which skidder?
Started by treefarmer87, March 12, 2010, 11:42:44 AM
treefarmer87
I also found a franklin 170 http://www.tylosales.com/index.php?/FORESTRY/69-FRANKLIN.html  in my price range, looks a little rough though, there is a 440 deere a mile down the road with a brand new motor too. im kinda confused now. i have never had a skidder and i need something for work mon- fri getting at least 2 loads a day
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
timberjackrob
had a older 440 once u never had to worry about losing it u could track it by the leaking hydraulic fluid. ajohn deere is a great machine as long as everything is working actullay easier to use than a timberjack,however they are extremley hard to work on to many hydraulic parts and valves. everything is enternal even brakes require complete teardown,not to mention parts from dealer are out a site.unless u are an experienced deere mechanic iwould stay away. deeres are harder to get on and off of also.
208 timberjack, woodmizer lt28,case 455 trackloader with gearmatic winch,massey 4710, ford f250s ford f700
treefarmer87
yea i know there is a guy that hauls to the same mill i do and he told me not to get that skidder cause it is beat up i like that 170 though
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Bobus2003
Quote from: timberjackrob on March 26, 2010, 10:41:42 AM
I have a late 60's 440 and I love it.. Its not hard to work on.. Yeah the valves are a bit complex and $$ to fix if you go to Deere.. I havent really found it hard to get any parts through Deere or that expensive.. (I also have a Complete Extra Parts Skidder). I had some issues with a Clutch a for a few weeks, but that was just a Shim issue.. Still lost on that one though
Jim H
TF, check Charlottesville Craigslist,there's a c5d with a detroit for $6500 in the farm and garden section.
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
treefarmer87
i just seen that a little while ago, thanks jim it has been on there before, probably about december, the they took it off first they wanted $8500 for it then dropped it to $6500 it went off craigslist in jan i think. now its back on
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
treefarmer87
hey jim h, thanks for the info on the treefarmer, checked it out yesterday- going to bring it home tomorrow
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Jim H
Glad that worked out, it sounded like it might be a good machine. On another subject, do you run into much cedar on your tracts? I could use a load or two from time to time.
