Dynamic Green Products Inc.
Author Topic: Small blocks  (Read 6840 times)
Offline farmerdoug
Small blocks
« on: December 14, 2008, 09:01:20 AM »
I know some larger blocks were sold here earlier this year.
I have a couple of crates of smaller blocks to sell.  I am not sure of what to charge so I am asking your guys help on the price.  They are from an greenhouse auction this fall.  The guy also did tree service too.
The wood block has a sticker on it.  The name on them is McGraw Edison, Brewer-Titchner.  It is made in the USA.  Size 4" inch. Working load 1400 lbs.  Rope size 1/2 MR.  There is a milk crate and a half of these.
There also is some metal blocks.  They look the same size as the others but all I can find on them is a large number 4 and Crosby.
Here is three pictures of the metal ones.
Here is three pictures of the wood ones.  The blocks are wood but the pulleys and frame is metal on these.
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Small blocks
« Reply #1 on: December 14, 2008, 10:08:41 AM »
 How much ???  Deliver  ??? ::) ::) ::)
  Need one set of wooden ones ???
Offline Loghead
  • creative sawing the best
    • kitchen and bath remodeling
Re: Small blocks
« Reply #2 on: December 14, 2008, 05:28:21 PM »
I also would take a couple sets, I use the ones have all the time !
whats the cost? ???
PS paid $20 for the wood set I have.
lovin anything handcrafted with logs!!
Offline farmerdoug
Re: Small blocks
« Reply #3 on: December 14, 2008, 09:31:22 PM »
Okay as to the price.  I am having no luck in pricing this things new or used.  I see Northern sells cheap knockoffs for 30+ dollars each.
So I am going to set the price at $12.50 each or $25/set.  If I am out of line let me know.
There is two sets of the steel ones and nine sets of the wood ones.  Only a couple of the wood blocks have the hook safty latches but I seen you can get new ones online.  If you need them I can get you the site.  The hooks all have the holes for the safety latches.
As for the shipping I will only charge what it costs me as close as I can get it.
Loghead and FDH,  I IM me your shipping info and I will try to get you a price on it.  Costa Rica will not be cheap I suspect. :o
Doug
Fargo, MI
Re: Small blocks
« Reply #4 on: December 14, 2008, 09:40:23 PM »
 Try Sebastian, Fl 32976
Offline farmerdoug
Re: Small blocks
« Reply #5 on: December 14, 2008, 10:02:33 PM »
FDH,  The USPS Priority mail flat rate box looks like the best deal.  I am sure one set will fit easily in the small box.  The small flat rate box is 9.80 + .65 for delivery confirmation=10.45 plus insurance if you like.
Doug
Fargo, MI
Re: Small blocks
« Reply #6 on: December 14, 2008, 10:47:06 PM »
 OK, Doug.
  I will send the address. How do you want payment ???
Offline farmerdoug
Re: Small blocks
« Reply #7 on: December 14, 2008, 10:56:37 PM »
A check, I guess. :) :)  If that is a problem we can work out something else.
IM me the addy and I will do the same.
Doug
Fargo, MI
Offline masonjar
Re: Small blocks
« Reply #8 on: December 15, 2008, 03:42:19 PM »
I sent you a message. Im interested in three sets if in good working condition if you still got them.
Offline Loghead
Re: Small blocks
« Reply #9 on: December 15, 2008, 06:23:03 PM »
Checks on its way! Thanks
Offline farmerdoug
Re: Small blocks
« Reply #10 on: December 15, 2008, 06:45:28 PM »
I have only two sets of wooden ones and one set of steel ones unspoken for so far.  I will be sending the Forum the 5% of the sales for support. :)
Thanks to the guys who are buying the blocks from me. 8)
Doug
Doug
Fargo, MI
Re: Small blocks
« Reply #11 on: December 15, 2008, 10:24:59 PM »
 Too late to ask for safety clips on the hooks ???
  I'll PM the address in the morning.
Offline Banjo picker
Re: Small blocks
« Reply #12 on: December 16, 2008, 03:58:29 PM »
I would like a set of the wooden ones.  Will PM you my address.  Tim
Offline farmerdoug
Re: Small blocks
« Reply #13 on: December 17, 2008, 07:25:36 PM »
One wooden set and one steel set left to go. :)
Doug
Fargo, MI
Re: Small blocks
« Reply #14 on: December 17, 2008, 07:36:14 PM »
I put the check in the mail today about lunch for mine.  Thanks Tim
Offline farmerdoug
Re: Small blocks
« Reply #15 on: December 25, 2008, 09:51:51 PM »
I have one wooden set and one steel set left.
Thanks to those who have bought the rest.
Doug
Fargo, MI
Re: Small blocks
« Reply #16 on: December 29, 2008, 08:16:01 PM »
I got them today Doug.  Thanks.  Tim
Offline moonhill
Re: Small blocks
« Reply #17 on: January 01, 2009, 11:20:39 AM »
I think I missed out on a good deal.  I cut the hooks clean off and use a shackle instead.  No chance of something coming off, no tape or string needed either as some of the old hooks required. The only drawback is it takes time to switch loads, which usually isn't a concern.   Did you have any triples.
Tim
Offline Piston
  • ...Brick by brick my friends...brick by brick!
Re: Small blocks
« Reply #18 on: January 02, 2009, 05:45:54 PM »
I'll take your last set of wooden blocks if you still have em....
-Matt
What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.
Offline farmerdoug
Re: Small blocks
« Reply #19 on: January 02, 2009, 05:49:27 PM »
Moonhill, No triples.
Piston, IM me and I will get you setup.
Doug
Fargo, MI
small wack,small logs,small project
Started by Dave H. on Sawmills and Milling
Last post February 01, 2016, 08:58:54 AM
by Sixacresand
AAC Blocks
Started by Brian_Weekley on Timber Framing/Log construction
Last post March 13, 2012, 12:39:56 PM
by witterbound
2 by 10 blocks
Started by Ohio_Bill on Sawmills and Milling
Last post October 19, 2019, 10:46:45 AM
by Banjo picker
Set-up Blocks
Started by D._Frederick on General Board
Last post February 05, 2010, 05:30:32 PM
by pnyberg
