Author Topic: 3 point hitch welder  (Read 1198 times)
Offline timberfaller390
« on: August 06, 2008, 03:33:24 PM »
I have an old hobart welder that has some parts missing off the engine. I was wondering if I could build a frame for a 3 point hitch and run it off my tractors PTO. Most farm implements run at either 540 RPM or 1000RPM so do any of yall know how I can tell what the RPM requirements are to run this welder?
Appalachian Hardwoods Lumber and Logging Co.
Peavine Valley Farms
Three Notch Forge Farrier Service
Stihl MS390
John Deere 5103
58 IHC A-162 log truck
70 Ford F600 log truck
75 Ford F750 equipment hauler
IHC 500 dozer
John Deere 440 ICD dozer
Offline pineywoods
Re: 3 point hitch welder
« Reply #1 on: August 06, 2008, 03:48:05 PM »
Hard to tell for sure what the rpm requirement is, most likely 2400 but could be 3600. In any case, you gonna need some kind of speed step up -- belts, gears, etc. Those old welders are actually DC generators, so the rpm isn't all that critical.
« Reply #2 on: August 06, 2008, 04:04:54 PM »
Thanks for the info. If the RPM is "not that critical" do I need to worry about stepping up the speed? I can get more than 1000 rpm out of my tractor that is just what most balers and such operate at.
Stihl MS390
John Deere 5103
IHC 500 dozer
Offline pineywoods
« Reply #3 on: August 06, 2008, 04:11:56 PM »
It will probably work at 1000 rpm, but not very well. I'd say rig up a 2.5 to 1 belt drive, or an old manual tranny hooked up backwards--drive the output shaft of the tranny off the pto, hook the input shaft to the welder.
Offline olyman
« Reply #4 on: August 06, 2008, 05:41:22 PM »
MOST welders driven by a gas engine were at 3600 rpm--so even if you have 1000 pto--your going to have to step it up to 3600--or youll get no amps to speak of out of it---and some of those engines had a taper shaft to hook to the welder direct----
Offline DanG
« Reply #5 on: August 06, 2008, 10:40:46 PM »
Did ya look at the spec plates on the engine or welder?  They'll probably tell ya what the RPM should be.  Just size your pulleys, sprockets or gearbox accordingly.
3 point hitch log grapple
Started by 250quality on Forestry and Logging
Last post September 22, 2011, 08:33:13 AM
by bill m
3-point hitch grapple
Started by huntdibbs on Forestry and Logging
Last post January 27, 2014, 10:01:45 PM
by bill m
3 point hitch sawmill
Started by Corley5 on Sawmills and Milling
Last post December 28, 2003, 02:14:38 PM
by Frickman
A new (to me) 3 point hitch stumpgrinder (?? on teeth??)
Started by Piston on Forestry and Logging
Last post July 05, 2012, 04:46:07 PM
by muddstopper
