Author Topic: Woodsplitter OIL  (Read 2120 times)
Offline Woodhog
Woodsplitter OIL
« on: May 27, 2009, 08:16:08 AM »
Would anyone know if it would be OK to use Automatic Transmission fluid in a woodsplitter??
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Woodsplitter OIL
« Reply #1 on: May 27, 2009, 08:58:05 AM »
Shouldn't be a problem.  I run it in my Blockbuster processor  :)
Offline chucker
  • never enough !!
« Reply #2 on: May 27, 2009, 09:26:32 AM »
its the only way to go !!
respect nature ! and she will produce for you !!  jonsered 625 670  2159 2171/28"  efco 147 husky 390xp/28" .375... 455r/auto tune 18" .58 gauge
Offline Ed
« Reply #3 on: May 27, 2009, 09:38:39 AM »
I've ran ATF for years................no problems.
Ed
Offline caz
« Reply #4 on: May 27, 2009, 09:42:28 AM »
Instead of hyd oil ?
Offline Woodhog
« Reply #5 on: May 27, 2009, 11:35:24 AM »
Quote
Yes, instead of regular Hydraulic Oil.
Thanks for the replies....
Offline Reddog
  • Forest & Urban woody plant management
« Reply #6 on: May 27, 2009, 01:02:14 PM »
Works fine but, once you start using ATF switching back may be a problem. ATF uses a higher swelling rate on seals. So if you ever switch back the seals may leak or weap.
Not always but. ;)
Offline cheyenne
« Reply #7 on: June 07, 2009, 02:32:25 PM »
I would use what the Mfg. reccomends. The most importent thing is don't mix them & change your fluids & filter when reccomended or you'll get foaming.....Cheyenne
Home of the white buffalo
Offline mike_van
« Reply #8 on: June 07, 2009, 06:14:44 PM »
The book for my '78 Didier says 10w30 or 10w40  motor oil.  I tried hyd. fluid once, the hotter it got the less snot the splitter had.
woodsplitter for big blocks
Started by wiam on General Board
Last post May 19, 2005, 04:24:22 PM
by maple flats
log lifter for woodsplitter
Started by bitternut on General Board
Last post April 23, 2006, 11:45:56 PM
by bitternut
woodsplitter speed
Started by r.man on Firewood and Wood Heating
Last post February 12, 2013, 08:56:01 PM
by Al_Smith
woodsplitter cradle
Started by CT Trapper on General Board
Last post July 20, 2011, 08:00:02 AM
by Magicman
