Dynamic Green Products Inc.
Author Topic: bearings  (Read 2140 times)
Offline D Martin
  • Work is always interfearing with my playtime
bearings
« on: June 19, 2008, 05:07:55 AM »
Hi just a quick question. How often do you guys grease the pillow block bearings on your sawmill's  band wheels? I just had one fall apart on mine. Ill buy 4 new ones from linn sawmills, but the guy I bougt the mill from said once a year was about right. Im sure hours on milling is the right formula to decide ,so how many hours
Offline Woodchuck53
Re: bearings
« Reply #1 on: June 19, 2008, 05:53:18 AM »
Around here we give a squirt daily. It keeps the grease worm satisfied and cut's out the down time changing them out. Just enough to see it start to ooze. CV
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
Offline bandmiller2
Re: bearings
« Reply #2 on: June 19, 2008, 05:56:13 AM »
D Martin,kinda depends on the load and speed.A little grease often is better than alot once a year.High speed pillow blocks don't want to be stuffed full,let the bearing tell you take a large screwdriver put the handle near your ear and the bit agenst the bearing.Give it a little grease slowly when it quiets down quit, be carefull.Slow bearings such as on wheels should be kept full to keep out dirt sawdust and moisture.Many industrial plants use a stethiscope to listen to bearings wile greasing. Frank C.
Offline D Martin
Re: bearings
« Reply #3 on: June 19, 2008, 05:59:50 PM »
 Thanx guys I didnt think it seemed right not to be adding grease regularly. I have to do some re- fabing on the tension- taker- uper anyway' so I ll repace  that side,  both bearings. Think I should replace the shaft while it's apart anyway? They do seem cheap enough. If the bearing fell apart i'll bet the shaft is worn. All four bearings  seemed warm to th touch but not hot though. It bent the  heck out of a new band when it went.
Offline ladylake
Re: bearings
« Reply #4 on: June 20, 2008, 06:34:34 AM »
According to TK 2 or 3 pumps every 40 hours, seems to work with no bad bearing in 6500 hours.    Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline bandmiller2
Re: bearings
« Reply #5 on: June 20, 2008, 06:42:40 AM »
DM,if they are a name brand pillow block you can just buy the inner bearing ,fine unless the old one is loose in the housing.Their are different grades of pillow blocks for your application I'd use the better ones.For slow speed like carrage wheels the cheapies are fair game.Frank C.
Offline MrMoo
  • Do you have a spare log dar
Re: bearings
« Reply #6 on: June 20, 2008, 09:54:00 AM »
I do mine every 8 hours as the manufacter suggested
Offline D Martin
Re: bearings
« Reply #7 on: June 21, 2008, 01:53:03 PM »
Turns out the bearing was cracked straight through, inner and outer. Im going to replace the bearings on that side and re fab the tensioner, the shaft is fine. Must have gotten some moisture that froze over the winter im guessing. Can't think of any other reason it may have cracked.
Sealed bearings or greasable bearings on blade guides
Started by fathead on Sawmills and Milling
Last post October 31, 2012, 08:22:34 AM
by Cypressstump
hot bearings
Started by millstead on Sawmills and Milling
Last post February 01, 2013, 10:29:02 AM
by thecfarm
bearings
Started by kev on Sawmills and Milling
Last post May 08, 2009, 07:23:49 PM
by ARKANSAWYER
83 wm lt 30 bearings
Started by brandonward6 on Sawmills and Milling
Last post January 12, 2019, 11:46:31 PM
by Crossroads
