Quarter Sawing White Oak
Started by Jim Spencer, November 11, 2009, 10:02:22 PM
Jim Spencer
Quarter Sawing White oak on a Logosol chainsaw mill.
What thickness would be best to saw the boards and end up with 3/4" after kiln drying and planing?
I had a 34" oak I cut down and decided to quarter saw it and found that it cuts much easier when cutting this way across the growth rings.
I cut (split) the (4) 8' logs into 4 pcs and cut boards from the bottom and rotate the piece that is left after each cut.  I have cut a few thousand board ft. just slabbing but never liked cutting white oak because it is very hard but quarter sawing the cut seems to be much easier on the saw and cuts much faster.
Has anyone experienced this or is this just my imagination?
Jim
Dan_Shade
i would recommend at least 1 1/8" thick when green for quartersawing.  anything less, you may end up shy when you plane it out.
could the easier sawing have to do with the width of the board being more narrow while quartersawing?
lots of dull bands and chains
Gblombo
1-3/16.  Quartersawn material will shrink more in thickness and less in width relative to plain sawn.
Have fun.
Greg
Greg
Strengthening your cost accounting muscles so you can flex them for your stakeholders and family.
woodmills1
I would say yes to the thinner widths, once you rip a big white oak log you will agree.
ladylake
 Jim  If you have some nice white oak log that will QS, I'd hire a bandsaw to saw them. The extra boards over a chainsaw mill should more than pay for the sawing. QS WO fetches a good price. With a accurate bandsaw I'd saw 1" thick, I saw mine 1" and have no trouble cleaning up with the planer to just over 3/4 unless a board cups bad, then I rip in half with the table saw before planing.  QS doesn't cup much either. I've QS some at 5/4 that cleaned up at a little over 1-1/16  at 6-8% moister.    Steve
Dan_Shade
I quarter-sawed a bunch of red oak at 1 1/16 when I first started milling, none of it will clean up to 3/4".  It's extremely frustrating when that happens.
your mileage may vary
backwoods sawyer
Quote from: Dan_Shade on November 14, 2009, 08:22:06 AM
Wow, that is a lot for Oak. The only wood that I have had move that much is Madrone.
Backwoods Custom Milling Inc.
ladylake
I find QS WO to be real stable with no cupping and I don't like to make extra passes through the planer just making more shavings.   Steve
Dan_Shade
quartersawn wood shrinks more in it's thickness than it does it's width.
I have some quartersawn red oak still rough sawn.  I sawed it to 1 3/16 using woodmizer's simple setworks.  checking a few boards that have been kiln dried, they are all less than 1 1/8. They mayl plane out to a full inch, but it's doubtful, they'll likely hit 15/16 when finished.
My opinion is that it's not worth the risk of having thin boards, trying to get a half board more.
As I said before, your mileage may vary.  If I'm sawing good stuff for a customer, I try to get them to let me cut it to 1 1/8.  scant boards are bad.
ladylake
   1-3/16 to 15/16 is 1/4"      Same as 1" to 3/4"  and there's less wood to shrink with 1" boards. sawing to thick just makes more planer shavings and more work.   Steve
red oaks lumber
a board that didn't cleanup, is all wasted work, wood ,energy. i always saw thicker, in case the blade dips, or make a small math error you still have mat'l to plane off.
ladylake
If 1 board out of 50 doesn't clean up we should saw  them all to thick to save that 1 board, not over here. Being a woodworker also there a lot of places to use that board that doesn't clean up.   Steve
nas
Quote from: ladylake on November 15, 2009, 11:44:29 AM
My thoughts exactly.  Are we going to loose 1 in 9 to save 1 in 50? ???
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Dan_Shade
It's not 1 in 50, it was all of the ones I sawed out.
If you have good material that can be quartersawn, it is absolutely not worth the risk of having thin boards after they dry, and it can easily happen if they are only sawn an inch thick.
Draw up some circles and figure out how many boards you'll lose if you saw them thicker than an inch.  If you are quartersawing, you'll probably find that you won't lose any boards if you cut the boards a bit on the thick side.
I "lost" 500bf of nice red oak quartersawn boards from a 36" diameter log.  Live and learn.
To be blunt, I consider advise to saw anything thinner than 1 1/8 to be bad advice, even if flatsawn, and especially bad advise if quartersawn.  I'm adamant about that with my customers.  I won't do it, unless they are sheathing a barn. :)
Chico
exactly rt Dan-Shade the most exp mills in the industry allow 1/8 esp on hi grade h/w they may fudge on 2com and below if it's headed for flooring
My Daughter My sailor MY HERO God Bless all the men and Women fighting for us today If you see one stop and thank them
backwoods sawyer
Quote from: Dan_Shade on November 15, 2009, 08:41:18 PM
You seem pretty adamant about that.
