Author Topic: Diesel fuel tank question  (Read 2413 times)
Offline jtmccallum
« on: January 30, 2010, 03:56:50 PM »
I am in the process of replacing the fuel lines on my mill.  The previous owner eliminated the quick disconnect for the supply line because of problems bleeding the system after re-fueling.  Is this normally a problem.  Should I just install a new Q/D adapter.  What are other owners doing.  '97 Lombardini.
John M.        '97 WM LT40Super Manual 40HP Lombardini,  XP372,  MS361, Logrite Cant Hook  CASE 1210 W/ Loader
Offline amberwood
    • www.amberwood.com.au
Re: Diesel fuel tank question
« Reply #1 on: January 30, 2010, 05:09:01 PM »
The prev owner of my 97 super did the same thing. I refill via jerry can.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: January 30, 2010, 05:42:52 PM »
I still have the quick connects, but I always refill with 5 gallon cans.  Even though I don't need them, I did have to replace the plastic one a couple of years ago.
I went to the boat dealership for a new one.
Offline ladylake
« Reply #3 on: January 30, 2010, 08:09:35 PM »
I use a quick disconect off a Mercury boat motor gas tank, been working good for almost 2 years. Sometimes I fill with a can and sometimes take the tank off and fill. When it's really cold I bring the tank inside to prevent gelling.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #4 on: January 30, 2010, 10:33:23 PM »
The previous owner had removed the quick disconnect on my mill as well. I built a new tank and plumbed it in direct. I just lower the head to about 6 and position it so that I can walk right up on and have a solid spot to stand while refueling.
Offline LeeB
« Reply #5 on: January 31, 2010, 12:56:33 AM »
Mine still has the quick connects and I use them whenever I take the tank off for refilling or sometimes I just use another can to refill. One possible reason for removing them is that the can leak after a while causing the line to suck air. This will reek havoc with your engine output.
Offline pineywoods
« Reply #6 on: January 31, 2010, 11:10:13 AM »
It ain't just the diesel tanks. I had the same problem on my gas burner. Same solution, hose clamp and brass fitting..
Offline ladylake
« Reply #7 on: January 31, 2010, 11:48:06 AM »
  I think it's just a rubber o ring that needs to be replaced if it sucks air.   Steve
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
« Reply #8 on: January 31, 2010, 12:33:16 PM »
Have never had a problem with quick disconnects on my 2008 lt40hdd51 (Cat)
Always take the tank off for refueling.
I am 99% stationary and fill from a bulk tank.
I would assume that if a problem occurs a couple of squeezes on the priming bulb would suffice to cure the prob.
Pete
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #9 on: January 31, 2010, 05:48:49 PM »
I had to replace the QD connectors on my gas tank due to the O-Ring leaking air.
I looked for replacement O-Ring's, but they turned out to be "non-standard", so I just put new fitting on instead of continuing the search.
I remove my tank at the end of each day.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Diesel fuel contamination in 518 fuel tank
Started by giant splinter on General Board
Last post February 17, 2013, 07:31:07 AM
by Autocar
Gas and diesel fuel transfer tank
Started by Firewoodjoe on Forestry and Logging
Last post March 25, 2019, 08:55:59 PM
by DDW_OR
cutting and welding on a diesel fuel tank-Now how to build a heat exchanger
Started by OneWithWood on General Board
Last post September 27, 2006, 11:36:52 PM
by Don_Papenburg
024 av fuel tank replacement question
Started by Banjo picker on Chainsaws
Last post July 07, 2013, 10:11:19 AM
by Banjo picker
