Author Topic: 036 problems  (Read 2281 times)
Offline Tony
036 problems
« on: February 18, 2009, 04:37:27 PM »
I hope I can explain this problem to where you can understand it. ::) I'm having trouble with the pull-rope assembly on my 036. The little black doohickies (pawls??) seize up and won't catch. I replaced them a couple of times this past year. :o >:( >:(
                           I hope this makes sense ::)
                                               Thanks Tony 8)
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Offline Kevin
Re: 036 problems
« Reply #1 on: February 18, 2009, 05:11:59 PM »
Is the rope wrapped in the proper direction and the retaining clip attached to the pawls?
Offline Tony
Re: 036 problems
« Reply #2 on: February 18, 2009, 06:08:31 PM »
    Yes, every thing seems to be in order. It'll run good for a while then the problem starts. >:(
Offline chevytaHOE5674
Re: 036 problems
« Reply #3 on: February 18, 2009, 06:26:29 PM »
Are they actually melting and seizing? Or just getting crude in them?
Offline sawcollector
Re: 036 problems
« Reply #4 on: February 18, 2009, 06:51:45 PM »
If they catch at all then you probably have the clip on right. If they are not kicking out and the spring clip is worn that may be the problem. I have seen sometimes the rope rotor or pulley get so worn where the pawl drops in that the rotor must be replaced.
If you drop start the saw that is why the pawls and rotor are getting messed up.
Drop starting is dangerous and hard on the starter.
Offline Tony
Re: 036 problems
« Reply #5 on: February 18, 2009, 06:57:17 PM »
                            seizing
Offline Rocky_J
Re: 036 problems
« Reply #6 on: February 18, 2009, 07:44:20 PM »
If you have ever greased them, the grease will eventually dry up and get hard, which will then create friction and gum up the works. It's plastic on plastic so no lubrication is called for. Clean it up and see that everything moves smoothly. Try to find out exactly what is catching and why.
Re: 036 problems
« Reply #7 on: February 18, 2009, 08:18:14 PM »
That was my thinking. Plastic on plastic should be a dry connection.
Next time it seizes up try and get a picture of the inside of the starter housing.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: 036 problems
« Reply #8 on: February 18, 2009, 08:44:41 PM »
 I had the same hapen to my 034 ... change the rope drum the clip and the pawl and you will not have any more issues .
   Marcel
Offline Tony
Re: 036 problems
« Reply #9 on: February 18, 2009, 09:15:39 PM »
               Went to the dealer and all that is ordered, so we'll see ::) ::) ::)
                                    Thanks for all the responses.
                                        Tony 8)
Offline joe_indi
  • The older I get the more I learn
Re: 036 problems
« Reply #10 on: February 18, 2009, 11:29:52 PM »
If the groove for the pawl spring on the starter axle is worn, replacing other parts may not help.
Remove the pawl spring (the clip that holds the 'little black doohickies'), wind a couple of inches of sewing thread into the groove for the pawl spring, re-install the pawl spring and try the starter.This could do the trick
Joe
026 Problems
Started by AdkStihl on Chainsaws
Last post October 23, 2011, 07:27:42 PM
by AdkStihl
B20 Problems
Started by Bolson400 on Sawmills and Milling
Last post April 16, 2019, 02:07:00 PM
by luap
XP Problems
Started by Paul_H on General Board
Last post May 06, 2002, 12:45:10 PM
by Jeff
OWB Problems
Started by Old Forester on Firewood and Wood Heating
Last post October 28, 2013, 11:22:55 PM
by mrcaptainbob