I am not real certain as to why though. If the customer is using the wood for his own use and is willing to work with ¾"-13/16"-7/8"-or 15/16" as a finished size, then why would you insist on milling 1 1/8"?
That is unless he is selling the wood commercially in which case of coarse you would mill to the industry standard.
scsmith42
Interesting comments from across the US.
Like Dan, I mill to 5/4 on quartersawn, and a lot of it has to go to 3/4" when going through the jointer/planer.  If I were simply double planing, I could get a thicker board out of it.
80% of my board widths are 10" or wider, and I prefer not to resaw it into narrower boards.  For my ultra-wide QS boards (16" - 20"), I'm thinking of milling to 6/4 in order to make sure that they will joint/plane out to 3/4" or 7/8".
Tom's 3638D Baker band mill
ladylake
6/4 to 3/4. you got to be kidding, I was brought up not to waste and unless you can get as much for planer shaving as you can get for QS WO boards that's all your doing. I've sawn everything for years at 1" that gets planed to 13/16 or 3/4 with no complaints including a flooring company that said maybe 1 out of 50 don't clean up on part of a board. Never has a customer call back and say they were sawed to thin. I can see if your cutting wavy where you would want to saw thicker or for a commercial outfit that demanded it. I've even sold a few loads to a commercial door company that let me saw at 1" with a band saw if they were uniform and straight .   Steve
I saw what the customer ask for.  Wider boards are sometimes sawed thicker if they think that it may cup.  Even then, the customer makes the decision.
Dan_Shade
I've never had a customer bulk when I explained my reasoning to him.
At the end of the day, they're paying the bill, so I do what they want.  But I certainly don't want an unhappy customer a year from now with a board that cleans up to 11/16 because I cut it too thin.
solidwoods
1" thick green and it planed out to over 3/4"?  WOW.
If you wood work, the jointer is typically the first tool you start out with.
It flattens the board, then you go to the planer to make thickness.
So 1" green doesn't allow for flattening.
(planers do not flatten boards, they make them thinner)
I mill 1 1/8" on the mill scale which makes a half kerf less than 1 1/8".
All cuts.  Since 92.  But any/any bit off and you'll be close to make 3/4" finished thickness.
I've tried 1" on the mill scale and "no way can I get 3/4" finished product.
Leave splitting hairs to crime investigators.
Now chain saw milling is a different critter, the surface will be rougher than a band so you should compensate for that.
Ditto on get a band mill to cut qtr sawn. just do the kerf loss to bf. yield  math.
CSM's are better suited to thicker cuts do to the kerf loss.
Stay in touch with band millers in your area, some may need your services to cut a big log to fit their mill (I wish I knew of one local).
Qtr sawns big dry defect is side bend, so plan widths accordingly.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
red oaks lumber
iv'e planed about 5 million b.f.  of mat'l sawn by small bandmills in the past 10yrs. most was sawn to thin, if you saw 1" green, it will dry to maybe 7/8. if we are making floor or wall paneling at 3/4 thick  and you have spots that don't cleanup, who's reputation is on the line , not the guy that sawed, but me because we are the last one to handle the wood.
i don't care how you saw your personal wood but, if your sawing for someone else you need to think about the next operation, thats just doing your job correctly. of the 5 million b.f. i planed from the small bandmills, maybe 10% was what i would consider sawed ok.
thicker is better
Dodgy Loner
I'll throw in my two cents. I quartersaw oak to 1 1/16" thick (that's the actual thickness) and every board will clean up to 13/16" thick after drying. Heck, last year I sawed up about 1400 b.f. of flatsawn pine, 12" wide and 10' long, using the 1" scale, which left all the boards somewhere between 7/8 and 15/16. Maybe 1 in 10 boards didn't plane out to 3/4" and the ones that were a little shy didn't matter because I was using it for wall paneling. I just put the clean side facing out and no one will ever know the difference.
I think all this talk of sawing 1 3/16 or 5/4 lumber to plane out 3/4" is just nuts. But then again, I'm not sawing for a commercial customer so the risks aren't as great if something doesn't work out like I planned. Still seems like a waste to me. Since when is 3/4" the only thickness of lumber that is considered usable?
backwoods sawyer
In reading all of the post I am seeing that some are referring to sawing to 1" scale and 1 1/4'" scale, verses actual thicknesses. With the accuset and accuset 2 the kerf is calculated in before the cut is made so you are cutting a full 1" verses 13/16". It may be that this whole discussion is based on two different measuring methods.
ladylake
 My mill when set on 1" drops down 1-1/16 to allow for the saw kerf.  The boards end up at just a hair over 1" maybe 1- 1/32"  .      Steve
