Our nags use their shed to get out of the hot sun, but don't go in there to escape the cold or the rain.
Looks alot like what I built for the wife. If I tried to put my wife in something like that I would be the one staying there.
Just thought that I would share some info on the 3 sided horse shelter the wife and I built last summer. It is mostly (~85%) out of recycled rough cut 2x6's of pine/spruce/cedar that came with the farm when we bought it. It's 10'x20' with a 12' high front and a sheet metal roof. We live up north where a heavy ground frost and large snow loads are possibleThe Drawing (Image hidden from quote, click to view.)The Picture(Image hidden from quote, click to view.)
Monique, What size do you plan on building - 10'X12', 10'X16', 10'X24', etc? What do you plan on using for siding - board & batten, OSB/Plywood, metal, lap siding, etc.? What do you plan on using for roofing - shingles, metal, etc. What is your snow load - slope of roof/height differences between front and back? What is your planned rafter material and spacing - 2X4/2X6, 16" centers/2' centers, etc. ? How much overhang do you want on the front, back and sides - 1', 2', etc? Lots of the box stores have a computer program and if you show them this drawing and answer the above info they can probably spit out a BOM in very short order. Its not that hard to calculate once you make up your mind about the above details?
Started by KGNC on Timber Framing/Log construction
Started by Downstream on General Board
Started by saxon0364 on Forestry and Logging
Started by MIsawyer on Sawmills and Milling
