Dynamic Green Products Inc.
Author Topic: Wood Mizer Blade Sharpener and Setter (Blade Maint Pkg) - SOLD...  (Read 9781 times)
Offline Warren
  • Whatever you do, work at it with all your heart, as working for the Lord.... Col. 3:23
More Garage Cleaning - Wood Mizer Automatic Blade Sharpener and Manual Setter.  4 years old, less than 200 blades sharpened on it.  Easier for me to send the blades out to have them sharpened.  This is the old style sharpener with the ceramic sharpening stone.  Not the CBN wheel.  Includes 9 degree and 10 degree cams, plus manuals, plus odds and ends.  Will try to post pictures of the actual unit  in the the next day or so.  But, looks just like the one on the Wood Mizer website:
http://www.woodmizerblades.com/maintenance/sharpenerSetter.aspx
Again,  this sharpener uses a ceramic blade, not the CBN wheel.  Cost $1995 new 4 years ago.  Out the door for $995 with 10% to Forum....
-w-
LT40SHD42, Case 1845C, W&S Forklift, Baker Edger ...  And not near enough time in the day ...
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Re: Wood Mizer Blade Sharpener and Setter (Blade Maintenace Package) $995
« Reply #1 on: February 27, 2010, 02:37:18 PM »
Will this sharpern any manufacturers blades or just WM's
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
« Reply #2 on: February 27, 2010, 02:49:44 PM »
That would be the same machine I have. I know that Timberwolf makes a cam for their blades to fit the WM sharpener, and I believe Cook's does to.
Gee Warren, why didn't you have a garage sale before I bought mine?
Bill
Offline Warren
« Reply #3 on: February 27, 2010, 03:27:32 PM »
Stumpy,
This is a stock Wood Mizer Sharpener set up for the stock Wood Mizer blade tooth profile.  If you are using  Wood Mizer blades, or blades that have the same blade tooth profile as Wood Mizer, you should be O.K.
As WH points out, with the proper cams, the sharpener could also be used to sharpen other manufacturers blades,  But, it would be up to you to sort out the details if you wanted to go that route.
If you are seriously interested, you could send me a blade.  I'll send it around the sharpener a couple times, and send it back to you.  You can run it on your saw to see if it cuts satisfactorily for you...
-w-
Offline LeeB
« Reply #4 on: February 27, 2010, 04:03:45 PM »
There are a couple of places you can get cams from for other brand blades. Both of them are sponsers. Cooks and Menominee. They both have a link on the left side of the screen.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: March 02, 2010, 09:57:49 AM »
I cant believe this sharpener is still FOR SALE!  :-\
Stuff like this usually is gone within a couple of hours of posting!  ;)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline dbnair
« Reply #6 on: March 02, 2010, 02:01:48 PM »
pm sent.
Thank you,
Grant
New to me blade sharpener & setter
Started by Mt406 on Sawmills and Milling
Last post January 03, 2017, 04:14:46 PM
by Bluejay27
Wood-Mizer Shop Series Dual Tooth Setter***SOLD
Started by terrifictimbersllc on For Sale
Last post January 30, 2016, 04:26:12 PM
question
Blade Sharpener and Setter Questions
Started by GF on Sawmills and Milling
Last post July 19, 2005, 12:52:26 PM
by Tom
Blade Sharpener & Tooth Setter
Started by ahlkey on Sawmills and Milling
Last post February 26, 2009, 10:49:44 PM
by Ironwood
