Author Topic: 357xp/2156 or 359/2159  (Read 7306 times)
Offline John Mc
Re: 357xp/2156 or 359/2159
« Reply #20 on: December 13, 2009, 08:30:48 AM »
wow, i thought if there was anywere the 359 were better, it would be in the bigger stuff. do you find the 359 better in any area?
Price.  ;D
I do wonder about durability... seems as though cranking more power out of a smaller engine would tend to shorten its life. But then I've not heard any complaints in this regard for the 357, so maybe it's not an issue?
John Mc
Offline SawTroll
« Reply #21 on: December 13, 2009, 05:01:07 PM »
I have a 357xp and a 365 special. There could be only a pound to 1.5lbs difference in them PHO. Something in 12.??  (cant remember) and 13.6lbs.
If you want a limbing saw and smaller bucking saw. Look at the new 50cc 346xp 11.??lbs with the grey side cover. If you want to save even more weight and more toward limbing old 46cc 346xp 10.??lbs with orange cover.
That is true!   8) 8)
Information collector.
Offline SawTroll
« Reply #22 on: December 13, 2009, 05:07:12 PM »
The 359 just is a cheaper and inferior saw - no miracles will happen (unless it is modded)..... ::)
Offline thumper
« Reply #23 on: December 13, 2009, 06:15:49 PM »
well, im not racing against anyone i just want to use my saw everyday without tuning and fiddling at the jobsite. also not so happy with saws that require w.o.t all the time to cut anything without bogging. i will use my 2 saws 2150 and 2165 for the next few weeks and then i will be buying a new jonsered 2156 or 2159. ive had a 346oe in the past and didnt really care for it,  im not so happy with the hsqv dealer around here. so a 346 is out of the question unless the new one is as powerful as the 56/ or 59. even at 1lb or so quoted less , i think it will be less strain after carrying a 2165 all day.
Jonsered 2150 2152 2156 2165  Husqvarna 262xps Worn 1970 JD440a 06 GMC 3500 DURAMAX
Offline Cut4fun
« Reply #24 on: December 13, 2009, 06:22:07 PM »
Thumper where are you located? That like new 357xp that is woods ported is FS  in my video's I posted in this thread. Cost is less then a new 357 for PHO.  I'm wanting to get a alky saw built and the 357 hasnt seen any real use since 2004. Just a hobby cutter here and use it for gtg's.
Come take it for a test if you are close.
Offline thumper
« Reply #25 on: December 13, 2009, 06:28:45 PM »
Id love to try that 357 but im in northern maine, with dialup, so i cant even watch the video!  :'(
Offline Cut4fun
« Reply #26 on: December 13, 2009, 07:02:06 PM »
Dial up on my end takes about 10 mins to load 30 sec video. I just start download leave come back and hit replay. Good Luck.
Yep little far for a test drive, sorry.
Jonsered 2156 = Husky 357XP?
Started by Corley5 on Chainsaws
Last post October 29, 2007, 03:29:52 PM
by SawTroll
jred 2156 crankcase gasket
Started by thumper on Chainsaws
Last post November 04, 2011, 08:14:32 AM
by Al_Smith
Husky 359 vs Jony 2159
Started by vgbob on Chainsaws
Last post August 14, 2006, 08:37:04 PM
by 4woody
Jonsered 2159 Husky 359
Started by Woodhog on Chainsaws
Last post September 15, 2005, 11:28:08 AM
by floyd
