Dynamic Green Products Inc.
Author Topic: joists log sizes??  (Read 1710 times)
Offline shad
joists log sizes??
« on: February 20, 2010, 10:00:08 PM »
Got started cutting logs today to build the house in Jack Sobons book. You can see a picture of my crew and high tech logging equipment in my photo gallery. (couldn't figure out how to attach it here)
My question is about some of the smaller timbers like the 5"x7"x 14" joists. Would they stay straighter if I cut them from a small tree(box heart) or cut several from a very large log?
Offline jander3
    • Anderson TimberWorks
Re: joists log sizes??
« Reply #1 on: February 20, 2010, 11:05:26 PM »
I like the crew.  Logging always works better when clad in pink shoes.
Offline moonhill
« Reply #2 on: February 21, 2010, 06:53:52 AM »
What do you have more of?  If you cut them out of the large log, we will say they will bow, just put the bow up to help with the deflection.  Could you use the larger logs for something else?  Small trees taken from thinning and such will make nice joist.  I will have to take a peek at the pictures, but hardwood or softwood?
Tim
Offline shad
« Reply #3 on: February 21, 2010, 10:12:26 AM »
mostly hardwood, but i do have a good stand of SYP all around 8" diameter.
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
« Reply #4 on: March 09, 2010, 06:38:22 AM »
Didn't get the "pink shoe" comment till I checked the photo gallery- good to have the young ones helping and maybe they'll learn something if you're safe with 'em.
I've tried cutting beams that are not heart centered- if the log is dry (got a mess of Katrina logs been drying for years) they work fine.  If the log is still wet when you cut it, you might get more movement as it dries.  Heart-centered stays straight almost all the time, and since you can use smaller trees for that, it makes more sense if you're using your own trees.  If you're buying, you might be able to pick and choose.
Either way works, just differently- plan for what will happen and compensate as you build.
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Rough sawn green doug fir for exposed ceiling joists and floor joists
Started by Sedgehammer on Timber Framing/Log construction
Last post February 14, 2019, 12:14:18 AM
by Sedgehammer
Modern joists between 1860's log joists.
Started by Mediastinia on Timber Framing/Log construction
Last post April 06, 2019, 03:06:48 PM
by Mediastinia
I-joists
Started by fiddle1 on General Woodworking
Last post June 13, 2011, 04:32:30 PM
by ljmathias
timber vs log joists
Started by cgsemrau on Timber Framing/Log construction
Last post August 14, 2019, 09:59:25 PM
by cgsemrau
