Author Topic: Wood waste grinder  (Read 2301 times)
Offline Kansas
  • In the mountains of Kansas
Wood waste grinder
« on: March 19, 2010, 10:39:47 PM »
The plan is this summer to put a new building that will house our operation. When we do this, I want to put in a wood waste grinder.  We haven't settled on the exact floor plan yet, but I suspect it will have both bandmills, the resaw, gang edger, and pop up saw along one side. We run most of the first cuts through the gang edger and cut them into cants for the resaw. If we can get a 1/2 x 3 1/2 inch board 34 inches long out of a cant, we take it. As such, most of the material thats left is fairly small. This building will be fully enclosed.  How do other operations set up something like this? I have wondered about putting in a conveyor belt to feed a wood grinder. Some feed from the top, some are horizontal. I want a grinder that makes a nice mulch. The cresswood and some others that are lower speed and lower horsepower look intriguing. Any ideas or experience with this?
Offline Ron Wenrich
Re: Wood waste grinder
« Reply #1 on: March 20, 2010, 06:30:46 AM »
When it comes to woodwaste, you don't want to handle it any more than necessary.  You can run it on belt or vibrating conveyors.  If you're handling lots of small material, chains won't work too well.
Are you going to mix the sawdust with the other waste?  If so, then you can run everything on one conveyor.  If you're going to separate it, you can run it on a one conveyor, but will need some way of pulling out the dust.  You can use a grate on a vibrating conveyor to do this.
When guys were grinding wood for mulch, they usually put in a wood hog.  These were more like a shredder, and could take some pretty big chunks.  A horizontal feed gives you the luxury of putting in an unlimited length.  Top feeds means you have to have sufficient drop to handle your longest piece.  There's an arc that has to be engineered in to accommodate the drop.
From my standpoint, I always look at how quickly and easily something can be cleared when it jams up.  Since you won't have a hog attendant (no offense pigman), what happens when a vertical feed gets filled up as opposed to a horizontal feed?  A lot depends on the material being hogged.
Brand and type depends on how much waste you plan to shred and if expansion is in the stars.  There are a lot of different makes and models to fit your needs.  I'd look at a lot of them before I decided on one particular company or model.  You're the one that has to work with it.
Offline Kansas
« Reply #2 on: March 20, 2010, 09:12:18 PM »
I never thought about a screen to allow the sawdust to fall through. I think it would make a better mulch if we did. I did buy a blower big enough at a sawmill auction a few years ago to hook up the mills and resaw and planer.
I may go that route for those, but the gang edger has too many chunks of wood coming off of that to hook it up to that. I do think horizontal is the way for  us to go. We cut too many 16-20 ft trailer deck orders for a vertical grinder.
I think a road trip is in order to look at some other operations on their layout, get some ideas.
Thanks for the advice.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #3 on: March 20, 2010, 09:43:23 PM »
One of the cleanest operations that I have seen had the sawmill on the second floor with three vibrator conveyors underneath. The sawmill was set up in a rectangle with the primary breakdown along one long wall, a transfer, unscrambler and scanner along the short wall, this fed the three edgers that were set up along the other long wall. All the edgers dumped onto a transfer chain along other short wall that that went to the sorter and trays then out the door at the stacker. The infeed and out feed of the mill were side by side.
The chip system had one conveyer under the headrig and another under all of the edgers both of these conveyors ran parallel to each other. There was a 6 section in both conveyors that that had a series of 3 holes to allow the fines to drop down to second layer of the conveyor. At one end, a third conveyor had a trough along the side of it for the fines. The tailings went thru a Nicholson chipper, then to the surge bin, a screen, and finally to the sort bins.
Offline Puffergas
    • Puffergas
« Reply #4 on: March 20, 2010, 10:58:34 PM »
I worked in a large furniture manufacturing plant and they use vibrating conveyors feeding hammer mills. This was a horizontal set up. Worked pretty good.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
Offline Cedarman
    • Cedarusa
« Reply #5 on: March 21, 2010, 07:00:24 AM »
We use a horizontal grinder with 100 HP motor.  Mulch is blown into a truck. When truck is full, it is switched out with another.  Sometimes the company can't get here for a few hours and we have to buffer the waste.  We can fill the truck in 2 to 3 days with our waste stream.
We put all slabs , edging strips,cut offs and sawdust through the hog. Will only take slabs 5" and thinner. Sawdust does not hurt our mulch.  We also sell by weight.  If selling by yard, you will get nothing for the sawdust as it settles between the larger pieces.  We sell by weight because there is not a good way to measure the actual yards of mulch in the truck.  We have done this for 10 years or so.
We have a belt that runs full length of mill and feeds a vibrating conveyor. It would be good to put an amp measuring device on the hog to shut down the vibrating conveyor  if the hog starts to overload or out put gets clogged.  It is not too hard to clear the clog.
Kansas, do lots of research on hogs. I would use a different one than what we have.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #6 on: March 22, 2010, 01:33:42 AM »
The cedar mill and pole mill down the road from me have a different approach. They pile up all their slabs, butts, rejects, etc. in one huge pile -- about 16' high, 30' wide, and as long as it has to be. Then once or twice a year they hire a guy to bring in a portable grinder.
I haven't seen "under the hood", so I don't know what does the actual grinding. It has a 6' wide horizontal steel conveyor about 16' long and it's got a pair of 650 HP Cat diesels driving it. Apparently the guy hauls it around to various operations that don't want to invest in their own system.
Someone told me it was there last week, so I might just mosey on down with the camera tomorrow if time permits.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Kansas
« Reply #7 on: March 22, 2010, 07:58:31 AM »
Brucer  That is what we have done in the past.We have an open front to the south and all slash gets pitched outside and then pushed up every few days into a pile. Problem is, the guy that was wholesaling the mulch and arranged for the the grinder seemed to lose his markets when the housing downturn hit. That coupled with all the rain and snow we have had the last two years has resulted in a real mess trying to push it down to the pile. To put it mildly, our yard is a disaster.
Cedarman, I like the idea of using two trailers. If one of these biofuel companies steps up and pays a decent price, I would like to do just that. I am just getting started researching grinders. The plan is to have this all in place in the October/November time frame, so I have some time to try and get it right.
Offline Ron Wenrich
« Reply #8 on: March 22, 2010, 05:29:43 PM »
We have several trailers for chips and sawdust.  We simply switch trailers with a yard truck when they get full.  Then they can be hauled when the truckers get around to it.
Grinder Head Angles on a TECOMEC chain saw grinder--Same grinder as Oregon 511
Started by hydro2 on Chainsaws
Last post November 29, 2005, 01:15:23 PM
by rickk
Why do we waste so much wood in the USA?
Started by Engineer on Firewood and Wood Heating
Last post February 09, 2015, 01:54:14 PM
by Weekend_Sawyer
Burning Wood Waste
Started by fast_freddie on General Board
Last post January 07, 2005, 02:39:30 AM
by iain
Waste wood into shavings
Started by Northside on Sawmills and Milling
Last post January 02, 2020, 10:24:51 AM
by Northside
