Author Topic: Band SFPM  (Read 1812 times)
Offline bandmiller2
Band SFPM
« on: March 02, 2010, 08:23:49 PM »
Do any of you guys know the effects of low SFPM,and the effects of too high SFPM.I would think too high the teeth would dull sooner and the sawdust would be finer.Seems lower band speed would give longer band life.Frank C.
Offline red oaks lumber
Re: Band SFPM
« Reply #1 on: March 02, 2010, 09:26:10 PM »
you can equal that with feed speeds, faster band speed means faster feed speed and visa versa.proper lubrication also helps
Offline taschmidretired
  • Stay Thirsty My Friends
Re: Band SFPM
« Reply #2 on: March 02, 2010, 10:55:49 PM »
  60 mph 5280' p/m
"Until I had turned Thirty Five, the longest I had ever stayed in one place was my Mother's womb."
"Beware of the man that shoots his arrow first, and then paints a bulls eye around it after."
Offline bandmiller2
Re: Band SFPM
« Reply #3 on: March 03, 2010, 06:59:42 AM »
Reason I asked is yesterday put hand held S/W tach on the bandwheel shaft the SFPM would figure out to 6500 SFPM.I didn't think it was that fast engine RPM must have picked up,seemed to cut good though.I'm not in a hurry so the with the electric motor conversion I'am going to slow it down right around 5000.Frank C.
Re: Band SFPM
« Reply #4 on: March 03, 2010, 06:57:13 PM »
Your sheave sizes at the motor/drive wheel can drastically amp up or lower travel speed. To get that1750 up to where you were/are constitutes a little movement causing a larger movement.
Offline bandmiller2
Re: Band SFPM
« Reply #5 on: March 04, 2010, 07:01:59 AM »
Your right Tom,I'am puting a 6" on the 1760 motor and 11" on the bandwheel shaft,keeping as large a pulleys as I can for traction.Frank C.
Offline ely
Re: Band SFPM
« Reply #6 on: March 04, 2010, 09:24:15 AM »
seems i read someplace one time that the sfpm that was optimal, was somplacein the neiborhood of 4600. im sure that would change with the many different bands we have available now days.
Offline bandmiller2
Re: Band SFPM
« Reply #7 on: March 04, 2010, 08:11:43 PM »
Ely,I think probibly the type of wood and its moisture content would play a roll in optimal SFPM.I think a good sharp well set band somewhere in the ballpark will work,its most likely a compromise anyways. Frank C.
Offline LeeB
Re: Band SFPM
« Reply #8 on: March 05, 2010, 02:13:29 AM »
Several years ago Sawmill and Woodlot magazine put out an issue that talked about this and many other blade issues, both band and circle. I seem to remember 52-5400 being the magic number. They have a websight and you may be able to search old issues. I don't know.
Band Speed SFPM
Started by smwwoody on Sawmills and Milling
Last post May 28, 2004, 07:27:06 PM
by smwwoody
What SFPM for big blades? And what power?
Started by Satamax on Sawmills and Milling
Last post August 25, 2011, 05:32:37 PM
by Satamax
Bought a home-made band saw- question about band guides
Started by dbpochardt on Sawmills and Milling
Last post January 30, 2013, 04:47:21 PM
by francismilker
question
Timberking B-20 Band Length and a couple Band Questions
Started by Meadows Miller on Sawmills and Milling
Last post February 07, 2012, 05:46:22 PM
by ladylake
