Author Topic: Army M-105 TIRES, fit Duece and trailers (keepiing trailers)  (Read 3109 times)
Offline Ironwood
    • http://www.branchandburl.com
« on: August 11, 2008, 09:14:38 AM »
Two rolling frames w/ parking brakes, and a "decked"  Genset trailer. 3 total. Tires on the one trailer w/ out the jack (front resting on a log) has brand new 9-20 tires. All tires are seviceable. These are big, see 5 gallon bucket in pictures for scale. These would make a good log arch for a crawler, or 35 HP or bigger tractor. I got what I wanted off of them, and now they need to go. The Genset trailer I used to haul dirt, and dump it from the lunet w/ my big forklift. I pulled the body off the one M-105 to make a offical dumping trailer. CHEAP, $250 for the Genset trailer, $150 for the rolling frame w/ landing gear, and $100 for the rolling frame w/out landing gear (this one has new tires on it), OR all for $450.  PM me if interested. Celeric was looking at an arch in "Wanted section" he get first crack if one of these will work.  Thanks Ironwood
Offline Ironwood
Re: 2 Army M-105 trailers running gear and 1 M-? Genset Trailer
« Reply #1 on: August 11, 2008, 04:30:03 PM »
Well, I am too tight! I just called the local spring shop and they wanted $250 for two springs to "help my F150 when loaded. I measured and D$%%^ these are the same width and exact legnth I need. So, I think I will just keep them and piece them out, using the extra springs and mounts for another 18,000 lb trailer I need to build. Celeric may want one as well.
  So, add now should read ARMY Duece Tires/ Rims  9-20's $50 each
Thanks For looking.
 Ironwood
Offline rebocardo
  • Atlanta GA
Re: Army M-105 TIRES, fit Duece and trailers (keepiing trailers)
« Reply #2 on: August 11, 2008, 08:28:49 PM »
Your frame should be 34" wide so many other things (hitches etc) will swap over from the military stuff too. Try using those double wrapped military springs, they are sweet. One of the small benefits of the earlier Fords.   8)
Offline Ironwood
« Reply #3 on: August 11, 2008, 09:24:43 PM »
I guess earlier means 2000? Both my Fords are 2000's. I felt kinda silly after looking at the spriings and realizing I would have to spend more on parts later if I sold these. Sometimes my creativity gets me running in circles, but after a quick call to the spring shop I realized the value of what was staring me in the face. I was ready to pay them the $250 for two measly springs, then for my heavy trailer later I would need to buy a TON more for that. I looked at the u bolts on my F-150  and they are plenty long to throw and extra sping or two and still have some thread left. I just wish my forks on the forklift were long enough to lift it up in the air (I do that with my junker Toyota Tacoma that I beat around town in ::)).
      Ironwood
log trailers
Started by redneck logger on Forestry and Logging
Last post December 25, 2008, 07:19:44 AM
by SwampDonkey
Log trailers ???
Started by BargeMonkey on Forestry and Logging
Last post October 28, 2018, 08:35:14 PM
by Oliver05262
question
Question on trailers.
Started by oakiemac on General Board
Last post October 10, 2005, 08:29:50 AM
by oakiemac
Travel Trailers
Started by Stephen1 on General Board
Last post November 17, 2013, 08:49:59 PM
by clww
