Author Topic: Creek or stream or ?????  (Read 9666 times)
Offline Don_Papenburg
  • I need money
Re: Creek or stream or ?????
« Reply #60 on: June 19, 2009, 09:41:57 PM »
Jeff , you are safe if it is bloated that means all the orfices that emit nasties are all swelled shut . Now if you looked up and it was just finnished deflating that would be a problem .   but you would have smetl it before you got the innerds outa your hard hat.
Offline Ironmower
« Reply #61 on: June 20, 2009, 08:37:44 AM »
Don't remember where I heard it. It was said that flowin water, over rocks, will "purify" the water in 50 ft (don't remember exact distance, likely further)
     I personally ain't gonna try it, but it would be an interesting test.
   Test the water with contaminents ( like where the sheep is layin), go down stream, and check again.
WM lt35 hd 950 JD
Offline Dave Hanny
  • Originally from Western PA
« Reply #62 on: June 20, 2009, 09:21:46 AM »
I don't know - My buddy tells a story of a pristine stream & waterfall system he found that he later found out was the equivalent of something like hydrochloric acid.  To look at it no-one would know, but... lol.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense.
-- Buddha
Heads Up Down Stream
Started by chet on General Board
Last post March 28, 2004, 06:28:03 PM
by Kevin
stream crossings
Started by OneWithWood on Forestry and Logging
Last post April 23, 2004, 09:52:28 AM
by OneWithWood
Stream Identification
Started by Bill Johnson on Forest Education
Last post December 07, 2007, 03:59:45 PM
by Bill Johnson
Have any of you used this stream crossing product?
Started by dustyjay on Forestry and Logging
Last post January 12, 2014, 03:35:50 PM
by plasticweld
