Husky 262xp
Started by Todzilla, August 29, 2009, 07:37:50 AM
Todzilla
Husky 262xp air inj. The h l t screws on the carb have been moved i'm curious about a good starting point on the adj. Saw starts and runs for a second lightly throttle up and it dies. New fuel and proper mix. any ideas? thanks,  Todd
Kevin
Basic setting is 1 turn out from a lightly seated position on the H & L .
13,500 rpm , 2,500 rpm on idle.
Tree tech
Hi there, i was going to  say 1 1/2 out , ive got a 262xp i will check tomorow!
Kevin
one turn is factory spec for the 262.
GASoline71
Read the link that Brian put up... It's all you need to know abou tunin' a pro saw.
Gary
\"...if ya mess with the bull... ya gets the horn.\"
