Author Topic: Bandsaw Blades  (Read 2885 times)
Offline Andy Harden
Bandsaw Blades
« on: May 06, 2008, 10:05:09 AM »
Has anyone heard of a band saw blade with less than one tooth per inch. That would make a rougher but faster cut.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Bandsaw Blades
« Reply #1 on: May 06, 2008, 11:04:26 AM »
woodmizer has recently come out with a 1 1/8" tooth spacing:
http://www.woodmizerblades.com/bladeTypes/raiseTheBar.aspx
lots of dull bands and chains
Offline beenthere
Re: Bandsaw Blades
« Reply #2 on: May 06, 2008, 12:10:18 PM »
Andy
I'd be interested to hear what the logic is behind the "rougher but faster" cut....can ya tell us more?
Offline Andy Harden
Re: Bandsaw Blades
« Reply #3 on: May 07, 2008, 08:56:27 AM »
Andy
Well I was looking at the small band saw ion my shop. The less teeth on the band the faster cut in the same type wood. I also noticed the cut was less smooth.
On my band mill I have tried some 7/8 by 1.5 blades and they do not cut as fast as the one inch pitch. I think my logic is kinda fuzzy but it just made me think less teeth might drag more saw dust. My neighbor is running a 52 inch round mill. The tooth spaceing is over an inch. Big chunks of saw dust and a fast rough cut.
Offline Dan_Shade
Re: Bandsaw Blades
« Reply #4 on: May 07, 2008, 09:06:08 AM »
my understanding is that it will take more HP to pull a band with less teeth through the wood, but you may have a bigger gullet to get rid of more sawdust.
Offline Dodgy Loner
  • Forester
  • It's an anagram for "dendrology" and in no way a reflection of my personality
    • My Blog: A Riving Home
Re: Bandsaw Blades
« Reply #5 on: May 07, 2008, 04:31:16 PM »
The bigger gullet is the key.  Once the gullet fills up with sawdust, it's no longer cutting effectively.  The same principle applys to all sawblades, including circular saws and handsaws.
Offline Andy Harden
Re: Bandsaw Blades
« Reply #6 on: May 07, 2008, 05:44:15 PM »
Well I have a 51 HP CAT® Diesel Engine. If I run out of power I have a Volvo diesel out of a passenger car. I think it has a lot more power. It is a Turbo charged 4 cylinder.
I just thought it might be a good alternative to my present blades. With the exception of the Wood Miser blades I haven’t heard of anything else like that.
Offline Mo
  • Sponsor
  • Wood-Mizer Blade Sales
Re: Bandsaw Blades
« Reply #7 on: May 07, 2008, 06:14:25 PM »
Hello gents, your thoughts so far are correct. With the wider tooth spacing you need a higher horsepower unit.
The 51 Cat is fine. The wider the spacing the more gullet capacity to remove the sawdust as mentioned,
which in turn allows faster cuts. 8) My personal experiance in poplur, red oak and hard maple is awesome!
One thing to remember regaurdless of your blade profile, always saw as fast as you can and still keep a strieght cut.
This will give you longer blade life.
Offline Dan_Shade
Re: Bandsaw Blades
« Reply #8 on: May 07, 2008, 10:28:10 PM »
Mo, welcome to the FF, and thanks for sharing info with us.
what is your minimum horsepower recomendation for the 1 1/8 blades?
also, figuring out drive speed is one of the harder parts of learning to saw, do you have any pointers on  how to run the "saw as fast as you can and still keep a straight cut" ?  That sounds simple, but it's really not for a lot of us.
Offline Mo
  • Sponsor
Re: Bandsaw Blades
« Reply #9 on: May 09, 2008, 10:12:23 AM »
Thank you. Well you have nailed me! Your power feed speed is determined by so many things as I'm sure you know. So to give a actual concrete awnser, I'd be telling a lie. I listen to my blade and watch my cut. The blade will all most "sing" when you have the correct speed. It is something you learn on your own machine in time because each machine is different.
As far as the minimum horsepower, nothing less than a 42 horse because of rim speed.
Offline HUMS MILL
Re: Bandsaw Blades
« Reply #10 on: May 09, 2008, 04:41:17 PM »
Fellow nail cutters
 Got a 1 1/8" tooth space blade from WDMIZER. Great blade. Cut hickory ,red oak, and 3 yr old hemlock with it. Stayed true. I have 40 hp diesel on LT40hd. Need to get it sharpened a few times to see how long it takes to break. I tried some 1 1/4 x 55 deg blades, they worked good, but 2-3 sharpenings they broke. Use RESHARP.
  Gotta go, have logs on deck AND a Honey do list ::)
                   Hum
question
Bandsaw Blades - Who sends sample blades to try out?
Started by Ozarkian on Sawmills and Milling
Last post April 01, 2012, 06:50:08 PM
by Magicman
No name bandsaw blades
Started by cloair on Sawmills and Milling
Last post January 08, 2008, 04:46:45 PM
by SAW MILLER
Bandsaw blades
Started by beerguy on Sawmills and Milling
Last post September 03, 2003, 06:26:44 AM
by woodmills1
Bandsaw blades??
Started by woodland84 on Sawmills and Milling
Last post February 07, 2020, 03:57:23 PM
by goose63
