Tally-I/O
Author Topic: 18 or 25 Inch Woodmaster  (Read 11493 times)
Offline sawwood
Re: 18 or 25 Inch Woodmaster
« Reply #20 on: February 16, 2008, 08:00:21 PM »
 David as i see the photos of your set up, you only use the power feeders to move the
 wood threw the planer. What i was going  for was i have a lot of lumber with bark on
 the edge so a fence as your may not work. I was going to put a rail across the out feed
 table and just below the table face and make two L shape brackest i can move in or out.
 these L bracket will be just in front of the blades to guide the wood. if i help the wood into
 the planer and my son on the out feed i think i can make stright cuts. This way i can cut
 a lot of the lumber into size and remove the wayne edge. If it evers warms up i am going
 to make this set up and see how it works.
 Lester
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline David Freed
    • Simply Affordable Cabinets
« Reply #21 on: February 16, 2008, 11:05:11 PM »
I think your idea should work for what you are wanting to do. It sounds more like an edger saw to me. Are you going to run the lumber through before or after you dry it?
woodmaster 25 inch planer
Started by woodmills1 on General Woodworking
Last post May 17, 2009, 06:35:46 AM
by woodmills1
10 inch X 4 Inch beams Coastal Douglas Fir
Started by ultraglide62 on Drying and Processing
Last post June 11, 2012, 10:36:24 AM
by metalspinner
Mortising 8 inch x 8 inch hardwood posts
Started by christopherw on Drying and Processing
Last post December 22, 2008, 07:55:28 AM
by Meadows Miller
31 inch to 25 inch Western Red Cedar on the Manual LT 35
Started by Ruffneck on General Board
Last post March 16, 2017, 02:50:23 PM
by Ruffneck
