Dynamic Green Products Inc.
Author Topic: Timber Framing Tools for Sale  (Read 24624 times)
Offline WoodDean
Re: Timber Framing Tools for Sale
« Reply #20 on: January 04, 2007, 10:36:56 AM »
Hello Jim,
I'm building my first frame and I need some tools!!!!! 8)
I'm cutting out the timbers for a 14x16 garden shed, I'm only doing this in my spare time as a hobby so, bare neccesity . . . . . . . what tools would you recommend I buy from you?  ;D
Only God can make a tree, probably because it's so hard to figure out how to get the bark on it.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #21 on: January 04, 2007, 12:25:43 PM »
If you go to the timber framing section of the FF (Forestry Forum) you'll see a list of tools suggested for each timber framer to have in a thread called: "Tools for Timber Faming List".
Here is a direct link to that thread: Click here for link to Tools for Timber Faming List
Look at the list, see what you have already, and then draw up a new list of the things you need.
I'll help you with your new "tools needed list"....
Jim Rogers
Offline WoodDean
« Reply #22 on: January 04, 2007, 03:50:20 PM »
Thanks Jim.
I looked at the list . . . . . . danG that's a lot of tools for just a garden shed.  :o
And since this is my first TF project, I don't have any of the important stuff.
I'm working with 4x8, 6x6 and 4x4 's.
I don't have any TF chisels and my saw is probably too small.
I do have a milwaukee right angle drill and big bits.
Here's my guess:
2 inch slick
1 inch corner chisel
Big Al
Depending on your advice, I think I can get away with the milwaukee for boring holes but I would like to have a Makita beam saw.
Offline Jim_Rogers
    • jrsawmill.com
« Reply #23 on: January 04, 2007, 06:07:13 PM »
I sent you a private message.....
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
« Reply #24 on: January 04, 2007, 08:04:56 PM »
WoodDean, be careful using that Milwaukee for boring holes.  I bought one of their right angle drills a few years ago to do just what you want to do, and I ran into a little problem.  The chuck on my drill is held on with a left-hand threaded screw...you can see it if you look inside the chuck.  If you bore too deep and get a lot of wood shavings on top of the bit, it will bind up when you try and back it out and the screw will snap.  It really doesn't take much to snap it, and since it's a left-hand thread I had to buy new ones from the local Milwaulkee repair place, and they aren't cheap (as far as machine screws go anyway  ;) ).  I had to back off quite often for the first hole, and then overlap a little extra to give the shavings someplace to go.  Those right angle drills must be made to drill through holes  :-\
I need to get around to buying one of those boring machines from Jim one of these days  ;)
Offline WoodDean
« Reply #25 on: January 05, 2007, 08:27:34 AM »
Funny you mentioned that . . . . . . .
I just got my drill back from the repair shop . . . . . . and guess what I had done???!!???
I was drilling holes in some floor joist with a 2 inch hole saw to run water lines in the basement, I was just about to drill the last hole when the chuck fell off.  >:(
 . . . . . . I guess that means more business for Jim!!!!
Offline ohsoloco
« Reply #26 on: January 05, 2007, 08:50:21 PM »
Now that I thought about it some more, I think the chuck on my drill is threaded, and screws onto the drill.  Using it to go "in" a hole tightens the chuck, but when you try and run in reverse, the chuck starts to screw off, and this is what knocks the head off of that special screw  ::)
Offline DWM II
« Reply #27 on: January 06, 2008, 12:23:43 PM »
Jim, where is your most up to date list? I need to start picking up a few items.  :)
Thanks, Donnie
*edit*
I just looked at the top of the thread and saw your date in ().
Stewardship Counts!
Offline Radar67
  • Cuttin Wood Now For My House Later.
    • Stewart Photography
« Reply #28 on: January 06, 2008, 12:30:14 PM »
Donnie, check the very first post of this thread. He updates that list.
Offline DWM II
« Reply #29 on: January 06, 2008, 12:34:43 PM »
Thanks Stew, kinda looks like I was chasin my tail. ;D
Stewardship Counts!
Online moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #30 on: January 25, 2008, 03:28:00 PM »
 I bought a 2" chisel, 3" slick and a corner chisel from Jim. All were used but in excellent shape and sharpened to a razor sharp edge. I've never bought a new tool that was sharpened as well.
 I also got a rock(?) maple mallet from them, very nice.
I have been making wood splinters out of some 8x8 hemlock beams with these tools. Hope to have some pics in the spring.
mh
"And the days that I keep my gratitude
Higher than my expectations
Well, I have really good days".    Ray Wylie Hubbard
Offline Jim_Rogers
    • jrsawmill.com
« Reply #31 on: January 25, 2008, 03:31:52 PM »
Thanks for your kind words.... I'll pass them on to Tom who sharpens everything.....
Offline Max sawdust
  • If it's got to do with making sawdust; count me in!
    • truetimbers.com
« Reply #32 on: February 06, 2008, 07:46:34 AM »
Jim,
Keep your eyes open for large and heavy 14" blade draw knifes.  Preferably White or Greenlee.  Interested in purchasing.
Max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Offline Jim_Rogers
    • jrsawmill.com
« Reply #33 on: February 06, 2008, 10:48:47 AM »
Max:
I've forwarded your message to Tom, he buys the tools....
Jim
« Reply #34 on: February 08, 2008, 07:45:30 PM »
It's another Tom.   :D :D
Offline Jim_Rogers
    • jrsawmill.com
« Reply #35 on: February 09, 2008, 08:35:16 AM »
Yes, Tom my partner in the tool business...... ;D
Offline StorminN
« Reply #36 on: September 08, 2008, 09:15:48 PM »
Thank you Jim and Tom, I just received the corner chisel I bought from you last week, and it looks great... I'm very happy! I will be doing business again with you soon!
Thanks,
-Norm.
Happiness... is a sharp saw.
Offline masonjar
« Reply #37 on: December 15, 2008, 04:31:58 PM »
I see the tool list hasn't been updated since first of november. Do you still have the following available.
2 1/2"-------2P
1"-----------3c
1"-----------4T
Also, if so what would shipping be to 40741
Offline Jim_Rogers
    • jrsawmill.com
« Reply #38 on: December 15, 2008, 05:00:04 PM »
Jeff:
Yes all three tools are still available.
Can you send me an email and I'll send you some information about how we package and sell the tools?
Jim Rogers
Offline Jim_Rogers
    • jrsawmill.com
« Reply #39 on: July 28, 2009, 01:24:38 PM »
The tools for sale list has just been updated....
Started by Jim_Rogers on For Sale
Last post October 05, 2010, 09:57:40 AM
by Jim_Rogers
Timber Framing Hand Tools for Sale
Last post December 25, 2011, 10:05:20 AM
by Jim_Rogers
Last post July 15, 2020, 04:34:59 PM
by Jim_Rogers
Where to buy timber framing tools
Started by Qweaver on Timber Framing/Log construction
Last post February 02, 2006, 06:05:20 PM
by srjones
