old husky
Started by Gus, September 16, 2003, 08:21:55 PM
Gus
Does any body remember the cc's and horses of the old husky 2100?
Thanks,
Gus
"How do I know what I think unless I have seen what I say?"
Tillaway
Yep, 99 or 100.  Lots of parts for those out west if you need them.
Making Tillamook Bay safe for bait; one salmon at a time.
Kevin
Oregon_Rob
SERIES OR ASSEMBLY NUMBER:
YEAR INTRODUCED:             1975
YEAR DISCONTINUED:             1987
ENGINE DISPLACEMENT:             99cc (6.0 cu. in.)
NUMBER OF CYLINDERS:             1
CYLINDER BORE:             56mm (2.20 in.)
PISTON STROKE:             40mm (1.57 in.)
CYLINDER TYPE:             Aluminum with chrome plated bore
INTAKE METHOD:             Piston ported
MANUFACTURER ADVERTISED H.P.:             6.7/4.9 hk/kW
WEIGHT :             10.35 kg 22.8 with 60 cm 24In bar & chain
OPERATOR CONFIGURATION:             One Man operation
HANDLEBAR SYSTEM:             Anti-vibration
CHAIN BRAKE:             Mechanical
CLUTCH:             Centrifugal
DRIVE TYPE:             Direct
CONSTRUCTION:             Die cast magnesium
MAGNETO TYPE:             Electronic
CARBURETOR:             Tillotson HS series
AIR FILTER SYSTEM:             Nylon mesh cartridge
STARTER TYPE:             Husqvarna automatic rewind
OIL PUMP:             Automatic, adjustable
OPERATING RPM:             8,500
IGNITION TIMING:             Mark on stator should align with mark on crankcase
BREAKER POINT SETTING:             none
FLYWHEEL/COIL AIR GAP:             fixed, not adjustable
SPARK PLUG TYPE:             Bosch WS7F or Champion CJ7Y
SPARK PLUG GAP:             0.5mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS:             Ball
FUEL TANK CAPACITY:             950 ml
FUEL OIL RATIO:             40:1
RECOMMENDED FUEL OCTANE:             Regular
MIX OIL SPECIFICATION:             Two-stroke chain saw mix oil
CHAIN PITCH:             3/8 in. or .404 in.
CHAIN TYPE:
SHORTEST GUIDE BAR SUPPLIED:             40cm (16 in.)
LONGEST GUIDE BAR SUPPLIED:             152cm (60 in.)
COLOUR SCHEME:             Husqvarna Orange enamel
Chainsaw Nerd
Kevin
Gus
Hey Rob love it 8) Everything I could ask for and more. Had no idea it was that long ago that they quit making that saw. Man time flies. :-/
Thanks, Gus
Oregon_Rob
I picked up one that was pretty warn out, oiler didn't work, starter spring shot, clutch warn out, carb needed rebuild, lots of broken parts, stripped holes but I have it in decent shape now and use it for milling. Still runs strong.
Wish I could get a new one
Chainsaw Nerd
