw mill to break down big logs into 1/4s or cants that you can move to your bandmill.
You would still have the issue of sharpening your blades, you may have to get your own sharpener as I doubt anyone local will do it and you are going to NEED sharp bands for your logs. But s/h band sharpeners are around.
Cheers
Offline ErikC
« Reply #37 on: January 28, 2008, 11:42:02 PM »
 Well I guess you could just keep your eyes open for a used one you like and keep chainsawing for now. There are lots for sale here in the US, but I doubt as many where you are. I've known people to get used manual band mills for around $3,000. There's a few homebuilt swing mills on the FF as well. Hope you don't get discouraged and give up to soon.
Erik
Paranoid or reasonable to lock up a portable mill overnight
Started by chainsaw_louie on Sawmills and Milling
Last post September 11, 2012, 11:53:00 AM
by MartyParsons
Picking Up New Mill On Friday
Started by wwsjr on Sawmills and Milling
Last post May 13, 2013, 08:17:00 PM
by francismilker
Picking up my fist mill
Started by crosswind on Sawmills and Milling
Last post February 13, 2018, 08:51:31 PM
by WV Sawmiller
Help needed picking a mill
Started by timjab on Sawmills and Milling
Last post May 02, 2010, 08:39:47 PM
by jfl
